Bluetooth Module Driver
endSly
PostPosted: Wed Jun 27, 2007 5:46 am     Reply with quote
This driver suports all a7eng serial bluetooth modules and parallax Bluetooth Module.
This is a first beta.
 * bt.c     Bluetooth Controler Library
 *    Distribute freely with copyright notice intact.
 *    Library to control a7eng's Bluetooth Modules eb100
 *    and eb500 by serial port using the CCS compilers.
 *       www.a7eng.com
 * (c) 2007 endSly
 ** Functions Reference **
 * bt_command_mode(EscapeChar)
 *    The bt_command_mode allow  to use commands.
 *    When Bluetooth device started goes automaticaly to
 *    command Mode
 *    Parameters:
 *     EscapeChar Control Char to escape from EasyConnect
 *                Mode. Default '+'
 * bt_connect(Address, Profile, Timeout)
 *    The bt_connect command establishes a connection
 *    to another Bluetooth device. Returns 1 if error
 *    Parameters:
 *     Address    The Bluetooth address of the remote
 *                device.
 *     Profile    The Bluetooth profile to connect with.
 *     Timeout    An optional parameter used to abort
 *                the connection request after the
 *                specified number of seconds.
 *                0 -> Not Used
 * bt_delete_trusted(All, Address)
 *    The delete trusted device command removes the
 *    remote device from the trusted list and prevents
 *    it from being able to connect with the local Bluetooth
 *    device when security is turned on.
 *    Parameters:
 *     All        This parameter is used to remove
 *                all devices from trusted status if 1.
 *     Address    The Bluetooth address of the device that
 *                should be removed from trusted status if all 0.
 * bt_diconnect()
 *    The bt_disconnect command closes the connection
 *    with the remote Bluetooth device.
 * bt_EasyConnect_mode()
 *    The bt_EasyConnect_mode commandallow to send messages
 *    via Bluetooth;
 * bt_get_address(Device)
 *    The bt_get_address command returns a globally unique
 *    address for either the local Bluetooth device
 *    or the remote Bluetooth device.
 *    Parameters:
 *     Device     LOCAL or REMOTE
 * bt_get_connectable()
 *    The bt_get_connectable command returns the current
 *    connectable setting of the local Bluetooth device.
 *    Returns 1 if on, 0 if off or error
 * bt_get_encrypt()
 *    The bt_get_encryp command returns the current
 *    encryption setting of the local Bluetooth device.
 * bt_get_escape_char()
 *    The get escape character command returns the current
 *    character used in the soft break command to instruct
 *    the local EmbeddedBlue device to break the flow of
 *    data and begin accepting commands.
 *    Returns char or 0 if error
 * bt_get_flow_control()
 *    The bt_get_flow_control command returns the flow control
 *    setting of the local EmbeddedBlue device.
 *    Returns 0 if none or 1 if hardware
 * bt_get_link_timeout()
 *    The bt_get_link_timeout command returns the amount of time,
 *    in seconds, it takes for the local Bluetooth device to
 *    notice that the connection has been broken if the remote
 *    device disappears.
 * bt_get_name(*Name)
 *    The bt_get_name command returns the name of the local
 *    Bluetooth device in *Name.
 *    Name's lenght 16 chars
 * bt_get_security()
 *    The get security command returns the current security
 * bt_get_tx_power()
 *    The bt_get_tx_power command returns the transmit
 *    power setting of the Bluetooth radio.
 *    The transmit power is set to 10 (maximum) by default.
 * bt_get_visible()
 *    The bt_get_visible command returns the current visibility
 * bt_list_trusted_devices(*ListAddress)
 *    The bt_list_trusted_devices command returns a list of
 *    all the devices that are allowed to connect to the
 *    local Bluetooth device when security is turned on.
 *    Parameters:
 *     ListAddress   Pointer to array of address
 * bt_list_visible_devices(*ListAddress, *Name, Timeout)
 *    The bt_list_visible_devices command returns a
 *    listing of all the Bluetooth devices that are
 *    currently in range and visible.
 *    Parameters:
 *     Name          Pointer to array of chars (16 chars for each Name)
 *                   0xFF Not names listed
 *     Timeout       An optional parameter used to abort the
 *                   list visible devices command after the
 *                   0 Not used
 * bt_reset(Factory)
 *    The bt_reset command will cause the local Bluetooth
 *    device to reboot.
