__SIMS
PIC18F8722 help; nothing happening |
Posted: Thu Mar 23, 2006 9:27 am |
I am having trouble getting any output on my LED when using the PIC18F8722... please help:
#include <18F8722.h>
#include "FLEX_LCD420.C"
lcd_init();
output_high(PIN_F2);
output_low(PIN_F2);
printf(lcd_putc, "Hello World.");
lcd_putc("f");
The only change I made to the FLEX_LCD420.c was to change the appropriate pin connections I am using:
#define LCD_DB4 PIN_F4
#define LCD_DB5 PIN_F5
#define LCD_DB6 PIN_F6
#define LCD_DB7 PIN_F7
#define LCD_E PIN_F2
#define LCD_RS PIN_F0
#define LCD_RW PIN_F1 |
Posted: Fri Mar 24, 2006 12:47 am |
That's [spam]'s code. He's going to have to support it.
Just letting you know. |
vitorego
Posted: Tue Apr 18, 2006 5:26 pm |
The flexible lcd code also works with powertip LCD modules with 16x2 and 5*8 dots?
I canīt configure this LCD manually with function sets and all this things. |
noisepic
Posted: Fri May 05, 2006 8:03 pm |
I have used flex_lcd.c for Pic16F877A but it doesn't working. I don't know why. I used PORTB
RS PIN_B2
E PIN_B3
D4-D7 PIN_B4-PIN_B7
help me pls? or another code!! |
Mark
Posted: Sat May 06, 2006 8:44 am |
Did you remember to include NOLVP in your fuses? |
fuzzy
Posted: Sun Jun 04, 2006 5:07 am |
could you please tell me how can i write a variable value on this kind of LCD with these drivers?? |
Mark
Posted: Sun Jun 04, 2006 8:16 am |
lcd_putc() will display a single char.
You can redirect the printf command to the LCD by supplying this function name as the first parameter of the printf. Look at the help for printf to see an example. |
TheNewHetfield
Posted: Mon Jun 26, 2006 4:05 pm |
It's a very useful code!!
I'm using it in a huge project, needing to optimize the use of the ports, and this code has become an excelent solution
Greetings from Santiago de Chile
Sergio |
pdswar
Joined: 18 Jul 2006 Posts: 33 Location: Maryland, USA
how can I modify flex_lcd.c to drive NKK Smartswitch LCD |
Posted: Tue Jul 18, 2006 7:18 am |
I am a beginner to PIC programming and I am using PIC 18F6722 to drive NKK Smartswitch LCD.
http://www.nkksmartswitch.com/PDF/IS01NCF.pdf?
// As defined in the following structure the pin connection of Port F is as
// follows:
// F0 rs
// F1 rw
// F2 enable
// F3 LCD_LP
// F4 LCD_DOUT
// F5 LCD_BL
// Pins F6 and F7 are not connected
How can I modify flex_lcd.c to drive 36 X 24 pixel NKK Smartswitch LCD |
treitmey
javi.ar
Ignorance |
Posted: Thu Jul 20, 2006 1:52 pm |
Sorry about this silly question but can anyone explain what are the meaning of this line
output_bit(LCD_DB4, !!(nibble & 1));
i think is putting on the PIN (#define LCD_DB4 PIN_D0) D0 one bit, so far so good, but what is !!, I cannot find out why do you need twice negative (nibble & 1) which I think is always the LSB of each byte...
Please clarify, and thanks in advance. |
Posted: Thu Jul 20, 2006 2:16 pm |
There is a note in the source code which explains this:
Quote: | void lcd_send_nibble(int8 nibble)
// Note: !! converts an integer expression
// to a boolean (1 or 0).
output_bit(LCD_DB5, !!(nibble & 2));
output_bit(LCD_DB6, !!(nibble & 4));
output_bit(LCD_DB7, !!(nibble & 8));
delay_cycles(1);
output_high(LCD_E);
delay_us(2);
output_low(LCD_E);
The CCS output_bit() function wants the 'value' parameter to be 0 or 1.
From the CCS manual:
Quote: | Syntax:
output_bit (pin, value)
Parameters:
Pins are defined in the devices .h file. The actual number is
a bit address. For example, port a (byte 5) bit 3 would have
a value of 5*8+3 or 43. This is defined as follows: #define
PIN_A3 43. Value is a 1 or a 0. |
Doing a double negation (!!) will convert an integer value to a 0 or 1.
I am giving the output_bit() function what it needs. |
jaime
Joined: 25 Nov 2005 Posts: 56 Location: Porto - Portugal
Posted: Tue Dec 19, 2006 10:38 am |
What i need to do to use it with 24x2 display??
Thanks |
Posted: Tue Dec 19, 2006 1:21 pm |
Quote: | What i need to do to use it with 24x2 display ? |
Give the manufacturer and part number of the 24x2 LCD that you
want to use. Post a link to the data sheet. I'll look at it. |
jaime
Posted: Tue Dec 19, 2006 1:46 pm |
In the silkscreen i have:
SII L2432 N11V0
There's some info in the net but i cannot find the site of the manufaturer...
http://www.eio.com/l2432ap.htm |
