How to calculate process time?
No_Fear
PostPosted: Mon Jun 30, 2003 1:43 pm     Reply with quote
Hi there,
I wrote a firmware for pic but i cant calculate right time.I need to send a string to computer via COM2 *10* times per second.But i cant find (or fix it to send 10 tps) the solution.
So can you advice me how to do it? Should i calculate all calculation times of all commands ???
No_Fear
#include <16F877A.h>
#include <string.h>
#fuses XT, NOWDT, PROTECT, BROWNOUT, PUT, NOLVP
#use rs232(baud=9600,xmit=PIN_C6,rcv=PIN_C7)
int v1,v2,v3,v4,v5,v6;
char ON;
setup_adc_ports(ALL_ANALOG);
setup_psp(PSP_DISABLED);
setup_spi(FALSE);
setup_counters(RTCC_INTERNAL,RTCC_DIV_2);
setup_timer_1(T1_DISABLED);
setup_vref(FALSE);
set_tris_d(0x00);
ON = 1;
printf("3A75D5FA\r\n");
while (1)
set_adc_channel( 0 );delay_us(10);v1 = read_adc();
set_adc_channel( 1 );delay_us(10);v2 = read_adc();
set_adc_channel( 4 );delay_us(10);v3 = read_adc();
set_adc_channel( 5 );delay_us(10);v4 = read_adc();
set_adc_channel( 6 );delay_us(10);v5 = read_adc();
set_adc_channel( 7 );delay_us(10);v6 = read_adc();
printf("Value:\%2X/\%2X/\%2X/\%2X/\%2X/\%2X!",v1,v2,v3,v4,v5,v6);
if (ON == 1) {output_high(PIN_D2);ON = 0;} else {output_low(PIN_D2);ON = 1;}
v1=0;v2=0;v3=0;v4=0;v5=0;v6=0;
delay_ms(????); //I know i should change this to rite value
// but how to do this? What is the best value for 10 times per
//second????
___________________________
Original Post ID: 144515654
Neutone
Re: How to calculate process time?
PostPosted: Mon Jun 30, 2003 2:07 pm     Reply with quote
<font face="Courier New" size=-1>:=Hi there,
:=I wrote a firmware for pic but i cant calculate right time.I need to send a string to computer via COM2 *10* times per second.But i cant find (or fix it to send 10 tps) the solution.
:=So can you advice me how to do it? Should i calculate all calculation times of all commands ???
:=No_Fear
:=#include <16F877A.h>
:=#include <string.h>
:=#use delay(clock=4000000)
:=#fuses XT, NOWDT, PROTECT, BROWNOUT, PUT, NOLVP
:=#use rs232(baud=9600,xmit=PIN_C6,rcv=PIN_C7)
:=void main() {
:=int v1,v2,v3,v4,v5,v6;
:=char ON;
:= setup_adc_ports(ALL_ANALOG);
:= setup_adc(ADC_CLOCK_INTERNAL);
:= setup_psp(PSP_DISABLED);
:= setup_spi(FALSE);
:= setup_counters(RTCC_INTERNAL,RTCC_DIV_2);
:= setup_timer_1(T1_DISABLED);
:= setup_timer_2(T2_DISABLED,0,1);
:= setup_comparator(NC_NC_NC_NC);
:= setup_vref(FALSE);
:= set_tris_d(0x00);
:= ON = 1;
:=printf("3A75D5FA\r\n");
:=while (1)
:= set_adc_channel( 0 );delay_us(10);v1 = read_adc();
:= set_adc_channel( 1 );delay_us(10);v2 = read_adc();
:= set_adc_channel( 4 );delay_us(10);v3 = read_adc();
:= set_adc_channel( 5 );delay_us(10);v4 = read_adc();
:= set_adc_channel( 6 );delay_us(10);v5 = read_adc();
:= set_adc_channel( 7 );delay_us(10);v6 = read_adc();
:= printf("Value:\%2X/\%2X/\%2X/\%2X/\%2X/\%2X!",v1,v2,v3,v4,v5,v6);
:= if (ON == 1) {output_high(PIN_D2);ON = 0;} else {output_low(PIN_D2);ON = 1;}
:= v1=0;v2=0;v3=0;v4=0;v5=0;v6=0;
:= delay_ms(????); //I know i should change this to rite value
:=// but how to do this? What is the best value for 10 times per
:=//second????