 *    Parameters:
 *     Factory       Restores all device settings to factory
 *                   defaults. This includes the baud rate parameter
 *                   which may cause serial communications to be lost after
 *                   the command is issued. To reestablish communications
 *                   with the device after resetting to factory defaults,
 *                   simply adjust the baud rate on the microprocessor
 *                   serial port to match the device default rate of 9600bps.
 * bt_set_baud_rate(Rate)
 *    The bt_set_baud_rate command sets the baud rate for
 *    communications with the local Bluetooth device.
 *    Parameters:
 *     Rate          The baud rate value. Valid baud rates are
 *                   1200, 2400, 4800, 9600 (default), 19200,
 *                   38400, 57600, 115200, 230400, and 460800.
 * bt_set_connectable(State)
 *    The bt_set_connectable command provides control over whether the
 *    local Bluetooth device will accept connections from other
 *    Bluetooth devices.
 *    Parameters:
 *     State         1- On / 0- Off
 * bt_set_encrypt(State)
 *    The set encryption command provides control over whether
 *    transmitted data is encrypted or sent in the clear.
 *    Parameters:
 * bt_set_escape_char(Char)
 *    The bt_set_escape_char command provides control over the
 *    character used in the soft break command to instruct the
 *    local Bluetooth device to break the flow of data and begin
 *    accepting commands.
 *    Parameters:
 *     Char          Escape Character
 * bt_set_flow_control(State)
 *    The bt_set_flow _control command provides control over the
 *    flow control setting of the local Bluetooth device.
 *    Parameters:
 *     State         1- Hardware / 0- None
 * bt_set_link_timeout(Timeout)
 *    The bt_set_link_timeout command sets the amount of time it
 *    takes for the local Bluetooth device to notice if the remote
 *    device disappears. In Bluetooth terminology, this command
 *    controls the setting for link supervisor timeout.
 *    Parameters:
 *     Timeout       The time, in seconds, it takes for the device
 *                   to notice that a connection has been broken.
 * bt_set_name(*Name, Lenght)
 *    The bt_set_name command sets the name of the local Buetooth device.
 *    Parameters:
 *     Name          Pointer to array of chars with name
 *     Lenght        Lenght of the Name (Max = 32)
 * bt_set_passkey(*Passkey, Lenght)
 *    The bt_set_passkey command sets the passkey that is used when
 *    establishing a connection with a new device.
 *    The passkey is set to 0000 by default.
 *    Parameters:
 *     Name          Pointer to array of chars with Passkey
 *     Lenght        Lenght of the Name (Max = 16)
 * bt_set_security(State)
 *    The bt_set_security command sets the current security
 *    setting of the local Bluetooth device.
 *    Parameters:
 * bt_set_tx_power(Power)
 *    The bt_set_tx_power command sets the transmit power
 *    setting of the Bluetooth radio.
 *    Parameters:
 *     Power         The power setting which is an integer
 *                   between 1-10.
 * bt_set_visible(State)
 *    The bt_set_visible command provides control over
 *    whether the local Bluetooth device can be seen by
 *    other Bluetooth devices.
 *    Parameters:
#define ser_out   printf
//Profiles
#define SPP       0        //Serial Port Profile         "spp"
#define DUN       1        //Dial-Up Networking Profile  "dun"
#define LOCAL     0        //Local Bluetooth
#define REMOTE    1        //Remote Bluetooth
typedef struct address{
  unsigned int8 add_byte[6];
}address;
//ascii_to_u8bit -> Copy and Paste from Gary Smithson work - theByteFactory.com
unsigned int8 ascii_to_u8bit (char *string)      // Converts string "A1" to unsigned 8 bit A1 (basically atoi but more compact)
{                              // NOTE: This function processes both uppercase and lowercase strings
   unsigned int8   MSN;                  // Most Significant Nibble of the result
   unsigned int8   LSN;                  // Least Significant Nibble of the result
   MSN = (string[0] - '0');         // Assume numeric and subtract text 0 which is ASCII 30
   if (string[0] >= 'A') {            // The character is actually alphabetic,...
      MSN = MSN - 7;               // ...adjust for the 7 character gap in the ASCII table
   LSN = (string[1] - '0');         // Assume numeric and subtract text 0 which is ASCII 30
   if (string[1] >= 'A') {            // The character is actually alphabetic,...
