Problem
huma
Problem
PostPosted: Tue Jul 11, 2006 8:27 am     Reply with quote
hello ,
i want to turn on/off the LED after 5 sec using delay.
i write the following code .but its not changing the value on RD0,plz tell me where is the problem.Its my first program in C for PIC
///////////////////////code////////////////////////////
#include "16f877.h"
#fuses XT,NOWDT
#use delay(clock = 4000000)
void delay_seconds(int n)
for(;n!=0 ;n--)
set_tris_d(0x00);
while(true)
output_high(pin_D0);
delay_seconds(5);
output_low(pin_D0);
///////////////////////////////////////////////// Question
PostPosted: Tue Jul 11, 2006 8:50 am     Reply with quote
A classic error.
After setting the output_low a delay is missing, on the next instruction the processor will call ouput_high again. Too fast for your eye to see.
 while(true)
  delay_seconds(5);
  output_low(pin_D0);
  delay_seconds(5);    // Add this line
treitmey
PostPosted: Tue Jul 11, 2006 8:51 am     Reply with quote
Please post code using the code button.
You messed up in the while loop. If you follow the logic around
high
delay
low
high //you don't delay before this and you will not see the previous low
delay
low
high
...beat me by a min. :o)
huma
PostPosted: Wed Jul 12, 2006 12:53 am     Reply with quote
Thanks a lot ckielstra and treitmey.
its running well now.
Thanks once again.
