MASTER Slave communicaton
atta
PostPosted: Thu Jul 12, 2007 2:23 am     Reply with quote
PLZ some one can help me?
- LM35 is conected to Slave controller(PIC16f877)
-slave is sending the temperature value to master controller(pic16f877) as string string via RS232.
-master on reciving this string on soft-port will send this string to PC on hardport.
-slave also attach its adress with the string.
ON master side i have to seprate the adress and temp value for my control logic.
PLZ can some one help me by giving me the code of
-how the slave will send string(temperatur + adress)
-how the master will receive the string
-how the master will saperate the adress and teperature value
atta
PostPosted: Fri Jul 13, 2007 1:56 pm     Reply with quote
printf ("%3.1fslave1\r",(float)temperatur);
\\slave is sending temperature value
master will receive following string i want to separate temperature value and slave1 from this string.
i am using following code at master side to separate temperature value and slave1 from this string.
fgets (string1,COM_A);
    fprintf (PC, string1);
    temp1=strtod(string1,&ptr1);
    delay_ms (1000);
    fprintf (PC,"temperature(Slave) = ");
    fprintf (PC,"%3.1f", (float)temp1);
the above code works if slave send sitring by this way
printf("25.5A\r");
PostPosted: Fri Jul 13, 2007 2:24 pm     Reply with quote
PLZ help me where is the problem in the above code
PostPosted: Fri Jul 13, 2007 2:46 pm     Reply with quote
It's not clear to me exactly what you want to do. You need to show
the string that your master will receive, and then show the two extracted
sub-strings that you want to get.
It may be that you want the C language equivalent of MID$ in Basic.
If so, see this thread.
http://www.ccsinfo.com/forum/viewtopic.php?t=27121
atta
PostPosted: Fri Jul 13, 2007 3:01 pm     Reply with quote
actuly i want to use this function
float result;
char str[12]="123.45hello";
char *ptr;
result=strtod(str,&ptr);
//result is 123.45 and ptr is "hello"
slave send the following command to master
temperature=read_adc ();
printf ("%3.1fA\n\r",(float)temperature);
master on receiving this string has to send the result to PC seriallly by using the following code
fgets (string1,COM_A);// from slave
    result=strtod(string1,&ptr1);
    fprintf (PC,"%6.2f", (float)result);//to PC