First assign the location of Timer_Interupt_Flag
#bit Timer_Interupt_Flag = xxx.x
Forget about using delay_mS. Computation times can vary. Setup one of the timers to overflow every .1 seconds. The project wizard is good way to solve timer settings. Then where you want to put delay_mS put this
while(!Timer_Interupt_Flag);
Timer_Interupt_Flag=0;
This will gate your program on a 100mS time base.</font>
Original Post ID: 144515655
No_Fear
PostPosted: Mon Jun 30, 2003 2:47 pm     Reply with quote
Thanks for your reply, but i couldnt see Timer_Interrupt_Flag in ccs compiler?? Is it TOIF? If so i havent got any idea how it works?Could you show it in my code please? I will search how to use TOIF on code.
By the way sometimes pic sends garbage characters with this code it send 0xUF for example.I check all of things which is described on CCS Manual Page 185 everything is ok but still sends garbage characters (especially adc input changes fastly)
No_Fear
:=<font face="Courier New" size=-1>:=Hi there,
:=:=I wrote a firmware for pic but i cant calculate right time.I need to send a string to computer via COM2 *10* times per second.But i cant find (or fix it to send 10 tps) the solution.
:=:=So can you advice me how to do it? Should i calculate all calculation times of all commands ???
:=:=No_Fear
:=:=#include <16F877A.h>
:=:=#include <string.h>
:=:=#use delay(clock=4000000)
:=:=#fuses XT, NOWDT, PROTECT, BROWNOUT, PUT, NOLVP
:=:=#use rs232(baud=9600,xmit=PIN_C6,rcv=PIN_C7)
:=:=void main() {
:=:=int v1,v2,v3,v4,v5,v6;
:=:=char ON;
:=:= setup_adc_ports(ALL_ANALOG);
:=:= setup_adc(ADC_CLOCK_INTERNAL);
:=:= setup_psp(PSP_DISABLED);
:=:= setup_spi(FALSE);
:=:= setup_counters(RTCC_INTERNAL,RTCC_DIV_2);
:=:= setup_timer_1(T1_DISABLED);
:=:= setup_timer_2(T2_DISABLED,0,1);
:=:= setup_comparator(NC_NC_NC_NC);
:=:= setup_vref(FALSE);
:=:= set_tris_d(0x00);
:=:= ON = 1;
:=:=printf("3A75D5FA\r\n");
:=:=while (1)
:=:= set_adc_channel( 0 );delay_us(10);v1 = read_adc();
:=:= set_adc_channel( 1 );delay_us(10);v2 = read_adc();
:=:= set_adc_channel( 4 );delay_us(10);v3 = read_adc();
:=:= set_adc_channel( 5 );delay_us(10);v4 = read_adc();
:=:= set_adc_channel( 6 );delay_us(10);v5 = read_adc();
:=:= set_adc_channel( 7 );delay_us(10);v6 = read_adc();
:=:= printf("Value:\%2X/\%2X/\%2X/\%2X/\%2X/\%2X!",v1,v2,v3,v4,v5,v6);
:=:= if (ON == 1) {output_high(PIN_D2);ON = 0;} else {output_low(PIN_D2);ON = 1;}
:=:= v1=0;v2=0;v3=0;v4=0;v5=0;v6=0;
:=:= delay_ms(????); //I know i should change this to rite value
:=:=// but how to do this? What is the best value for 10 times per
:=:=//second????
