i2c and wdt reset
Fabri
i2c and wdt reset
PostPosted: Thu Mar 30, 2006 10:09 am     Reply with quote
Hi everybody,
I use i2c bus as below:
// Configura bus
#use I2C(MASTER,sda=PIN_C4,scl=PIN_C3,restart_wdt,FORCE_HW,fast)
During i2c bus inizialization there is a reset from watchdog.
Why doesn't restart_wdt as option of #use i2c work ?
Thanks for support
PostPosted: Thu Mar 30, 2006 12:52 pm     Reply with quote
Post your compiler version and post a short, compilable test program
that demonstrates the problem and that has less than 20 lines in it,
if possible.
PostPosted: Thu Mar 30, 2006 12:54 pm     Reply with quote
The Restart_WDT option only says that it will restart the WDT while waiting in a I2C read. Not during initialization. You have to do that yourself.
Fabri
PostPosted: Fri Mar 31, 2006 2:30 am     Reply with quote
I found a problem in other part of project.
The routine i2c bus work right also with watchdog.
Thanks for support
