looking for power_pwm excode or explanation.
skyforme
PostPosted: Mon Aug 15, 2005 7:44 am     Reply with quote
Hello all.
I am new to ccs and pic.
I am trying to use 18f4431 and trying to power_pwm
because
for me, it looks like that ccp has 2 independent outputs.
however, I could not find any example about power_pwm
and
the exp. of power_pwm looks like self-explanatory for the old user but it's not for me.
Could you help me to explain about power_pwm or
could you post any example code about power_pwm?
Mark
PostPosted: Mon Aug 15, 2005 8:16 am     Reply with quote
I would check out Microchip's website. Look for Appnotes on using the pwm modules and also read the datasheet for the PIC.
Re: looking for power_pwm excode or explanation.
PostPosted: Mon Aug 15, 2005 8:41 am     Reply with quote
skyforme wrote:
Hello all.
because
and
Look at the PICDEM MC User's Manual (from the Microchip website) to learn about using the 18F4431.
If you are only looking for a PIC with 2 independent PWM outputs, then you don't need a 4431. Just look for a PIC that has CCP and ECCP. By operating the CCP in PWM mode, and the ECCP in single PWM mode, then you'll have the two independent PWMs you want.
skyforme
PostPosted: Mon Aug 15, 2005 11:59 am     Reply with quote
Hello
Thank you for replies.
I need 6 pwm signals that is the reason why I chose 4431.
(ccp can control 2 pwms?)
In addition, I still have confusion about all the parameters and usage of set_power_pwm0_duty and related command - maybe new command of CCS.
There was no ex code and the explanation is so simple.
Could you help me about these command?
