| Redpic
				| 4 x Serial EEPROM 24AA1025 512 Kbytes direct access driver. |
				|  Posted: Sun Oct 15, 2006 10:32 am |   |
				| This work is based in two previous works:
 The EX_EXTEE.C from CCS C examples directory and
 a post in this same Code Library section Driver Microchip 24AA512 512k I2C EEPROM by UFAnders
 This driver is capable for addresing from 0x0000 to 0x7FFFF, 0x8000 positions = 512 Kbytes.
 Driver:
  	  | Code: |  	  | ///////////////////////////////////////////////////////////////////////////////
 // 4 x EEPROM 24AA1025 Driver with absolute memory addressing
 #define EEDEBUG
 // device hardware address
 int8 const deviceAddress1 = 0b00000011; // #3
 int8 const deviceAddress2 = 0b00000010; // #2
 int8 const deviceAddress3 = 0b00000001; // #1
 int8 const deviceAddress4 = 0b00000000; // #0
 // baseAddress = 8 bits which mean ...
 // Fixed (4 bits)            -> 1010
 // EE internal Block (1 bit) -> 0 for 0000/FFFF, 1 for 10000/1FFFF
 // Dev Hard Address (2 bits) -> 00 or 01 or 10 or 11
 // R/W (1 bit)               -> 0 -> Write / 1 -> Read
 int8 const baseAddress24AA1025 = 0b10100000;
 // Aux Functions //////////////////////////////////////////////////////////////
 int1  menRelative2BankSelect(int32 memRelativeAddress){
 int1 returnBit=0;
 if(memRelativeAddress>(int32) 0xffff) returnBit = 1;
 return returnBit;
 int32 memAbsoluteAddress2menRelativeAddress(int8 deviceOrder, int32 memAddress){
 int32 returnInt32 = 0;
 switch(deviceOrder){
 case 1: returnInt32 = memAddress;
 case 2: returnInt32 = memAddress - 0x20000;
 case 3: returnInt32 = memAddress - 0x40000;
 case 4: returnInt32 = memAddress - 0x60000;
 return returnInt32;
 int8 memAbsoluteAddress2deviceOrder(int32 memAddress){
 int8  returnByte=0;
 if((memAddress>0x05ffff) && (memAddress < 0x080000)) returnByte=4;
 if((memAddress>0x03ffff) && (memAddress < 0x060000)) returnByte=3;
 if((memAddress>0x01ffff) && (memAddress < 0x040000)) returnByte=2;
 if((memAddress< 0x020000)) returnByte=1;
 return returnByte;
 int8 memAbsoluteAddress2deviceAddress(int32 memAddress){
 int8  deviceOrder=0, returnByte=0;
 deviceOrder = memAbsoluteAddress2deviceOrder(memAddress);
 case 0: returnByte = 0xff;
 case 1: returnByte = deviceAddress1;
 case 2: returnByte = deviceAddress2;
 case 3: returnByte = deviceAddress3;
 case 4: returnByte = deviceAddress4;
 return returnByte;
 // Main Functions /////////////////////////////////////////////////////////////
 void writeByte24AA1025(int32 memAddress, int8 data){
 int8  baseAddress;
 int8  deviceAddress;
 int8  deviceOrder=0;
 int32 memRelativeAddress;
 int8  bank=0;
 deviceAddress      = memAbsoluteAddress2deviceAddress(memAddress);
 memRelativeAddress = memAbsoluteAddress2menRelativeAddress(deviceOrder, memAddress);
 bank               = menRelative2BankSelect(memRelativeAddress);
 baseAddress        = baseAddress24AA1025 + (bank<<3)  + (deviceAddress<<1);
 #ifdef EEDEBUG
 printf("\r\n\nAbsolute Address: %LX Relative Address: %Lx Device: %u Bank: %u\r\n",memAddress,memRelativeAddress,deviceOrder,bank);
 i2c_start();
 i2c_write(baseAddress);
 i2c_write(memRelativeAddress>>8);
 i2c_write(memRelativeAddress);
 i2c_write(data);
 i2c_stop();
 delay_ms(5);
 int8 readByte24AA1025(int32 memAddress){
 int8  returnByte=0;
 int8  baseAddress;
 int8  deviceAddress;
 int8  deviceOrder=0;
 int8  bank=0;
 #ifdef EEDEBUG
 i2c_start();
 i2c_start();
 i2c_write(baseAddress|1);
 returnByte = i2c_read(0);
 i2c_stop();
 return returnByte;
 Adapted from example code EX_EXTEE.C, my own EEPROM_24AA1025x4.C:
 // EEPROM_24AA1025x4.C
 // based on EX_EXTEE.C example by CCS
 // and "Microchip 24AA512 512k I2C EEPROM driver" by UFAnders
 // in http://www.ccsinfo.com/forum/
 // by RedPic from http://picmania.garcia-cuervo.com
 // October 2006
 #include <18F4550.h>
 #use i2c(master, sda=PIN_B0, scl=PIN_B1)
 #include <input.c>
 #include <24AA1025x4.c>
 const char Version[]="1.0.F\0";
 // Main
 BYTE value, cmd;
 int32 address;
 int8  device;
 delay_ms(300);
 printf("\r\n\n");
 printf("[RRBOARD2] EEPROM Commander %s\r\n",version);
 printf("based on 24AA1025 Microchip Hardware\r\n");
 printf("\xa9 10.2006 by RedPic\r\n\n");
 do {
 do {
 printf("\r\nDo you Read or Write? : ");
 cmd=getc();
 cmd=toupper(cmd);
 putc(cmd);
 } while ( (cmd!='R') && (cmd!='W') );
 printf("\n\rGive me EEPROM internal absolute Address (24 bits) in hex : ");
 address = gethex();
 address = (address<<8)+gethex();
 device  = memAbsoluteAddress2deviceAddress(address);
 if(cmd=='R')
 printf("\r\nReturn Value (8 bits) in hex is : %X\r\n",readByte24AA1025(address));
 if(cmd=='W') {
 printf("\r\nEnter new value (8 bits) in hex : ");
 value = gethex();
 printf("\n\r");
 writeByte24AA1025(address, value );
 } while (TRUE);
 At last a executing view:
 More details (in spanish) in AUX Quad-EEPROM I2C 512 Kbytes de EEPROM con cuatro 24AA1025
