Problem after ICD software/firmware upgrade..... |
Posted: Thu May 24, 2007 3:49 pm |
I just "upgraded" to version 2.77 of the ICD software, and version 1.37 of the ICD-U40 firmware. After the upgrade, everything seems to work fine (Test ICD, Test Target, etc.), but my known-good target board no longer runs known-good software.......
Is there some setting I need to change? I tried both 'normal' and 'fast' programming modes......
PIC is the 16F628.
Thanks,
Noel |
Posted: Thu May 24, 2007 3:51 pm |
To be clear, when I click Run Program, or disconnect the ICD from my board my program does not execute. I know this because none of the diagnostic LEDs flash as they should during normal startup of my code.....
Noel |
