M41T80 Real time clock bcd2bin bin2bcd
treitmey
PostPosted: Mon Aug 22, 2005 9:16 am     Reply with quote
//                               M41T80.C                           ////
//                     Driver for Real Time Clock                   ////
//  init_rtc()
//  multi_read_rtc(int16 address,char *data,int16 size)
//  multi_write_rtc(int16 address,char *data,int16 size)
//  BYTE data=read_rtc(long int address)
//  write_rtc(long int address, BYTE data)
//  BOOLEAN rtc_ready()
#ifndef m40t80_SDA
  #define m40t80_SDA  PIN_C4
  #define m40t80_SCL  PIN_C3
#endif
//#use I2C(master,sda=m40t80_SDA,scl=m40t80_SCL,FORCE_HW,RESTART_WDT)
#use I2C(master,sda=m40t80_SDA,scl=m40t80_SCL,FAST,FORCE_HW,RESTART_WDT)
#define bcd2bin(val) ((val)&15) + ((val)>>4)*10
#define bin2bcd(val) (((val)/10)<<4) + (val)%10
struct _time
{             //  BYTE
  int s:7;        //1. Seconds Register
  int st:1;       //1. Stop
  int m:7;        //2. Minutes Register};
  int j2:1;       // -- waisted bits --
  int h:6;        //3. Hours Register
  int CB:1;       //3. Century Register
  int CEB:1;      //3. Century Enable Register
struct _date
  int dow:8;      //4. Day of week Register
  int d:6;        //5. Day of month Register
  int j3:2;       // -- waisted bits --
  int M:5;        //6. Month Register (note that its UPPER case)
  int j4:3;       // -- waisted bits --
  int y:8;        //7. Year Register
struct _datetime
  int st:1;       //1. Stop
//========================Prototypes==============================//
void init_rtc();
BOOLEAN rtc_ready();
void write_rtc(long int address, BYTE data);
BYTE read_rtc(long int address);
BOOLEAN multi_read_rtc(int16 address,char *data,int16 size);
BOOLEAN multi_write_rtc(int16 address,char *data,int16 size);
//======================init_rtc===========================//
void init_rtc() {
  output_float(m40t80_SCL);
  output_float(m40t80_SDA);
//======================rtc_ready===========================//
BOOLEAN rtc_ready() {
  int1 ack;
  i2c_start();            // If the write command is acknowledged,
  ack = i2c_write(0xD0);  // then the device is ready.
  i2c_stop();
  return !ack;
//======================write_rtc===========================//
void write_rtc(long int address, BYTE data) {
  while(!rtc_ready());//loop here until device is ready
  i2c_start();
  i2c_write((0xD0|(BYTE)(address>>7))&0xFE);
  i2c_write(address);
  i2c_write(data);
  i2c_stop();
//======================read_rtc===========================//
BYTE read_rtc(long int address) {
  BYTE data;
  i2c_start();
  i2c_write(address);
  i2c_start();
  i2c_write((0xD0|(BYTE)(address>>7))|1);
  data=i2c_read(0);
  i2c_stop();
  return(data);
//======================multi_write_rtc===========================//
  i2c_start();
  i2c_write(address);
  for(;size;data++,address++,size--)
    i2c_write(*data);
  i2c_stop();
  return(TRUE);
//======================multi_read_rtc===========================//
  i2c_start();
  i2c_write(address);
  i2c_start();
  for(;size;data++,size--)
    *data=i2c_read(1);//The ack will put next data on bus
  data++; //last read requires no ack
  *data=i2c_read(0);//last read requires no ack
  i2c_stop();
  return(TRUE);
//////struct short_date_time now;
////const char dow_text[8][4] =
////  "---",// -0-
////  "Mon",// -1-
////  "Tue",// -2-
////  "Wed",// -3-
////  "Thr",// -4-
////  "Fri",// -5-
////  "Sat",// -6-
////  "Sun" // -7-
//////Comment out the text if your not using it. This saves on ram
////const char month_text[13][4] =
////  "---",// -0-
////  "Jan",// -1-
////  "Feb",// -2-
////  "Mar",// -3-
////  "Apr",// -4-
////  "May",// -5-
////  "Jun",// -6-
////  "Jul",// -7-
////  "Aug",// -8-
////  "Sep",// -9-
////  "Oct",// -10-
////  "Nov",// -11-
////  "Dec"// -12-
//void rtc_set_datetime(BYTE day, BYTE mth, BYTE year, BYTE dow, BYTE hr, BYTE min, BYTE sec) {
//struct _datetime now;
//  now.s=bin2bcd(sec);
//  now.m=bin2bcd(min);
//  now.h=bin2bcd(hr);
//  now.CB=0;
//  now.CEB=1;
//  now.dow=bin2bcd(dow);
//  now.d=bin2bcd(day);
//  now.M=bin2bcd(mth);
//  now.y=bin2bcd(year);
//  multi_write_rtc(1,&now,sizeof(now));//write the struc to addr=1
//void rtc_get_date(BYTE& day, BYTE& mth, BYTE& year, BYTE& dow) {
//   day = read_rtc(0x87);
//   mth = read_rtc(0x89);
//   year = read_rtc(0x8d);
//   dow = read_rtc(0x8b);
//void rtc_get_time(BYTE& hr, BYTE& min, BYTE& sec) {
//   hr = read_rtc(0x85);
//   min = read_rtc(0x83);
//   sec = read_rtc(0x81);
//int8 getDayOfWeek(int m, int d, int y)
//  int8 csys=1;
//     // csys = 1 for Gregorian Calendar
//     if (m < 3)
//           m = m + 12;
//           y = y - 1;
//     return (d+(2 * m)+int(6*(m+1)/10)+y+int(y/4)-int(y/100)+int(y/400)+csys)%7;
 multi_write_rtc(1,&TimeNow,sizeof(TimeNow));//write the struc to addr=1;not messing with seconds
multi_read_rtc(1,&TimeNow,sizeof(TimeNow));//reread clock
//  printf(glcd_putc,"   %s %s %02u ",dow_text[bcd2bin(current.dow)],month_text[bcd2bin(current.M)],bcd2bin(current.d));
//  printf(glcd_putc,"2%U",current.CB);//print 2000 or 2100 depending on century bit
//  printf(glcd_putc,"%02u",bcd2bin(current.y));
//  printf(glcd_putc," %02u:%02u:%02u   ",bcd2bin(current.h),bcd2bin(current.m),bcd2bin(current.s));
//  printf(glcd_putc,"---");
