sonicdeejay
| Working LCD.c driver for Samsung based chip |
Posted: Thu Feb 09, 2006 11:13 am |
I am using PIC18F2525 with a 2x16 matric LCD based on S6A0069 and works well so far...(thx to PCM programmer for his helps)
This is my lcdmod.c
struct lcd_pin_map { // This structure is overlayed
BOOLEAN enable; // on to an I/O port to gain
BOOLEAN rs; // access to the LCD pins.
BOOLEAN rw; // The bits are allocated from
BOOLEAN unused; // low order up. ENABLE will
int data : 4; // be pin B0.
} lcd;
#if defined(__PCH__)
#if defined use_portb_lcd
#byte lcd = 0xF81 // This puts the entire structure
#else
#byte lcd = 0xF83 // This puts the entire structure
#else
#byte lcd = 6 // on to port B (at address 6)
#else
#byte lcd = 8 // on to port D (at address 8)
#define set_tris_lcd(x) set_tris_b(x)
#else
#define set_tris_lcd(x) set_tris_d(x)
#define lcd_type 2 // 0=5x7, 1=5x10, 2=2 lines
#define lcd_line_two 0x40 // LCD RAM address for the second line
BYTE const LCD_INIT_STRING[4] = {0x20 | (lcd_type << 2), 0xc, 1, 6};
// These bytes need to be sent to the LCD
// to start it up.
// The following are used for setting
// the I/O port direction register.
struct lcd_pin_map const LCD_WRITE = {0,0,0,0,0}; // For write mode all pins are out
struct lcd_pin_map const LCD_READ = {0,0,0,0,15}; // For read mode data pins are in
BYTE lcd_read_byte() {
BYTE low,high;
set_tris_lcd(LCD_READ);
lcd.rw = 1;
delay_cycles(1);
lcd.enable = 1;
delay_cycles(1);
high = lcd.data;
lcd.enable = 0;
delay_cycles(1);
lcd.enable = 1;
delay_us(1);
low = lcd.data;
lcd.enable = 0;
set_tris_lcd(LCD_WRITE);
return( (high<<4) | low);
//Modified code to fit S6A0069 chip based LCD
void lcd_send_nibble( BYTE n ) {
lcd.data = n;
delay_cycles(1);
lcd.enable = 1;
delay_us(2);
lcd.enable = 0;
//Orignal LCD format
/*void lcd_send_nibble( BYTE n ) {
lcd.data = n;
delay_cycles(1);
lcd.enable = 1;
delay_us(2);
lcd.enable = 0;
void lcd_send_byte( BYTE address, BYTE n ) {
lcd.rs = 0;
while ( bit_test(lcd_read_byte(),7) ) ;
lcd.rs = address;
delay_cycles(1);
lcd.rw = 0;
delay_cycles(1);
lcd.enable = 0;
lcd_send_nibble(n >> 4);
lcd_send_nibble(n & 0xf);
void lcd_init() {
lcd.rs = 0;
lcd.rw = 0;
lcd.enable = 0;
delay_ms(30);
lcd_send_nibble(0x02);
delay_us(1);
delay_us(1);
lcd_send_nibble(0x0C);
delay_us(45);
lcd_send_nibble(0x00);
delay_us(1);
lcd_send_nibble(0x0F);
delay_us(45);
delay_us(1);
lcd_send_nibble(0x01);
delay_ms(2);
delay_us(1);
lcd_send_nibble(0x06);
delay_ms(2);
void lcd_init() {
BYTE i;
lcd.rs = 0;
lcd.rw = 0;
lcd.enable = 0;
delay_ms(15);
for(i=1;i<=3;++i) {
lcd_send_nibble(3);
delay_ms(5);
lcd_send_nibble(2);
for(i=0;i<=3;++i)
lcd_send_byte(0,LCD_INIT_STRING[i]);
void lcd_gotoxy( BYTE x, BYTE y) {
BYTE address;
if(y!=1)
address=lcd_line_two;
address=0;
address+=x-1;
lcd_send_byte(0,0x80|address);
void lcd_putc( char c) {
switch (c) {
case '\f' : lcd_send_byte(0,1);
delay_ms(2);
case '\n' : lcd_gotoxy(1,2); break;
case '\b' : lcd_send_byte(0,0x10); break;
default : lcd_send_byte(1,c); break;
sonicdeejay
Posted: Mon Feb 20, 2006 7:19 pm |
In my main program..
| Code: | #include <18F2525.h> // Call for PIC18F2525 Driver
#device ICD=TRUE
#device ADC=10 // Use 10bits ADC
#use delay(clock=16000000) // 16Mhz Crystal is Used
#use rs232(baud=9600, parity=N, xmit=PIN_C6, rcv=PIN_C7, bits=8) // RS232 Configuration for COM Port Communication
#define use_portb_lcd TRUE // Using Port B for LCD Display
#include <lcdmod.c> // This is Where I call for lcdmod.c
#byte PORTB = 0xf81
#byte PORTC = 0xf82
#include <stdlib.h>
#include <math.h> |
sonicdeejay
Posted: Sun Feb 26, 2006 6:29 am |
My physical connection is ...
| Code: | LCD - PIC18F2525
VSS - GND
VDD - 5V
V0 - O/P from variable ressitor (20KOhm)
R/S - PORT_B1
R/W - PORT_B2
E - PORT_B0
DB0 - NC (not connected)
DB1 - NC (not connected)
DB2 - NC (not connected)
DB3 - NC (not connected)
DB4 - PORT_B4
DB5 - PORT_B5
DB6 - PORT_B6
DB7 - PORT_B7 |
