I'm trying to get two pics to work together and I can only debug with one at a time. Is it possible to debug on two ICD-U at the same time?
Neutone
Posted: Mon Oct 30, 2006 12:02 pm
I would use a second PC if I really had to debug from both ends at the same time.
I suggest you put a scope on the communication link between the two and approach it from that angle. Make sure the master is sending the right request and then check that the slave is sending the correct reply.
