jruibarroso
something wrong with DigPot AD8402 |
Posted: Wed Nov 08, 2006 10:59 am |
I'm using the driver code (AD8400.c) that comes with CCS and using this main code to test the digital Pot :
#include <16f870.h>
#device adc=8
#fuses HS,NOWDT,NOPROTECT,NOBROWNOUT,NOLVP
#use delay(clock=8388608)
#include <AD8400.c>
#include <flex_lcd_4x20_3.c>
int8 PotA=125;
int8 PotV=125;
#define VoltsMenos PIN_C7 // key V-
#define VoltsMais PIN_C0 // key V+
setup_adc_ports(AN0_AN1_AN3);
//setup_psp(PSP_DISABLED);
//setup_spi(FALSE);
setup_timer_0(RTCC_INTERNAL|RTCC_DIV_256);
setup_timer_1(T1_INTERNAL|T1_DIV_BY_1);
int_count=INTS_PER_SECOND;
enable_interrupts(INT_RTCC);
init_pots ();
lcd_init();
WHILE (TRUE) {
printf(lcd_putc,"\f Volts %LU\n Amps %U",PotV,PotA);
if (input(VoltsMenos)) {PotV=PotV-10;}
if ((PotV)<1) {PotV=1;}
if (input(VoltsMais)) {PotV=PotV+10;}
if ((PotV)>256) {PotV=256;}
set_pot (1, PotV);
delay_ms(250);
With all this , the digital Pot. simply don't change at all is OHM, it's stucked at middle scale (5k)
Can anybody help me ? |
Posted: Wed Nov 08, 2006 12:41 pm |
Read the AD8400 data sheet:
http://www.analog.com/UploadedFiles/Data_Sheets/248207866AD8400_2_3_c.pdf
It has a table on the right side of page 13, that shows the input value
for the Pot, and the corresponding resistance. The table shows values
from 0 to 255.
Look at your code. What value are you using as the maximum value ?
Compare it to the permissable value in the table.
Also, you have declared your Pot voltage variables as 8-bit (unsigned)
variables. What is the range of values that such as variable can hold ?
Look at your code. You are trying to put a value of 256 in those
variables. What is the actual value that the variable will be set to,
if you try to do this ? Answer these questions and you will solve your
problem. |
