densimitre
16F877A USART Problem |
Posted: Tue Nov 15, 2005 9:26 am |
Hi friends.
I am having troubles with mi PIC 16F877A and his USART module. I am usign MAX232.
This code donīt work.
#include <16F877A.h>
#device adc=10
#FUSES NOWDT, HS, NOPUT, NOPROTECT, NODEBUG
#FUSES BROWNOUT, NOLVP, NOCPD, NOWRT
#use delay(clock=20000000,RESTART_WDT)
#use rs232 (baud=57600,parity=n,[b]xmit=PIN_C6,rcv=PIN_C7[/b],bits=8,restart_wdt) // HARDWARE USART
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_OFF);
setup_psp(PSP_DISABLED);
setup_spi(FALSE);
setup_timer_1(T1_DISABLED);
setup_vref(FALSE);
int i=0;
while(i<255) {
printf("Current CHAR: %C\n\r",i);
i++;
But following code works.
#device adc=10
#use rs232 (baud=57600,parity=n,[b]xmit=PIN_C4,rcv=PIN_C5[/b],bits=8,restart_wdt) // SOFTWARE USART
setup_adc(ADC_OFF);
setup_spi(FALSE);
setup_vref(FALSE);
int i=0;
while(i<255) {
i++;
itīs seems hardware usart fail.
thank you. |
asmallri
Joined: 12 Aug 2004 Posts: 1646 Location: Perth, Australia
Posted: Tue Nov 15, 2005 9:42 am |
try using the same IO pins as the hardware UART but forcing the compiler to use software.
Code: | #use rs232 (baud=57600,parity=n,xmit=PIN_C6,rcv=PIN_C7,bits=8, force_sw) // SOFTWARE USART |
For your hardware implementation you forgot to add the keyword errors but this affects the receive logic not the trnsmit logic. _________________ Regards, Andrew
densimitre
Posted: Tue Nov 15, 2005 12:49 pm |
asmallri wrote: | try using the same IO pins as the hardware UART but forcing the compiler to use software.
For your hardware implementation you forgot to add the keyword errors but this affects the receive logic not the trnsmit logic. |
HI
thankz for answer..
Well, My intention is to send information towards the PC only....i will try your suggestion.
Bye |
densimitre
Posted: Wed Nov 16, 2005 6:57 am |
Hi there
I have tested your code, and this is the result.
1.- USARTīs pins with force_sw as simple I/O, works fine for rs232 communications. TX and RX functions works very well.
2.- I did some test.
a.- TX in force_sw mode / RX in hardware mode ==> TX ok / RX not OK
b.- TX in hardware mode / RX in force_sw mode ==> TX not OK / RX OK
#use rs232(baud=9600,bits=8,parity=n,xmit=pin_c6,rcv=pin_c7,force_sw,errors,stream=pc1)
#use rs232(baud=9600,bits=8,parity=n,xmit=pin_c6,rcv=pin_c7,errors,stream=pc2)
char c;
setup_adc(ADC_OFF);
setup_spi(FALSE);
setup_vref(FALSE);
while (1) {
c=fgetc(pc2); //RX in hardware mode
fputc(c,pc1); //TX in force_sw mode
after
while (1) {
c=fgetc(pc2); //RX in hardware mode. DONT WORK
fputc(c,pc2); //As RX dont work, TX in HARD/SW mode dont work also.
Im afraid USART HARDWARE ist FAULT....
A question:
- When i use usart in force_sw mode, the data to send is stored in RAM or TXSTA register????
thank you |
Ttlemah Guest
Posted: Wed Nov 16, 2005 10:19 am |
What compiler version?.
If you look back a few days, another poster was having problems with the receive, on the hardware UART, on another chip, and I suggested he simply set the TRIS bit for the RX line. This is a fault, that seems to have appeared a few compiler versions ago, with some chips, when using standard_io, where the compiler clears the TRIS bit incorrectly, setting the receive pin as an output (I have reported it to CCS). Can I suggest you try the same fix?
The software UART does everything in RAM.