:=First assign the location of Timer_Interupt_Flag
:=#bit Timer_Interupt_Flag = xxx.x
:=Forget about using delay_mS. Computation times can vary. Setup one of the timers to overflow every .1 seconds. The project wizard is good way to solve timer settings. Then where you want to put delay_mS put this
:=while(!Timer_Interupt_Flag);
:=Timer_Interupt_Flag=0;
:=This will gate your program on a 100mS time base.</font>
Original Post ID: 144515657
Neutone
PostPosted: Mon Jun 30, 2003 3:13 pm     Reply with quote
<font face="Courier New" size=-1>:=Thanks for your reply, but i couldnt see Timer_Interrupt_Flag in ccs compiler?? Is it TOIF? If so i havent got any idea how it works?Could you show it in my code please? I will search how to use TOIF on code.
:=By the way sometimes pic sends garbage characters with this code it send 0xUF for example.I check all of things which is described on CCS Manual Page 185 everything is ok but still sends garbage characters (especially adc input changes fastly)
:=No_Fear
:=:=<font face="Courier New" size=-1>:=Hi there,
:=:=:=I wrote a firmware for pic but i cant calculate right time.I need to send a string to computer via COM2 *10* times per second.But i cant find (or fix it to send 10 tps) the solution.
:=:=:=So can you advice me how to do it? Should i calculate all calculation times of all commands ???
:=:=:=No_Fear
:=:=:=#include <16F877A.h>
:=:=:=#include <string.h>
:=:=:=#use delay(clock=4000000)
:=:=:=#fuses XT, NOWDT, PROTECT, BROWNOUT, PUT, NOLVP
:=:=:=#use rs232(baud=9600,xmit=PIN_C6,rcv=PIN_C7)
:=:=:=void main() {
:=:=:=int v1,v2,v3,v4,v5,v6;
:=:=:=char ON;
:=:=:= setup_adc_ports(ALL_ANALOG);
:=:=:= setup_adc(ADC_CLOCK_INTERNAL);
:=:=:= setup_psp(PSP_DISABLED);
:=:=:= setup_spi(FALSE);
:=:=:= setup_counters(RTCC_INTERNAL,RTCC_DIV_2);
:=:=:= setup_timer_1(T1_DISABLED);
:=:=:= setup_timer_2(T2_DISABLED,0,1);
:=:=:= setup_comparator(NC_NC_NC_NC);
:=:=:= setup_vref(FALSE);
:=:=:= set_tris_d(0x00);
:=:=:= ON = 1;
:=:=:=printf("3A75D5FA\r\n");
:=:=:=while (1)
:=:=:= set_adc_channel( 0 );delay_us(10);v1 = read_adc();
:=:=:= set_adc_channel( 1 );delay_us(10);v2 = read_adc();
:=:=:= set_adc_channel( 4 );delay_us(10);v3 = read_adc();
:=:=:= set_adc_channel( 5 );delay_us(10);v4 = read_adc();
:=:=:= set_adc_channel( 6 );delay_us(10);v5 = read_adc();
:=:=:= set_adc_channel( 7 );delay_us(10);v6 = read_adc();
:=:=:= printf("Value:\%2X/\%2X/\%2X/\%2X/\%2X/\%2X!",v1,v2,v3,v4,v5,v6);
:=:=:= if (ON == 1) {output_high(PIN_D2);ON = 0;} else {output_low(PIN_D2);ON = 1;}
:=:=:= v1=0;v2=0;v3=0;v4=0;v5=0;v6=0;
:=:=:= delay_ms(????); //I know i should change this to rite value
:=:=:=// but how to do this? What is the best value for 10 times per
:=:=:=//second????
:=:=First assign the location of Timer_Interupt_Flag
:=:=#bit Timer_Interupt_Flag = xxx.x
:=:=Forget about using delay_mS. Computation times can vary. Setup one of the timers to overflow every .1 seconds. The project wizard is good way to solve timer settings. Then where you want to put delay_mS put this
:=:=while(!Timer_Interupt_Flag);
:=:=Timer_Interupt_Flag=0;
:=:=This will gate your program on a 100mS time base.</font>
Look at the chart on page 56 of the data sheet. TMR1IF is the bit you should watch for. It means the timer has overflowed. Thats why you have to clear it when it overflows.
