Mark
| More flexible LCD driver file can be used for PICDEM2 |
Posted: Tue Aug 10, 2004 8:01 am |
Here is a driver file that will allow you to move the control and data lines around a bit. I modified the CCS for someone a while back and here it is.
//// LCDD.C ////
//// Driver for common LCD modules ////
//// lcd_init() Must be called before any other function. ////
//// lcd_putc(c) Will display c on the next position of the LCD. ////
//// The following have special meaning: ////
//// \f Clear display ////
//// \n Go to start of second line ////
//// \b Move back one position ////
//// lcd_gotoxy(x,y) Set write position on LCD (upper left is 1,1) ////
//// lcd_getc(x,y) Returns character at position x,y on LCD ////
//// (C) Copyright 1996,1997 Custom Computer Services ////
//// This source code may only be used by licensed users of the CCS C ////
//// compiler. This source code may only be distributed to other ////
//// licensed users of the CCS C compiler. No other use, reproduction ////
//// or distribution is permitted without written permission. ////
//// Derivative programs created using this software in object code ////
//// form are not restricted in any way. ////
// This structure is overlayed onto the data ports so that you may use
// whatever ports you desire
struct lcd_pin_map
BOOLEAN dummy; // PinA0 is not used
BOOLEAN enable; // PinA1
BOOLEAN rw; // PinA2
BOOLEAN rs; // PinA3
int unusedA : 4; // The rest of portA
int unusedB; // portB is not used
int unusedC; // portC is not used
int data : 4; // lower nibble of portD is used for data lines
int unusedD : 4; // The rest of portD
} lcd;
#if defined(__PCH__)
#locate lcd = 0xF80
#else
#locate lcd = 5
struct lcd_tris_map
int control : 3;
} lcdtris;
#locate lcdtris = 0xF92
#else
#locate lcdtris = 0x85
#define set_tris_lcd(x) lcdtris.data = (x); lcdtris.control = 0;
#define lcd_type 2 // 0=5x7, 1=5x10, 2=2 lines
#define lcd_line_two 0x40 // LCD RAM address for the second line
BYTE const LCD_INIT_STRING[4] = {0x20 | (lcd_type << 2), 0xc, 1, 6};
// These bytes need to be sent to the LCD
// to start it up.
// The following are used for setting
// the I/O port direction register.
#define LCD_WRITE 0 // For write mode all pins are out
#define LCD_READ 15 // For read mode data pins are in
BYTE lcd_read_byte() {
BYTE low,high;
set_tris_lcd(LCD_READ);
lcd.rw = 1;
delay_cycles(1);
lcd.enable = 1;
delay_cycles(1);
high = lcd.data;
lcd.enable = 0;
delay_cycles(1);
lcd.enable = 1;
delay_us(1);
low = lcd.data;
lcd.enable = 0;
set_tris_lcd(LCD_WRITE);
return( (high<<4) | low);
void lcd_send_nibble( BYTE n ) {
lcd.data = n;
delay_cycles(1);
lcd.enable = 1;
delay_us(2);
lcd.enable = 0;
void lcd_send_byte( BYTE address, BYTE n ) {
lcd.rs = 0;
while ( bit_test(lcd_read_byte(),7) ) ;
lcd.rs = address;
delay_cycles(1);
lcd.rw = 0;
delay_cycles(1);
lcd.enable = 0;
lcd_send_nibble(n >> 4);
lcd_send_nibble(n & 0xf);
void lcd_init() {
BYTE i;
lcd.rs = 0;
lcd.rw = 0;
lcd.enable = 0;
delay_ms(15);
for(i=1;i<=3;++i) {
lcd_send_nibble(3);
delay_ms(5);
lcd_send_nibble(2);
for(i=0;i<=3;++i)
lcd_send_byte(0,LCD_INIT_STRING[i]);
void lcd_gotoxy( BYTE x, BYTE y) {
BYTE address;
if(y!=1)
address=lcd_line_two;
address=0;
address+=x-1;
lcd_send_byte(0,0x80|address);
void lcd_putc( char c) {
switch (c) {
case '\f' : lcd_send_byte(0,1);
delay_ms(2);
case '\n' : lcd_gotoxy(1,2); break;
case '\b' : lcd_send_byte(0,0x10); break;
default : lcd_send_byte(1,c); break;
char lcd_getc( BYTE x, BYTE y) {
char value;
lcd_gotoxy(x,y);
lcd.rs=1;
value = lcd_read_byte();
lcd.rs=0;
return(value);
sonicdeejay
Posted: Fri Feb 03, 2006 4:25 am |
| may I know the serial number of LCD i can use this code with??? |
Mark
Posted: Fri Feb 03, 2006 7:29 am |
| HD44780 compatiable |
sonicdeejay
Posted: Fri Feb 03, 2006 9:03 am |
Mark any example code to write in main program?? thx
and what is t pin out connection between PIC and LCD??? |
Mark
Posted: Fri Feb 03, 2006 9:28 am |
| Quote: | | Mark any example code to write in main program?? thx |
No, but CCS provides some.
This is actually CCS's LCD driver where I just changed the declaration section to allow control and data lines to be on different ports. It is set up to work with a PICDEM 2 PLUS board. Refer to that schematic or just look at the declaration section. |
sonicdeejay
Posted: Fri Feb 03, 2006 11:23 am |
| Mark wrote: | | Quote: | | Mark any example code to write in main program?? thx |
Mark....what is the pin to pin connection between PIC and LCD,,,according to your driver???
I am using PIC 18F2525 and I have RB0 to RB5 free....and would like to connect to the LCD using those pins...
so how can I make your driver works for the connection I suggested??/
thx
sonic |
