Mike Kress Guest
| 18F452 4xPLL |
Posted: Fri Jul 11, 2003 8:30 am |
I recently started using the 18F452 for a design I'm working on. This part has the ability to run at 40MHz using a 10MHz source, along with the 4xPLL enabled. How do I setup the #use delay at the top of my file? Would I use 40 or 10?
Mike
___________________________
Original Post ID: 144515878 |
john cutler
Joined: 06 Sep 2003 Posts: 82 Location: Hot Tub, California
| Re: 18F452 4xPLL |
Posted: Fri Jul 11, 2003 8:48 am |
:=I recently started using the 18F452 for a design I'm working on. This part has the ability to run at 40MHz using a 10MHz source, along with the 4xPLL enabled. How do I setup the #use delay at the top of my file? Would I use 40 or 10?
:=Thanks
:=Mike
#use delay(clock= 40000000)
Original Post ID: 144515880 |
R.J.Hamlett Guest
| Re: 18F452 4xPLL |
Posted: Fri Jul 11, 2003 9:17 am |
:=Thanks
:=Mike
A 'caveat'. You say '10MHz source'. The PLL, is _very_ critical about the input drive voltage. If the drive swings too far, you can get some very 'odd' behaviours, with the chip running at strange frequencies. Even operating off a crystal, it becomes vital to have a series resistor in a lot of cases to get good stable operation. If running off an external clock input, you may well need to attenuate the signal a little to make the PLL work. If you find the circuit is behaving strangely, you may need to look at this...
Original Post ID: 144515881 |
Ted Larson Guest
| Re: 18F452 4xPLL |
Posted: Fri Jul 11, 2003 1:42 pm |
:=:=I recently started using the 18F452 for a design I'm working on. This part has the ability to run at 40MHz using a 10MHz source, along with the 4xPLL enabled. How do I setup the #use delay at the top of my file? Would I use 40 or 10?
:=:=Thanks
:=:=Mike
:=#use delay(clock= 40000000)
Also...just to add to this...you will need to make sure your FUSES is correct for a PLL clock.
#fuses H4
- Ted
Original Post ID: 144515888 |
