dima2882
| SPI communication b/w master-slave PICs |
Posted: Wed Jul 13, 2005 12:34 pm |
Hi all,
I set up a PIC16F88 to act as an 8-bit parallel port expander linked through SPI to the master PIC18F458. The F88 can read 8-bit parallel data from parallel hardware, such as a CPLD, which is what I used this for. The Master selects the slave, gets its data, and sends it to the PC over the serial port. In this example, all this happens in an infinite loop, but of course that will be changed to suit the particular application.
***PIC16F88 SLAVE SPI DEVICE CODE***
| Code: | // Configure chip and compiler
#include "16F88.h"
#fuses INTRC_IO,NOWDT,NOPROTECT,NOBROWNOUT,NOLVP,NOMCLR
#zero_ram
#byte PORTA = 5
// PORTA is a variable mapped to the 8 physical pins of port A of the PIC
#define F88_CS PIN_B5
// Variables
int F88data;
// Configure pin direction
#use fast_io(A)
#use fast_io(B)
set_tris_a(0b11111111);
set_tris_b(0b00111010);
//PORTA = 0;
// Setup the SPI port
setup_spi(SPI_SLAVE | SPI_L_TO_H | SPI_CLK_DIV_4);
if(input(F88_CS) == 0)
F88data = PORTA;
spi_write(F88data);
delay_cycles(1);
return;
***PIC18F458 MASTER SPI DEVICE CODE***
#include "18F458.h"
#fuses EC_IO,NOWDT,NOPROTECT,NOBROWNOUT,NOLVP
#use delay(clock=16000000)
#use rs232(baud=57600, xmit=PIN_C6, rcv=PIN_C7)
#zero_ram
// Aliases for the pins used
#define F88_Servo_CS PIN_B5
#define F88_Aquire_Time 100
// Function prototypes
int readF88(void);
// Variables
int data;
// Configure pin direction, format is port X, pin 7 => pin 0; 1 is in, 0 is out
#use fast_io(A)
#use fast_io(B)
#use fast_io(C)
#use fast_io(D)
#use fast_io(E)
set_tris_a(0b00000000);
set_tris_b(0b10000000);
set_tris_c(0b10010000);
set_tris_d(0b00000000);
set_tris_e(0b00000000);
// Initially set all SPI chip selects to disable
output_high(F88_Servo_CS); // F88 CS is active low
setup_spi(SPI_MASTER | SPI_L_TO_H | SPI_CLK_DIV_16);
data = readF88();
printf("This is the data from F88: %d\n",data);
delay_us(100);
return;
int readF88(void)
int F88data;
output_low(F88_Servo_CS); // select the F88 to begin aquisition of data from external source
delay_us(F88_Aquire_Time); // wait the prescribed aquisition delay
F88data = spi_read(0); // aquire the data from the F88 by sending out a clock
output_high(F88_Servo_CS); // disable the F88
return F88data;
Neutone
Posted: Thu Jul 14, 2005 12:49 pm |
| You can buy a chip that does this in hardware. |
dima2882
Posted: Thu Jul 14, 2005 1:56 pm |
| Yes, that is true, in fact Microchip makes those also and it would be a better fit for this particular application. I was trying to go for the PIC-PIC communication angle, and SPI is a good fit for that. I2C would be even better, but there is a lot of I2C code in the forums already. |
Breno
Joined: 20 Jul 2006 Posts: 5 Location: Belo Horizonte, Brazil
Posted: Thu Jul 20, 2006 2:01 pm |
Hi dima, this code is actually using PIC's SPI hardware, isn't it?
In the "PIC16F88 SLAVE SPI DEVICE CODE" you used a variable called F88_CS, what variable is that? I understand it is the pin that correspond to the Chip Select but it should be defined before, right? And it is connected to the PIN_B5 of the PIC Master, right?
Did you test it? Does it work?
Thanks  |
dima2882
Posted: Fri Jul 21, 2006 6:39 am |
Breno,
Your're right, F88_CS does indeed need to be declared. It is a variable equivalent to a pin on the F88 chip, of your choice. When I pasted the code in, I removed some lines that were application-specific, and must have deleted this one by accident:
| Code: | | #define F88_CS PIN_B5 |
This needs to be placed at the top of the file, where the other preprocessor commands are located. The code listing has been subsequently fixed. Yes, this code worked, as I ripped it out of an application. |
