drawbars
Problem using CCS Debugger with multiple modules. |
Posted: Fri Apr 21, 2006 2:53 pm |
I am in the process of writing and debugging a rather large program. It has one master module --
master.c
and a number of modules that are included in this file, early in the syntax of master.c --
/* master.c -- a really long program */
int this;
int16 that;
int the_other;
#INCLUDE eeprom.c
#INCLUDE display.c
#INCLUDE somethingelse.c
The program compiles successfully, and loads into the CCS Debugger. If I press F7, the program jumps to the main() routine, just as it should.
If I continue pressing F7, it continues to step down the code -- until I reach init_disp(), which is the first function that is not physically in master.c; it is in display.c -- which was included in At that point, the text pointer jumps to the top line of master.c. I can't see any more details in the Debugger.
Also, I can set a breakpoint for a line anywhere in master.c, and the Debugger will execute to that point in the code. However, if I try to set the breakpoint to a line in one of the included modules (ex: the first called function in display.c), I get the following error:
Error adding breakpoint: The file display.c does not
belong to the debugging session.
I am using CCSWH v3.249, which is the latest version. The MCU is the PIC18F6527.
Anybody seen this before? What am I doing wrong?
Regards,
-BW
Bruce Wahler
Design Consultant
Ashby Solutions™
bruce@ashbysolutions.com |