      LSN = LSN - 7;               // ...adjust for the 7 character gap in the ASCII table
                              // Shift the MSN into position (zero fill), strip lowercase bit and...
   return ((MSN << 4) | (LSN & 0x0F));   // ...merge it with the LSN after the lowercase bit is stripped
unsigned int8 ascii_to_dec (char *string)      // Converts string "11" to unsigned 8 bit 11 (basically atoi but more compact)
   unsigned int8   MSN;
   unsigned int8   LSN;
   unsigned int8   CSN;
   if(string[1]==0x00)
      return MSN;
   if(string[2]==0x00)
      return LSN + MSN*10;
   CSN = (string[2] - '0');         // Assume numeric and subtract text 0 which is ASCII 30
   return CSN + LSN*10 + MSN*100;
void bt_command_mode(char esc_char){
   int i;
   for(i=0;i<3;i++)
      ser_out(esc_char);
   ser_out("\r");
int bt_connect(address address, int8 profile, unsigned int8 timeout){
   char r[3];
   // Example of connect command:
   //>con 00:0C:84:00:05:29 dun 10<CR>
   ser_out("con %2x:%2x:%2x:%2x:%2x:%2x ", address.add_byte[0],
                                           address.add_byte[1],
                                           address.add_byte[2],
                                           address.add_byte[3],
                                           address.add_byte[4],
                                           address.add_byte[5]);
   switch(profile) {
      case SPP :  ser_out("spp"); break;
      case DUN :  ser_out("dun"); break;
   if(timeout){
      ser_out(" %u", timeout);
   ser_out("\r");
   gets(r);
   if(r[0]=='A'&&r[1]=='C'&&r[2]=='K'){
      return 0;
   } else {
      return 1;
int bt_delete_trusted(int1 all, address address){
   char r[3];
   ser_out("del trusted ");
   if(all)
      ser_out("all");
      ser_out("%2x:%2x:%2x:%2x:%2x:%2x", address.add_byte[0],
   ser_out("\r");
   gets(r);
      return 0;
   } else {
      return 1;
int bt_disconnect(){
   char r[3];
   ser_out("dis\r");    //Send disconnect command
   gets(r);
      return 0;
   } else {
      return 1;
int bt_EasyConnect_mode(){
   char r[3];
   ser_out("ret\r");
   gets(r);
      return 0;
   } else {
      return 1;
address bt_get_address(int8 device){
   int i;
   char r[3];
   char addr_s[18];
   char byte_s[2];
   address addr;
   ser_out("get address ");
   switch(device){
      case  LOCAL    :  ser_out("local");    break;
      case  REMOTE   :  ser_out("remote");   break;
   ser_out("\r");
   gets(r);
      gets(addr_s);
      for(i=0; i<6; i++){
         byte_s[0]=addr_s[3*i];
         byte_s[1]=addr_s[3*i+1];
         addr.add_byte[i] = ascii_to_u8bit(byte_s);
   return addr;
int1 bt_get_connectable(){
   char r[3];
   char s[3];
   ser_out("get connectable\r");
   gets(r);
      gets(s);
      if(s[0]=='o'&&s[1]=='n'){
         return 1;
      } else {
         return 0;
   } else {
      return 0;
int1 bt_get_encrypt(){
   char r[3];
   char s[3];
   ser_out("get encrypt\r");
   gets(r);
      gets(s);
         return 1;
      } else {
         return 0;
   } else {
      return 0;
char bt_get_escape_char(){
   char r[3];
   char s;
   ser_out("get escchar\r");
   gets(r);
      s=getc();
      return s;
   } else {
      return 0;
int1 bt_get_flow_control(){
   char r[3];
   char s[8];
   ser_out("get flow\r");
   gets(r);
      gets(s);
      if(s[0]=='n'&&s[1]=='o'&&s[2]=='n'&&s[3]=='e'){
         return 0;
      } else {
         return 1;
   } else {
      return 0;
unsigned int8 bt_get_link_timeout(){
   char r[3];
   char s[3];
   ser_out("get linktimeout\r");
   gets(r);
      gets(s);
      return ascii_to_dec(s);
   } else {
      return 0;
void bt_get_name(char *name){
   char r[3];
   char s[16];
   int i;
   ser_out("get name\r");
   gets(r);
      gets(s);
      for(i=0;i<16;i++)
         *(name + i) = s[i];
int1 bt_get_security(){
   char r[3];
   char s[3];
   ser_out("get security\r");
   gets(r);
      gets(s);
         return 1;
      } else {
         return 0;
   } else {
      return 0;
