DS18S20 & DS18B20 Codes
Goto page 1, 2, 3, 4  Next
hansolo
PostPosted: Fri Oct 06, 2006 6:56 pm     Reply with quote
I find that the codes available in this site for DS18S20 & DS18B20 is a bit messy and complicated.
Below is the simple version of the codes which works. It also take care of negative temperature.
However, due to its simplicity, this will only work with one DS1820 connected to the 1-wire bus of the PIC. This code will not work with 2 or more DS1820 sharing the same 1-wire bus.
1wire.c
// (C) copyright 2003 j.d.sandoz / jds-pic !at! losdos.dyndns.org
// released under the GNU GENERAL PUBLIC LICENSE (GPL)
// refer to http://www.gnu.org/licenses/gpl.txt
// This program is free software; you can redistribute it and/or modify
// it under the terms of the GNU General Public License as published by
// the Free Software Foundation; either version 2 of the License, or
// (at your option) any later version.
// This program is distributed in the hope that it will be useful,
// but WITHOUT ANY WARRANTY; without even the implied warranty of
// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
// GNU General Public License for more details.
// You should have received a copy of the GNU General Public License
// along with this program; if not, write to the Free Software
// Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA
/***********************1Wire Class***********************/
/*Description: This class handles all communication */
/* between the processor and the 1wire */
/* sensors.
/*-------1-wire definitions-------*/
#define ONE_WIRE_PIN PIN_A0
/*******************1-wire communication functions********************/
/************onewire_reset*************************************************/
/*This function initiates the 1wire bus */
/*PARAMETERS: */
/*RETURNS: */
void onewire_reset()  // OK if just using a single permanently connected device
 output_low(ONE_WIRE_PIN);
 delay_us( 500 ); // pull 1-wire low for reset pulse
 output_float(ONE_WIRE_PIN); // float 1-wire high
 delay_us( 500 ); // wait-out remaining initialisation window.
/*********************** onewire_write() ********************************/
/*This function writes a byte to the sensor.*/
/*Parameters: byte - the byte to be written to the 1-wire */
/*Returns: */
void onewire_write(int data)
 int count;
 for (count=0; count<8; ++count)
  delay_us( 2 ); // pull 1-wire low to initiate write time-slot.
  output_bit(ONE_WIRE_PIN, shift_right(&data,1,0)); // set output bit on 1-wire
  delay_us( 60 ); // wait until end of write slot.
  output_float(ONE_WIRE_PIN); // set 1-wire high again,
  delay_us( 2 ); // for more than 1us minimum.
/*********************** read1wire() *********************************/
/*This function reads the 8 -bit data via the 1-wire sensor. */
/*Parameters: */
/*Returns: 8-bit (1-byte) data from sensor */
int onewire_read()
 int count, data;
  delay_us( 2 ); // pull 1-wire low to initiate read time-slot.
  output_float(ONE_WIRE_PIN); // now let 1-wire float high,
  delay_us( 8 ); // let device state stabilise,
  shift_right(&data,1,input(ONE_WIRE_PIN)); // and load result.
  delay_us( 120 ); // wait until end of read slot.
 return( data );
ds1820.c
float ds1820_read()
 int8 busy=0, temp1, temp2;
 signed int16 temp3;
 float result;
 onewire_reset();
 onewire_write(0xCC);
 onewire_write(0x44);
 while (busy == 0)
  busy = onewire_read();
 onewire_reset();
 onewire_write(0xBE);
 temp1 = onewire_read();
 temp2 = onewire_read();
 temp3 = make16(temp2, temp1);
 result = (float) temp3 / 2.0;   //Calculation for DS18S20 with 0.5 deg C resolution
// result = (float) temp3 / 16.0;  //Calculation for DS18B20 with 0.1 deg C resolution
 delay_ms(200);
 return(result);
Main code
#include <16F877A.h>
#device *=16
#device adc=8
#FUSES NOWDT, HS, PUT, NOPROTECT, NODEBUG, BROWNOUT, NOLVP, NOCPD, NOWRT
#include<1wire.c>
#include<lcd.c>
#include<ds1820.c>
float temperature;
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_OFF);
setup_psp(PSP_DISABLED);
setup_spi(FALSE);
setup_timer_1(T1_DISABLED);
setup_vref(VREF_LOW|-2);
lcd_putc("\f");
while (1)
  temperature = ds1820_read();
  lcd_gotoxy(1,1);
  printf(lcd_putc,"TEMP: %3.1f ", temperature);
  lcd_putc(223);
  lcd_putc("C    ");
  lcd_gotoxy(1,2);
  if(temperature >= 29.0)
   printf(lcd_putc,"Hot!    ");
  else if( temperature >= 20 && temperature < 29.0)
   printf(lcd_putc,"Comfort!");
   printf(lcd_putc,"Cold!   ");
jds-pic
Re: DS18S20 & DS18B20 Codes
PostPosted: Wed Oct 11, 2006 3:02 pm     Reply with quote
the entirety of the onewire driver code is copied directly from my post of Fri Jun 04, 2004 9:54 am EST -- a post which noted that the attached code is covered under the GPL.
http://ccsinfo.com/forum/viewtopic.php?t=19520
you can read about the GPL here
jds-pic
hansolo
PostPosted: Wed Oct 11, 2006 3:43 pm     Reply with quote
I posted the codes for sharing and I am not selling it.
