huma
| Interrupt problem |
Posted: Wed Jul 12, 2006 6:15 am |
hello,
I m trying to toggle the LED's connected to PORTD of PIC 16F877 based on interrupt from RB0/INT pin when a push button is pressed.
I am simulating this program in Proteus VSM,but i m getting no result.Nothing happens when i push the button and it is also not showing the normal sequence i.e in While loop.
Is there any problem with my code?
I have checked the other topics related to RB0/INT interupt,but everything seems to me ok,i might have missed something and i m not getting whats that.
Please tell me i shall be very thankful to you.
| Code: | /*
The program toggles the LED's on/off connected on PORTD when push button is pressed,
causing interrupt on RB0/INT pin
#include "16f877.h"
#fuses XT,NOWDT
#use delay(clock = 4000000)
//---------function prototypes
#int_ext
void external_int_isr(void);
//---------global variables---
char value = 0xbb;
set_tris_d(0x00); //LED's connected to portD ,make it output port
set_tris_b(0x01); //set RB0 = 1
port_b_pullups(TRUE);
ext_int_edge(H_TO_L);
enable_interrupts(INT_EXT);
while(true)
output_d(value); //output a sequnce on PORTD
value = ~value; //complement the sequence
clear_interrupt(int_ext); //clear the INTF flag bit
| Re: Interrupt problem |
Posted: Wed Jul 12, 2006 7:03 am |
Comments in the code.
| Code: | /*
button is pressed, causing interrupt on RB0/INT pin
#include "16f877.h"
#fuses XT,NOWDT
//#int_ext
//--- Do _not_ prototype with the interrupt definition - this _must_ be
//--- on the real routine.
char value = 0xbb;
//set_tris_d(0x00); //LED's connected to portD ,make it
// output port
//set_tris_b(0x01); //set RB0 = 1
//--- The two TRIS statements, actually do nothing. Since you are in
//--- 'standard_io' mode, the compiler will override the TRIS, as soon
//--- as you perform IO. Does not matter, but if you want manual control
//--- of TRIS, select 'fast_io' mode for the ports.
while(true)
#int_ext
//You _must_ have the interrupt defintion line here
//clear_interrupt(int_ext); //clear the INTF flag bit
//Do not do this. The compiler already does it for you
The problem that is stopping it working, is that there isn't a real interrupt handler, because of the wrong placement of the #int definition.
huma
| Thanks |
Posted: Wed Jul 12, 2006 12:36 pm |
thanks a lot Ttelmah.it worked i just did as u said.
and i also come to know whts this Standard and fast io are.Thanks. |
