Problem with ICD U40 --> Target was not reset
bard
PostPosted: Tue Oct 25, 2005 8:03 pm     Reply with quote
Hi Everyone
I am having one problem while using ICD U40.
Now i am using PIC16F877A with ICD U40.
During initialise ICD, the error Pop out as
" Target was not reset, check target oscillator and MCLR.
Somebody help me.
PostPosted: Tue Feb 06, 2007 7:22 pm     Reply with quote
I am having the same problem with a 18f1220, but work OK if I use an ICD-S...
CCS Technical Support does not monitor this forum on a regular basis. Please do not post bug reports to this form. All bug reports should be emailed to support@ccsinfo.com. Thank you.
frustrated EE
PostPosted: Sun Feb 18, 2007 5:37 pm     Reply with quote
I have the same problem with mine
buneri
Hi bard
PostPosted: Mon Feb 26, 2007 1:28 am     Reply with quote
I was having the same problem with ICD U.
I had connected the low value resistor with MCLR(10k).
Now i have connected the 47k resistor and my problem is solved.
PostPosted: Tue Mar 13, 2007 10:57 am     Reply with quote
The answer to that is some version of ICD software have problems with internal oscillator. You may have to go to an older version.
