Problem when try to program 18F2620
Post new topic   Reply to topic    CCS Forum Index -> CCS ICD / Mach X / Load-n-Go
radhios
PostPosted: Wed Feb 22, 2006 8:58 pm     Reply with quote
Hi all,
Currently I using a CCS PCWH Compiler version 3.227. I start my development with the device 18F252 and use the PicStar Plus and MPLAB to burn devices. But my project grow and I need to move to 18F2620, at this point start my problem. I can't program the new devices!!!! I upgrade all that I can update; Mplab and firmware to last version, but the problem persist. The programer said that has problem when verify the memory. I change all config settings that I can modify without success.
Can anybody help me????
Thanx!!!
Bob
PostPosted: Wed Feb 22, 2006 11:17 pm     Reply with quote
The answer is on the same Microchip forum that you posted on:
http://forum.microchip.com/tm.aspx?m=106833&mpage=1&key=18F2620&#107595
How to use the search engine to find answers on the Microchip forum:
http://www.ccsinfo.com/forum/viewtopic.php?t=25935
http://www.ccsinfo.com/forum/viewtopic.php?t=26043
radhios
Re: Problem when try to program 18F2620
PostPosted: Thu Feb 23, 2006 7:04 am     Reply with quote
When I try to find a post for my problem I use a wrong search string and I canīt found right post. Thanks for your assist!!!
Thanks a lot!!!
Bob
Post new topic   Reply to topic    CCS Forum Index -> CCS ICD / Mach X / Load-n-Go All times are GMT - 6 Hours