unsigned int8 bt_get_tx_power(){
   char r[3];
   char s[3];
   ser_out("get txpower\r");
   gets(r);
      gets(s);
   } else {
      return 0;
int1 bt_get_visible(){
   char r[3];
   char s[3];
   ser_out("get visible\r");
   gets(r);
      gets(s);
         return 1;
      } else {
         return 0;
   } else {
      return 0;
int bt_list_trusted_devices(address *list_address){
   char r[3];
   char s[18];
   int1 cntrl=0;
   unsigned int8 byte_s[2];
   int i;
   unsigned int8 count = 0;
   ser_out("lst trusted\r");
   gets(r);
      while(!cntrl){
         for(i=0;i<17;i++){
            s[i]=getchar();
            if(s[i]=='>'){
               cntrl=1;
               return count;
         for(i=0; i<6; i++){
            byte_s[0]=s[3*i];
            byte_s[1]=s[3*i+1];
            list_address[count].add_byte[i] = ascii_to_u8bit(byte_s);
         gets(r);
         count += 1;
   return count;
int bt_list_visible_devices(address *list_address, char *name, unsigned int8 timeout){
   char r[3];
   char s[18];
   int1 cntrl=0;
   int i;
   ser_out("lst visible");
   if(name != 0xFF)
      ser_out(" name");
   if(timeout)
   ser_out("\r");
   gets(r);
      while(!cntrl){
         for(i=0;i<18;i++){
            s[i]=getchar();
            if(s[i]=='>'){
               cntrl=1;
               return count;
         if(name != 0xFF){
            for(i=0;i<16;i++){
               *name[i]=getchar();
               printf(*name[i]);
               if(*name[i] == 0x0D){
         } else {
            gets(r);
         for(i=0; i<6; i++){
            byte_s[0]=s[3*i];
            byte_s[1]=s[3*i+1];
         count += 1;
         printf("OK");
   return count;
int1 bt_reset(int1 factory){
   char r[3];
   ser_out("rst");
   if(factory)
      ser_out(" factory");
   ser_out("\r");
   gets(r);
      return 0;
   } else {
      return 1;
int1 bt_set_baud_rate(unsigned int32 rate){
   char r[3];
   ser_out("set baud %Lu\r", rate);
   gets(r);
      return 0;
   } else {
      return 1;
int1 bt_set_connectable(int1 state){
   char r[3];
   ser_out("set connectable ");
   if(state){
      ser_out("on\r");
   } else {
      ser_out("off\r");
   gets(r);
      return 0;
   } else {
      return 1;
int1 bt_set_encrypt(int1 state){
   char r[3];
   ser_out("set encrypt ");
   if(state){
      ser_out("on\r");
   } else {
      ser_out("off\r");
   gets(r);
      return 0;
   } else {
      return 1;
int1 bt_set_escape_char(char esc_char){
   char r[3];
   ser_out("set escchar ");
   ser_out(esc_char);
   ser_out("\r");
   gets(r);
      return 0;
   } else {
      return 1;
int1 bt_set_flow_control(int1 state){
   char r[3];
   ser_out("set flow ");
   if(state){
      ser_out("none\r");
   } else {
      ser_out("hardware\r");
   gets(r);
      return 0;
   } else {
      return 1;
int1 bt_set_link_timeout(unsigned int8 timeout){
   char r[3];
   ser_out("set linktimeout %u\r", timeout);
   gets(r);
      return 0;
   } else {
      return 1;
int1 bt_set_name(char *name, unsigned int8 lenght){
   char r[3];
   unsigned int8 i;
   ser_out("set name ");
   for(i=0;i<lenght;i++)
      ser_out(*(name+i));
   ser_out("\r");
   gets(r);
      return 0;
   } else {
      return 1;
int bt_set_passkey(char *passkey, unsigned int8 lenght){
   char r[3];
   unsigned int8 i;
   ser_out("set passkey ");
      ser_out(*(passkey+i));
   ser_out("\r");
   gets(r);
      return 0;
   } else {
      return 1;
int1 bt_set_security(int1 state){
   char r[3];
   ser_out("set security ");
   if(state){
      ser_out("on\r");
   } else {
      ser_out("off\r");
   gets(r);
      return 0;
   } else {
      return 1;
int1 bt_set_tx_power(unsigned int8 power){
   char r[3];
   ser_out("set txpower %u\r", power);
   gets(r);
      return 0;
   } else {
      return 1;
int1 bt_set_visible(int1 state){
   char r[3];
   ser_out("set visible ");
   if(state){
      ser_out("on\r");
   } else {
      ser_out("off\r");
   gets(r);
      return 0;
   } else {
      return 1;
