RS232 and RS485 working together ?
Cookie
PostPosted: Tue Mar 20, 2007 6:16 am     Reply with quote
Hello everybody.
I am using PIC 18F2455 as a master to communicate with numerous 16F690.
My first step is to configure the 18F and try sending some data on RS485 line
il watch with an oscilloscoppe , see that data are transmited.
I activate the RS232 , that i connected to a PC for debugging, The PC receive the RS232 data , and print them well on my Screen.
But RS485 do not work any more. Is there something in the hardware of software that avoid them to work together, or i did something wrong ?
I use the RS485.c
with the default Pins
#if(RS485_USE_EXT_INT == FALSE)
   #ifndef RS485_RX_PIN
   #define RS485_RX_PIN       PIN_C7   // Data receive pin
   #ifndef RS485_TX_PIN
   #define RS485_TX_PIN       PIN_C6   // Data transmit pin
   #ifndef RS485_ENABLE_PIN
   #define RS485_ENABLE_PIN   PIN_B4   // Controls DE pin.  RX low, TX high.
   #ifndef RS485_RX_ENABLE
   #define RS485_RX_ENABLE    PIN_B5   // Controls RE pin.  Should keep low.
   #use rs232(baud=9600, xmit=RS485_TX_PIN, rcv=RS485_RX_PIN, enable=RS485_ENABLE_PIN, bits=9, long_data, errors, stream=RS485)
   #use rs232(baud=9600, xmit=RS485_TX_PIN, rcv=RS485_RX_PIN, enable=RS485_ENABLE_PIN, bits=9, long_data, force_sw, multi_master, errors, stream=RS485_CD)
and i activate RS232 like this
   #if defined(_DEBUG_RS232)
      #use rs232(baud=9600,parity=N, xmit=PIN_B1, rcv=PIN_B0, bits=8,stream=DEBUG)
   #define RS485_ID  1                 // The device's RS485 address or ID
   #define RS485_USE_EXT_INT FALSE        // Select between external interrupt
   #include "RS485.c"
As you can see i uses differents pins for RS232 and RS485
Any advice ?
thanks
Cookie
PostPosted: Wed Mar 21, 2007 3:29 am     Reply with quote
any help ?
Only thing i need is to know, if i could work , or it cannot. SO i can avoid loosing time trying to make something work that is impossible!
Humberto
PostPosted: Wed Mar 21, 2007 5:15 am     Reply with quote
Well, you show us only the header pin definitions, but we didnīt see your code.
As long as I understand, your architecture is:
1 Master that comunicate with n Slaves through RS485 and the same Master comunicate
with a PC through RS232, is this ok? If this is the case, of course it should work, the Master
is who handle the whole communications timmings.
Just a comment with your code:
There is a risk of bus contention and is code dependant. Usually I keep tied together PIN2
and PIN3 of the RS485 transceiver (unless you use Full Duplex) and control both pins with
a single PIC output.
Humberto
Cookie
PostPosted: Wed Mar 21, 2007 8:35 am     Reply with quote
thank you for your anwer.
I make it work, you have to include the RS485.c file BEFORE declare use of rs232. If i do the other way it do not work.
strange ...
thanks for your concern Humberto.
PostPosted: Sat Apr 21, 2007 4:12 am     Reply with quote
whats your compiler version Cookie
funmix
PostPosted: Sun Apr 22, 2007 8:55 pm     Reply with quote
HI cookie,
do you mind to share your working code?
