Mancio Guest
Debugger Problem |
Posted: Wed Aug 30, 2006 10:23 am |
Hallo everybody.
I've got some troubles with PIC18F4620.
When I try to enter in the debug mode, the system comiples the program but gives me this error:
"Could not start target: the target was not halted after reset. Check the target oscillator and MCLR"
Oscillator is internal and MCLR is not programmed to be used as MCLR.
The .h header is this:
#include <18F4620.h>
#device *=8
#device ICD=TRUE
#device adc=8
//#FUSES HS //High speed Osc (> 4mhz)
#FUSES BROWNOUT_SW //Brownout controlled by configuration bit in special file register
#FUSES BORV28 //Brownout reset at 2.8V
#FUSES PUT //Power Up Timer
#FUSES DEBUG //Debug mode for use with ICD
#FUSES LVP //Low Voltage Programming on B3(PIC16) or B5(PIC18)
#FUSES PBADEN //PORTB pins are configured as analog input channels on RESET
#FUSES LPT1OSC //Timer1 configured for low-power operation
//#FUSES MCLR //Master Clear pin enabled
Any idea?
thanck you |
Mancio Guest
Posted: Wed Aug 30, 2006 12:22 pm |
Previously I've read that topic and I've made as they said.
Still doesn't work.
Even with the fuse NOPUT.
Any other helpful idea? |
Posted: Wed Aug 30, 2006 1:27 pm |
Are you using Low Voltage programming mode ?
If not, you should change this fuse to NOLVP.
Leaving it as LVP can cause the PIC to lock up. |
Posted: Wed Aug 30, 2006 1:53 pm |
PCM programmer wrote: |
Reading in the CCS info I've seen that I was setting the LVP fuses instead of the NOLVP fuses.
Even making that change the problem still remain.
I've just finished to solder a new crystal and new capacitors but the debugger won't work.
Now I'm curious to know if there is someone that is using the PIC18F4620 in debug mode.
Waiting for some answer.
Thank you |
Posted: Wed Aug 30, 2006 2:14 pm |
Quote: | Oscillator is internal and MCLR is not programmed to be used as MCLR.
#FUSES INTRC_IO //Internal RC Osc, no CLKOUT |
Quote: | I've just finished to solder a new crystal and new capacitors but the debugger wont work. |
But in your first post, you said that the "oscillator is internal".
So soldering a new crystal and caps won't have any effect.
They're not used. Which mode are you really using ? INTRC_IO or HS ?
Also, the help file for the Microchip ICD2 (in MPLAB) says this, about
the 18Fxx20 chips:
Quote: | You must connect the AVDD and AVSS pins for the device to program. |
Posted: Wed Aug 30, 2006 2:21 pm |
First of all, I've started working with external clock.
With that advice, I switch to the internal clock just to be sure that everything was ok in the clock.
But the finally target is to have external clock so now I'm working with an external clock, setting #FUSES HS.
About the 18Fxx20 I will take a look on that.
Thank you for the help.
I will tell if everything was ok with AVDD and AVSS.
Stay tuned!!! |
Posted: Wed Aug 30, 2006 2:25 pm |
AVDD and AVSS are the pins for the power supply of the pic.
Unfortunately I've got them connected. And supplied when on programming. |
