problem with MPLAB
horsti
problem with MPLAB
PostPosted: Mon Apr 25, 2005 1:38 am     Reply with quote
when I try to start MPLAB from CCS, the MPLAB program starts fine but wouldn't loud any project file.
Another question:
Is it possible just to simulate a projet from CCS without any ICD or MPLAB ?
thanks to everybody
Haplo
PostPosted: Mon Apr 25, 2005 1:42 am     Reply with quote
What is the error message MPLAB is returning?
To my knowledge CCS doesn't have any chip emulators.
PostPosted: Mon Apr 25, 2005 4:00 am     Reply with quote
there's no error message. MPLAB was just started with no loaded file.
drolleman
PostPosted: Mon Apr 25, 2005 7:58 pm     Reply with quote
mplab starts ccs not the other way. you start mplab start / load a project that uses the ccs compiler then when you compile it ccs compiler compiles the code then mplab waits for the next task.