#bit Timer1_Interupt_Flag = 0C.0
setup_timer_1(T1_INTERNAL|T1_DIV_BY_2);
This will work on a time base of 131mS as timer 1 is set up with a crystle of 4mHz.
Right after clearing the overflow this
set_timer1(15508);
Will advance the counter and make it just right on the .1S interval.
</font>
Original Post ID: 144515658
No_Fear
PostPosted: Mon Jun 30, 2003 3:59 pm     Reply with quote
I noticed that i told my problem wrongly.Because I only want to send string in every 100 ms to pc.So i want device to read adc channels continously but send "printf ........" in every 100 ms.I couldnt compile the line
#bit Timer1_Interupt_Flag = 0C.0 By the way, i told that i have no experience with ccs c compiler+handle interrupts, i cant understand it.So can you please show it with real code instead of pseudo code? Or better could you edit my code? I'm sorry i shouldnt want you to do it but i'm very bad at handling interrupts.
No_Fear
:=<font face="Courier New" size=-1>:=Thanks for your reply, but i couldnt see Timer_Interrupt_Flag in ccs compiler?? Is it TOIF? If so i havent got any idea how it works?Could you show it in my code please? I will search how to use TOIF on code.
:=:=By the way sometimes pic sends garbage characters with this code it send 0xUF for example.I check all of things which is described on CCS Manual Page 185 everything is ok but still sends garbage characters (especially adc input changes fastly)
:=:=No_Fear
:=:=:=<font face="Courier New" size=-1>:=Hi there,
:=:=:=:=I wrote a firmware for pic but i cant calculate right time.I need to send a string to computer via COM2 *10* times per second.But i cant find (or fix it to send 10 tps) the solution.
:=:=:=:=So can you advice me how to do it? Should i calculate all calculation times of all commands ???
:=:=:=:=No_Fear
:=:=:=:=#include <16F877A.h>
:=:=:=:=#include <string.h>
:=:=:=:=#use delay(clock=4000000)
:=:=:=:=#fuses XT, NOWDT, PROTECT, BROWNOUT, PUT, NOLVP
:=:=:=:=#use rs232(baud=9600,xmit=PIN_C6,rcv=PIN_C7)
:=:=:=:=void main() {
:=:=:=:=int v1,v2,v3,v4,v5,v6;
:=:=:=:=char ON;
:=:=:=:= setup_adc_ports(ALL_ANALOG);
:=:=:=:= setup_adc(ADC_CLOCK_INTERNAL);
:=:=:=:= setup_psp(PSP_DISABLED);
:=:=:=:= setup_spi(FALSE);
:=:=:=:= setup_counters(RTCC_INTERNAL,RTCC_DIV_2);
:=:=:=:= setup_timer_1(T1_DISABLED);
:=:=:=:= setup_timer_2(T2_DISABLED,0,1);
:=:=:=:= setup_comparator(NC_NC_NC_NC);
:=:=:=:= setup_vref(FALSE);
:=:=:=:= set_tris_d(0x00);
:=:=:=:= ON = 1;
:=:=:=:=printf("3A75D5FA\r\n");
:=:=:=:=while (1)
:=:=:=:= set_adc_channel( 0 );delay_us(10);v1 = read_adc();
:=:=:=:= set_adc_channel( 1 );delay_us(10);v2 = read_adc();
:=:=:=:= set_adc_channel( 4 );delay_us(10);v3 = read_adc();
:=:=:=:= set_adc_channel( 5 );delay_us(10);v4 = read_adc();
:=:=:=:= set_adc_channel( 6 );delay_us(10);v5 = read_adc();
:=:=:=:= set_adc_channel( 7 );delay_us(10);v6 = read_adc();
:=:=:=:= printf("Value:\%2X/\%2X/\%2X/\%2X/\%2X/\%2X!",v1,v2,v3,v4,v5,v6);
:=:=:=:= if (ON == 1) {output_high(PIN_D2);ON = 0;} else {output_low(PIN_D2);ON = 1;}
:=:=:=:= v1=0;v2=0;v3=0;v4=0;v5=0;v6=0;
:=:=:=:= delay_ms(????); //I know i should change this to rite value
:=:=:=:=// but how to do this? What is the best value for 10 times per
:=:=:=:=//second????
