How Do You Turn Off The ECAN Module On The PIC18F4580?
Bill_Smith
PostPosted: Mon Aug 15, 2005 4:06 pm     Reply with quote
I am trying to gain access to the PORTB pins B2 and B3 on a PIC18F4580.
I wrote the short program below to test if I could talk to the pins, but I have had no success. I can get pins B4 through B7 to toggle but the two I/O pins B2 and B3 always stay HIGH. The data sheet says that writing to the PORTB TRIS and DATA latches can be changed if the ECAN module is active, and then refers you to that section for further info. In scanning through the 50 some pages of the ECAN section I wasn´t able to clearly understand how to turn off the ECAN module so that PORTB can be used for I/O. Has anyone seen this problem before?
Thank you.
#include <18F4580.h>
#device *=16 ADC=10
#fuses HS,NOWDT,NOPUT,NOPROTECT,NOBROWNOUT,NOLVP,NOCPD,NOWRT,NODEBUG
#use rs232(baud=57600,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8,stream=USB)
#use i2c(MASTER, SCL=PIN_C3, SDA=PIN_C4, FORCE_HW)
#zero_ram
#use fast_io(B)
#include <can-18F4580.c>
   can_init();
   can_set_mode(CAN_OP_DISABLE);   //
      output_toggle(PIN_B2);
      delay_ms(1);
PostPosted: Mon Aug 15, 2005 4:25 pm     Reply with quote
If you use fast_io mode, you need to set the TRIS for Port B with the
set_tris_b() function. If you want the compiler to automatically handle
setting the tris, then remove the #use fast_io() statement.
Bill_Smith
PostPosted: Mon Aug 15, 2005 4:54 pm     Reply with quote
Hey PCM,
Thanks for your observation however removing that statement had no effect on my problem. Apparently there is some bit in the ECAN module still set wrong. Most of Microchip´s controller data sheets have simplified block diagrams of each of the I/O ports, the PIC18F4580 only shows a generic model, pretty difficult to track down which register is controlling the multiplexer gate.
PostPosted: Mon Aug 15, 2005 5:03 pm     Reply with quote
What happens if you comment out the calls to can_init() and can_set_mode() ?
Does Pin B2 then toggle OK ?
Bill_Smith
PostPosted: Mon Aug 15, 2005 5:14 pm     Reply with quote
Nothing. I even tried the following:
#device *=16 ADC=10
#zero_ram
#byte   PORTB=0x0F81
#byte   TRISB=0x0F93
#asm
   clrf PORTB;
   movlw 0b00001000;
   movwf TRISB;
#endasm
      delay_ms(1);
The debugger shows that the PORTB and TRISB bits are getting set and cleared however pin B2 refuses to toggle. Do you know if the ECAN module defaults to OFF at Power UP?
PostPosted: Mon Aug 15, 2005 5:41 pm     Reply with quote
Try adding NOPBADEN to your #fuses statement.
