cube007 Guest
| Using ICSPCLK and ICSPDAT as input? |
Posted: Sun Aug 24, 2003 4:52 am |
I'm using a PIC16F676. When trying to use the ICSPCLK and ICSPDAT as a normal input, it's not possible to read out these pins.
That is my code:
#include <16F676.h>
#device adc=8
#fuses INTRC_IO,BANDGAPHIGH,NOPROTECT,BROWNOUT,NOMCLR,NOCPD,NOWDT,PUT
#rom 0x3ff = {0x3470}
#include "main.h"
setup_adc(ADC_OFF);
setup_timer_1 (T1_DISABLED);
setup_comparator(FALSE);
setup_vref(FALSE);
while(1) {
output_high(PIN_C3);
delay_ms(200);
output_low(PIN_C3);
delay_ms(200);
if (input(PIN_A0))
output_high(PIN_C4);
output_low(PIN_C4);
Is there anything I did't noticed in the spec?
Best regrads,
cube007
___________________________
Original Post ID: 144517187 |
cube007 Guest
| Re: Using ICSPCLK and ICSPDAT as input? |
Posted: Sun Aug 24, 2003 8:12 am |
Ok, now I got it.
It is necessary to init the adc ports with "setup_adc_ports(xxx)" and to disable the comparator with "setup_comparator(NC_NC)".
By,
cube007
Original Post ID: 144517189 |
Mark
Posted: Sun Aug 24, 2003 2:12 pm |
I prefer to set everything up manually by reading the datasheets for the PIC. However, I believe that you need to do this
setup_adc_ports(NO_ANALOGS);
Mark
:=Hello,
:=I'm using a PIC16F676. When trying to use the ICSPCLK and ICSPDAT as a normal input, it's not possible to read out these pins.
:=That is my code:
:=#include <16F676.h>
:=#device adc=8
:=#use delay(clock=4000000)
:=#fuses INTRC_IO,BANDGAPHIGH,NOPROTECT,BROWNOUT,NOMCLR,NOCPD,NOWDT,PUT
:=#rom 0x3ff = {0x3470}
:=#include "main.h"
:=void main() {
:= setup_adc(ADC_OFF);
:= setup_timer_1 (T1_DISABLED);
:= setup_comparator(FALSE);
:= setup_vref(FALSE);
:= while(1) {
:= output_high(PIN_C3);
:= delay_ms(200);
:= output_low(PIN_C3);
:= delay_ms(200);
:= if (input(PIN_A0))
:= output_high(PIN_C4);
:= else
:= output_low(PIN_C4);
:=Is there anything I did't noticed in the spec?
:=Best regrads,
:=cube007
Original Post ID: 144517196 |
cube007 Guest
Posted: Sun Aug 24, 2003 3:19 pm |
Hello Mark,
actually I got the solution (please take a look at this post: <a href="http://www.pic-c.com/forum/general/posts/144517189.html" TARGET="_blank">http://www.pic-c.com/forum/general/posts/144517189.html</a>). First I tried "setup_adc_ports(NO_ANALOGS)" but this command is not supported with the CCS and the PIC16F676.
cube007
:=I prefer to set everything up manually by reading the datasheets for the PIC. However, I believe that you need to do this
:=setup_adc_ports(NO_ANALOGS);
:=Mark
:=:=Hello,
:=:=I'm using a PIC16F676. When trying to use the ICSPCLK and ICSPDAT as a normal input, it's not possible to read out these pins.
:=:=That is my code:
:=:=#include <16F676.h>
:=:=#device adc=8
:=:=#use delay(clock=4000000)
:=:=#fuses INTRC_IO,BANDGAPHIGH,NOPROTECT,BROWNOUT,NOMCLR,NOCPD,NOWDT,PUT
:=:=#rom 0x3ff = {0x3470}
:=:=#include "main.h"
:=:=void main() {
:=:= setup_adc(ADC_OFF);
:=:= setup_timer_1 (T1_DISABLED);
:=:= setup_comparator(FALSE);
:=:= setup_vref(FALSE);
:=:= while(1) {
:=:= output_high(PIN_C3);
:=:= delay_ms(200);
:=:= output_low(PIN_C3);
:=:= delay_ms(200);
:=:= if (input(PIN_A0))
:=:= output_high(PIN_C4);
:=:= else
:=:= output_low(PIN_C4);
:=:=Is there anything I did't noticed in the spec?
:=:=Best regrads,
:=:=cube007
Original Post ID: 144517199 |
