Internal Pullup only on RB5 - PIC16F677
davefromnj
PostPosted: Thu Mar 13, 2008 2:23 pm     Reply with quote
Hello All,
The target IC is a PIC 16F677:
I need to use only one Port B pin with an internal pullup. According to the datasheet this is possible by setting up RABPU[bar] and setting the proper bits in the WPUB register.
The other Port B pins are as follows:
Portb.4 = I2C Data
Portb.5 = I need this one to have its internal pull up enabled.
Portb.6 = I2C Clock
Portb.7 = Digital Output
I didn't see a specific function or command in the CCS libraries to modify the WPUB register and set or clear the RABPU[bar] register.
Can someone point out how to do this?
Thank you all!
necati
pullups
PostPosted: Thu Mar 13, 2008 2:51 pm     Reply with quote
port_b_pullups (0b00100000);