I hope you do not mind.
Thanks.
jds-pic
PostPosted: Sun Oct 15, 2006 1:34 pm     Reply with quote
Thanks.
you must carry forward the GPL license and as well as the copyright(s) of the original author(s).
jds-pic
hansolo
PostPosted: Sun Oct 15, 2006 5:52 pm     Reply with quote
Thanks.
jds-pic
My mistake. I did not read the fine print.
I will amend it.
Sorry.
ulaska
PostPosted: Mon Jul 16, 2007 3:08 pm     Reply with quote
i tried this codes. it works OK.
i use 2x16 standard LCD, DS1280 and pic16f876a.
but it shows the temperatures like, 25.4 , 25.9, 27.4 ,
it increases or decreases 0.5 degree.
the resolution is 0.5 degree, but it isnt whole numbers or half (25.0, 25.5 etc.)
i think there are some problems with data types in ds1820_read() ?
but i cannot see any mistake, also i tried to add 0.1 to reach whole numbers Smile but doesnt works.
thank you.
p.s. i am new in PICs
scanan
0.1 degree resolution working code
PostPosted: Wed Jan 16, 2008 4:29 pm     Reply with quote
A working modification of hansolo - jds-pic codes.
Now it works fine.
// onewire library, for dallas onewire devices
// currently includes:
//   - generic onewire functions (init, readbyte, sendbyte, crc, etc.)
//   - ds1822 dallas-semi econo-thermometer
//Previously Posted in CCS thread from jds-pic
//Revision Made By SCanan Date: 26.06.2007
#include <16f628.h>
#device *=16
// internal osilator used
#FUSES NOWDT,INTRC, NOPUT, NOPROTECT, NOBROWNOUT, NOMCLR, NOLVP, NOCPD//for 16f628
#USE RS232(BAUD=9600, XMIT=PIN_B2, RCV=PIN_B1)
#include "1wire.c"
int8 tH,tL,Conf;
float ds1820_read()
signed int16 temp3;
float result;
onewire_reset();
delay_ms(200);
while (busy == 0)
onewire_reset();
tH=onewire_read();
tL=onewire_read();
Conf=onewire_read();
//result = (float) temp3 / 2.0;   // 0.5 deg C resolution
result = (float) temp3 / 16.0;  //0.1 deg C resolution
delay_ms(200);
return(result);
float temperature;
//for  10 bit resolution mod
onewire_write(0x4E);
onewire_write(125);
  onewire_write(-55); //this should be done for proper working of DS18B20
   onewire_write(127);
onewire_reset();
    onewire_write(0x48);
    delay_ms(15);
while (1)
printf("Temperature= %3.1f\n\r",temperature);
////// 1wire.c fontion //////
///// DS18b20 data pin connected to  pic16f628 B0 pin //////
/* sensors.
#define ONE_WIRE_PIN PIN_B0
/*Returns: */
int count;
/*Parameters: */
int onewire_read()
int count, data;
return( data );
mthornton
PostPosted: Thu Feb 21, 2008 3:56 pm     Reply with quote
The above ds18s20 code is nice & light & works, but I avoided the floating variables by integer-multiplying the result by 5 instead of dividing by 2 or 16. So my result is in DegC x 10. No problem, makes it even lighter. Just have to remember where to place the decimal-point in the display routine.
instead of the lines:
float ds1820_read()
float result
used :
signed int16 ds1820_read()
signed int16 result
result = temp3 * 5;
40inD
PostPosted: Sat Apr 26, 2008 1:08 pm     Reply with quote
Why i get 0.5 degree resolution in 18B20 when i do this:
meereck
PostPosted: Tue Apr 29, 2008 4:42 am     Reply with quote
hello, thanx for the source code. Works like a charm with both DS18S20 and B. Can any1 tell me what the maximal length of a cable between a PIC and the sensor can be?
cheers meereck
noobprogrammer
ds18s20
PostPosted: Tue May 20, 2008 7:07 pm     Reply with quote
cheers meereck
anybody has the schematic for this? thanks
muerte
View user's profile Send private message Visit poster's website ICQ Number
Re: ds18s20
PostPosted: Wed May 21, 2008 3:40 am     Reply with quote
Hi all,
noobprogrammer wrote:
cheers meereck
Schematic?
Look this:
connect DS18S20 to this pin (or another defined)
and DS18S20 data sheet from Maxim http://datasheets.maxim-ic.com/en/ds/DS18S20.pdf
Best regards,
muerte
meereck
Re: ds18s20
PostPosted: Wed May 21, 2008 7:08 am     Reply with quote
muerte wrote:
Hi all,
cheers meereck
Schematic?
Look this:
In addition, do not forget the pull-up resistor on the data line
PostPosted: Wed May 21, 2008 10:11 am     Reply with quote
http://www.ccsinfo.com/forum/viewtopic.php?t=34676
noobprogrammer
Re: ds18s20
PostPosted: Wed May 21, 2008 7:35 pm     Reply with quote
muerte wrote:
Hi all,
cheers meereck
Schematic?
Look this:
will this work for the pic18f452? and which ports and pins are connected to the LCD..sorrie im a noob..thanks for your help!
Page 1 of 4
