software pwm width set question
whung.john
PostPosted: Fri Jul 13, 2007 10:55 am     Reply with quote
hi:
today i read custom form content follow as :
but i dont understand width value ,how to culcuate.
please help me to solve,thanks u.
#include <16F877>
#use delay(clock = 4000000)
#define PWM_PIN PIN_B1
#define LOOPCNT 39
int8 width;
#INT_RTCC
void tick_interrupt(void);
main()
width = 10;
setup_counters(RTCC_INTERNAL, RTCC_DIV_1);
enable_interrupts(INT_RTCC);
#INT_RTCC
static int8 loop = LOOPCNT;
static int8 pulse;
if(--loop == 0)
loop = LOOPCNT;
pulse = width;
if(pulse)
output_high(PWM_PIN);
pulse--;
output_low(PWM_PIN);
PostPosted: Fri Jul 13, 2007 1:18 pm     Reply with quote
The width value can be from 0 to LOOPCNT. This corresponds to 0%
and 100% duty cycle. In the example below, the width = 0 for 0% duty
cycle and the width = 39 for 100% duty cycle.
#include <16F877.H>
#define PWM_PIN  PIN_B0
#define LOOPCNT 39
int8 width;
#INT_RTCC
main()
width = 0;
// Step through all values for width, from 0 to 39.
// This will slowly increase the duty cycle from 0 to 100%,
// by doing one step every 100 ms.
   for(width = 0; width <= LOOPCNT; width++)
#INT_RTCC
static int8 pulse;
if(--loop == 0)
   loop = LOOPCNT;
   pulse = width;
if(pulse)
   pulse--;
whung.john
max frequency
PostPosted: Fri Jul 13, 2007 10:57 pm     Reply with quote
thanks u very much for programmer:
but if ithink use software pwm make a frequency.
how much (MAX frequency AND min frequency) can make from software pwm RTCC OR TIMER1 OR timer2.
can u teach me how to culcuate? thanks u .
