invalid clock value
Georg Prinz
invalid clock value
PostPosted: Sun Jul 03, 2005 11:40 pm     Reply with quote
Hi folks,
I use PCWH-compiler V. 3.212 with ICD-U40. Following test program is compiled and loaded correctly and debugger says "Ready MCU at 10MHz":
#include <16f876.h>
#fuses HS,NOLVP,NOWDT,NOPROTECT,DEBUG
#use delay(clock=10000000)
#define led PIN_A5
main
output_low(led);
delay(1ooo);
output_high(led);
Stepping through the program goes well until last delay and then it jumps to "'use delay(clock=10000000) saying "Invalid clockvalue from the debugger" and "Ready MCU at 1280MHz". Starting again the program the debugger says "Debugging may not have been enalbled".
Any suggestion?
Thanks in advance.
georg
dl 2 kp
Georg Prinz
PostPosted: Sun Jul 10, 2005 11:40 pm     Reply with quote
Ok folks,
I's running. I checked the hardware carefully and found a hidden resistor.
dl 2 kp
Mixy73
PostPosted: Fri Jul 29, 2005 3:53 am     Reply with quote
I Have the same problem on my situation, but I din't found any hidden resistor.
Can You are more precise ???
Sorry for my bad english.
Marco
juanma
PostPosted: Sun Jan 01, 2006 6:44 pm     Reply with quote
CONECTA LOS 5V DEL CONECTOR TARGET, Y OK.
Y LOS DEMAS CLARO.
