nicko Guest
| i2c between 2 PICS |
Posted: Mon Mar 10, 2008 2:36 pm |
I am in trouble with getting 2 PICs communicating through i2c interface.
I observed SDA and SCL signals with a scope. I saw the first WR command
and the following 2 bytes going through and ACKed by the slave. Then the
RD command is sent and ACKed by the slave and after that SDA and SCL
signals freeze at 0V. Any ideas of what I did wrng? Thanks in advance.
Masre code:
#include <16F886.h>
#device adc=10
#FUSES HS //High speed Osc (> 4mhz)
#FUSES MCLR //Master Clear pin used for I/O
#FUSES NOFCMEN //Fail-safe clock monitor disabled
#FUSES BORV40 //Brownout reset at 4.0V
#use delay(clock=8000000)
#use rs232(baud=19200,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8)
#use i2c(MASTER, scl = PIN_C3, sda = PIN_C4, FORCE_HW)
#BYTE PORTB = 0x06 //Hardware config registers...
#BYTE TRISA = 0x85
#BYTE TRISB = 0x86
#BYTE TRISC = 0x87
#BYTE SSPADD = 0x93
#define SCAN_BYTE1 10
#define SCAN_BYTE2 11
int16 slaves[16];
int8 slave_count = 0;
void detect_slaves(){
int32 i = 0;
int8 addrh, addrl, temp;
while(i < 0xFFFF){
addrl = (int8)(i & 0xFF);
addrh = (int8)(i >> 8);
i2c_start();
i2c_write(0xA0);
i2c_write(SCAN_BYTE1);
i2c_write(addrh);
//i2c_stop();
i2c_start();
i2c_write(0xA1);
//while(i2c_poll() == 0);
temp = i2c_read();
i2c_stop();
if(temp != 0xC3)
i = i + 256;
else{
i2c_start();
i2c_write(0xA0);
i2c_write(SCAN_BYTE2);
i2c_write(addrl);
//i2c_stop();
i2c_start();
i2c_write(0xA1);
temp = i2c_read();
i2c_stop();
if(temp == 0xC3){
slaves[slave_count] = i;
slave_count++;
i++;
printf("\r\nSlaves found: %d\r\n", slave_count);
for(addrh=0;addrh<slave_count;addrh++)
printf("nSlave #%d Slave ID %LX\r\n", addrh, slaves[addrh]);
void init_ports(){
TRISA = 0x03;
TRISB = 0x00;
TRISC = 0x98;
void main(){
init_ports();
SSPADD = 0x7F; //The slowest possible SCL
detect_slaves();
for( ; ; ){
PORTB++;
Slave code:
#include <16F883.h>
#device adc=8
#use i2c(SLAVE, ADDRESS = 0xA0, scl = PIN_C3, sda = PIN_C4, FORCE_HW)
#BYTE TRISA = 0x85
#BYTE TRISB = 0x86
#BYTE TRISC = 0x87
#BYTE SSPADD = 0x93
int8 state;
int8 i2c_buffer[16];
extern int8 state;
#INT_SSP
void i2c_isr(){
output_high(PIN_B7);
state = i2c_isr_state();
if(state >= 0x80)
i2c_write(0xC3);
i2c_buffer[1] = i2c_read();
output_low(PIN_B7);
void init_ports(){
TRISA = 0x03;
TRISB = 0x00;
TRISC = 0x98;
void main(){
init_ports();
PORTB = 0;
clear_interrupt(INT_SSP);
enable_interrupts(INT_SSP);
for( ; ; ){
//printf("%X \r\n", state);
Posted: Mon Mar 10, 2008 3:36 pm |
This series of PICs have bugs with the i2c slave mode.
I was never able to make it work. Later, Microchip released an errata
notice on the MSSP module. They give a work-around for the slave,
but I never tried it. In other words, you have do some some coding
beyond using the CCS functions. I don't have time to do this right now.
http://ww1.microchip.com/downloads/en/DeviceDoc/80302D.pdf |
Douglas Kennedy
Posted: Mon Mar 10, 2008 8:13 pm |
Microchip's errata are a least an admission of something but I don't understand the Microchip business model of not recalling these chips and either replacing them with modified silicon or substituting a working device.
They cost pennies to manufacture and the cost of having customers feel it is their loss if Microchip errs must be higher. I know the US medical model is never to disclose mistakes and have the patient pay for the medical mistake when it happens. It has led to angry patients and massive legal bills for the medical profession. Microchip runs the risk of a serious malpractice law suit. |
nicko Guest
Posted: Tue Mar 11, 2008 10:16 am |
Thank You PCM programmer,
I migrated to PIC16F876A and I am fine now. |
