Hector Guest
| I2C simple test program |
Posted: Fri May 09, 2003 3:29 am |
Hey everybody!
I'm trying to make a simple test for communicate two 18F452 via I2C, I'll prefer to use the build-in function to make it more readable. In this code, the slave non-stop showing what it gets, but actually it's nothing! Which is the problem?
//I2C communication between PICs
//MASTER
//PIC 1
#include <18F452.h>
#device *=16
//#FUSES HS,NOWDT,NOPROTECT,PUT,BROWNOUT
#use DELAY(CLOCK=19660800)
#use fast_io(A)
#use fast_io(B)
#use fast_io(C)
#BYTE PORTC = 0xF82
#BYTE PORTB = 0xF81
#BYTE PORTA = 0xF80
#define SLAVE_ADDRESS 0xA0
#use rs232(baud=9600, BITS=8, PARITY=N, xmit=PIN_C6, rcv=PIN_C7, ERRORS)
#use I2C (MASTER, SDA=PIN_C4, SCL=PIN_C3)
delay_ms(2000);
SET_TRIS_A(0x01);
SET_TRIS_B(0x00);
SET_TRIS_C(0x88);
output_float(PIN_C3);
output_float(PIN_C4);
i2c_start();
i2c_write(SLAVE_ADDRESS); //write
i2c_write('H');
i2c_stop();
__________________________________
//SLAVE
//PIC 2
#include <18F452.h>
#device *=16
#use fast_io(A)
#use fast_io(B)
#use fast_io(C)
#BYTE PORTC = 0xF82
#BYTE PORTB = 0xF81
#BYTE PORTA = 0xF80
#use rs232(baud=9600, BITS=8, PARITY=N, xmit=PIN_A1, rcv=PIN_A0,ERRORS)
#use I2C (SLAVE, SDA = PIN_C4, SCL = PIN_C3, address = SLAVE_ADDRESS)
int c=0;
delay_ms(2000);
SET_TRIS_A(0x01); // 0000 0001
SET_TRIS_B(0x00); // 0000 0000
SET_TRIS_C(0x88); // 1000 1000
printf("I'm your slave, tell what you want\n\r");
while(!i2c_poll())
c=i2c_read(0);
printf("What I get: \%c\n\r", c);
any help will be usefull
thank you
Original Post ID: 14281 |
John H. Guest
| Are the output_float commands compiling properly? |
Posted: Fri May 09, 2003 8:21 am |
Hi Hector,
I'm here searching the forum for answers to the same question. I've got an I2C routine that I wrote that runs properly on an older version of the compiler and now isn't working properly.
Check the *.LST output from the compiler and see if it compiled the "output_float" commands. I suspect that there is an issue when using fast_io and the output_float commands. In my listing, the output_float appear to have been ignored by the compiler without any warning or error message.
You might be able to get your routine up and running if you switch over to standard_io. That seems to allow the output_float command to work.
I'm still looking for a workaround. I prefer not to use the supplied I2C routines.
Let me know if your listing file shows the same.
JH
:=Hey everybody!
:=I'm trying to make a simple test for communicate two 18F452 via I2C, I'll prefer to use the build-in function to make it more readable. In this code, the slave non-stop showing what it gets, but actually it's nothing! Which is the problem?
:=//I2C communication between PICs
:=//MASTER
:=//PIC 1
:=#include <18F452.h>
:=#device *=16
:=//#FUSES HS,NOWDT,NOPROTECT,PUT,BROWNOUT
:=#use DELAY(CLOCK=19660800)
:=#use fast_io(A)
:=#use fast_io(B)
:=#use fast_io(C)
:=#BYTE PORTC = 0xF82
:=#BYTE PORTB = 0xF81
:=#BYTE PORTA = 0xF80
:=#define SLAVE_ADDRESS 0xA0
:=#use rs232(baud=9600, BITS=8, PARITY=N, xmit=PIN_C6, rcv=PIN_C7, ERRORS)
:=#use I2C (MASTER, SDA=PIN_C4, SCL=PIN_C3)
:=void main(void)
:=delay_ms(2000);
:= SET_TRIS_A(0x01);
:= SET_TRIS_B(0x00);
:= SET_TRIS_C(0x88);
:= output_float(PIN_C3);
:= output_float(PIN_C4);
:=while(TRUE)
:= i2c_start();
:= i2c_write(SLAVE_ADDRESS); //write
:= i2c_write('H');
:= i2c_stop();
:= delay_ms(1000);
:=__________________________________
:=//SLAVE
:=//PIC 2
:=#device *=16
:=#use fast_io(A)
:=#use fast_io(B)
:=#use fast_io(C)
:=#use rs232(baud=9600, BITS=8, PARITY=N, xmit=PIN_A1, rcv=PIN_A0,ERRORS)
:=#use I2C (SLAVE, SDA = PIN_C4, SCL = PIN_C3, address = SLAVE_ADDRESS)
:=void main()
:= int c=0;
:= delay_ms(2000);
:= SET_TRIS_A(0x01); // 0000 0001
:= SET_TRIS_B(0x00); // 0000 0000
:= SET_TRIS_C(0x88); // 1000 1000
:= printf("I'm your slave, tell what you want\n\r");
:= while(TRUE)
:= while(!i2c_poll())
:= c=i2c_read(0);
:= printf("What I get: \%c\n\r", c);
:=any help will be usefull
:=thank you
Original Post ID: 14293 |
John H. Guest
Posted: Fri May 09, 2003 8:27 am |
Hi Hector,
JH
:=Hey everybody!
:=//MASTER
:=//PIC 1
:=#device *=16
:=#use fast_io(A)
:=#use fast_io(B)
:=#use fast_io(C)
:=void main(void)
:=delay_ms(2000);
:=while(TRUE)
:= i2c_start();
:= i2c_write('H');
:= i2c_stop();
:= delay_ms(1000);
:=//SLAVE
:=//PIC 2
:=#device *=16
:=#use fast_io(A)
:=#use fast_io(B)
:=#use fast_io(C)
:=void main()
:= int c=0;
:= delay_ms(2000);
:= while(TRUE)
:= c=i2c_read(0);
:=thank you
Original Post ID: 14295 |
Hector Guest
| Re: Are the output_float commands compiling properly? |
Posted: Sat May 10, 2003 9:13 am |
hey John!
you're right, the compiler ignores the output_float senteces when using #use fast_io. But that's why you can do it by you own, just set in the TRIS register the pins as input and you'll have the same effect.
Another cuestion does anybody knows if the i2c_poll runs correctly in the slave?
Hector
:=Hi Hector,
:=I'm here searching the forum for answers to the same question. I've got an I2C routine that I wrote that runs properly on an older version of the compiler and now isn't working properly.
:=Check the *.LST output from the compiler and see if it compiled the "output_float" commands. I suspect that there is an issue when using fast_io and the output_float commands. In my listing, the output_float appear to have been ignored by the compiler without any warning or error message.
:=You might be able to get your routine up and running if you switch over to standard_io. That seems to allow the output_float command to work.
:=I'm still looking for a workaround. I prefer not to use the supplied I2C routines.
:=Let me know if your listing file shows the same.
:=JH
Original Post ID: 14338 |