:=:=:=First assign the location of Timer_Interupt_Flag
:=:=:=#bit Timer_Interupt_Flag = xxx.x
:=:=:=Forget about using delay_mS. Computation times can vary. Setup one of the timers to overflow every .1 seconds. The project wizard is good way to solve timer settings. Then where you want to put delay_mS put this
:=:=:=while(!Timer_Interupt_Flag);
:=:=:=Timer_Interupt_Flag=0;
:=:=:=This will gate your program on a 100mS time base.</font>
:=Look at the chart on page 56 of the data sheet. TMR1IF is the bit you should watch for. It means the timer has overflowed. Thats why you have to clear it when it overflows.
:=#bit Timer1_Interupt_Flag = 0C.0
:=setup_timer_1(T1_INTERNAL|T1_DIV_BY_2);
:=This will work on a time base of 131mS as timer 1 is set up with a crystle of 4mHz.
:=Right after clearing the overflow this
:=set_timer1(15508);
:=Will advance the counter and make it just right on the .1S interval.
:=</font>
Original Post ID: 144515665
Neutone
PostPosted: Tue Jul 01, 2003 8:21 am     Reply with quote
This should work
Fear
#include
#bit Timer1_Interupt_Flag = 0x0C.0
char ON;
setup_spi(FALSE);
setup_vref(FALSE);
set_tris_d(0x00);
ON = 1;
while (1)
while(!Timer1_Interupt_Flag );
Timer1_Interupt_Flag =0;
set_timer1(15508);
Original Post ID: 144515682
No_Fear
PostPosted: Fri Jul 04, 2003 2:25 pm     Reply with quote
:=This should work
:=Fear
:=#include
Excuse me, i am a bit late to thank you for your help. :)
No_Fear
:=#bit Timer1_Interupt_Flag = 0x0C.0
:=void main() {
:=char ON;
:=setup_adc_ports(ALL_ANALOG);
:=setup_adc(ADC_CLOCK_INTERNAL);
:=setup_psp(PSP_DISABLED);
:=setup_spi(FALSE);
:=setup_counters(RTCC_INTERNAL,RTCC_DIV_2);
:=setup_timer_2(T2_DISABLED,0,1);
:=setup_comparator(NC_NC_NC_NC);
:=setup_vref(FALSE);
:=set_tris_d(0x00);
:=ON = 1;
:=while (1)
:=set_adc_channel( 0 );delay_us(10);v1 = read_adc();
:=set_adc_channel( 1 );delay_us(10);v2 = read_adc();
:=set_adc_channel( 4 );delay_us(10);v3 = read_adc();
:=set_adc_channel( 5 );delay_us(10);v4 = read_adc();
:=set_adc_channel( 6 );delay_us(10);v5 = read_adc();
:=set_adc_channel( 7 );delay_us(10);v6 = read_adc();
:=while(!Timer1_Interupt_Flag );
:=Timer1_Interupt_Flag =0;
:=printf("Value:\%2X/\%2X/\%2X/\%2X/\%2X/\%2X!",v1,v2,v3,v4,v5,v6);
:=if (ON == 1) {output_high(PIN_D2);ON = 0;} else {output_low(PIN_D2);ON = 1;}
:=v1=0;v2=0;v3=0;v4=0;v5=0;v6=0;
Original Post ID: 144515742
