Problem with RS232
Naiade
Problem with RS232
PostPosted: Mon Mar 14, 2005 10:49 am     Reply with quote
Hi everybody, hope you can help me.
I have a hex compiled with the CCS 3.127 and works ok but I need to change some part of the code and I am using the last one (3.221) and I have a big problem ...
I'm working with a GSM modem and receiving some call I look for "\r\nRING\r\n" but sometimes I just received the \r o \r\n o a little bit more but it seems like the message doesn't arrive ...
someone has got this problem ? Is it a parameter I have to change in the new CCS
Thx for your help.
Naiade
PostPosted: Mon Mar 14, 2005 11:04 am     Reply with quote
I add ther parameters I use
#USE RS232 (BAUD=9600, XMIT=PIN_C6, RCV=PIN_C7, PARITY=N, BITS=8)
thx again
PostPosted: Mon Mar 14, 2005 11:29 am     Reply with quote
I put you the code to see if you see something strange.
#INCLUDE <18F452.h>
#FUSES XT,WDT128,WDT,PUT, NOLVP, NODEBUG
#DEVICE ADC=10
#INCLUDE <string.h>
#INCLUDE <stdlib.h>
#INCLUDE <math.h>
#USE delay(clock=3579000)
#USE RS232 (BAUD=9600, XMIT=PIN_D6, RCV=PIN_D7, PARITY=N, BITS=8,STREAM=SETUP) (this a second RS232 emulated with others I/O pins)
#USE RS232 (BAUD=9600, XMIT=PIN_C6, RCV=PIN_C7, PARITY=N, BITS=8) (this is the modem RS232
Char GetFromRX () {
char data;
if (RXItems > 0)
data = *RXInicio;
RXInicio ++;
if (RXInicio > &ColaRX[MAXCOLA-1]) RXInicio = &ColaRX[0];
RXItems --;
return (data);
else return(0);
#INT_RDA
void Receive (){
char data;
data = getc();
if (RXItems == MAXCOLA) error_fatal();
if (RXItems < MAXCOLA)
*RXFinal = data;
RXFinal ++;
IF (RXFinal > &ColaRX[MAXCOLA-1]) RXFinal = &ColaRX[0];
RXItems ++;
disable_interrupts(GLOBAL);
restart_wdt();
setup_counters(RTCC_INTERNAL, WDT_ON);
setup_wdt(WDT_ON);
restart_wdt();
set_tris_a(0b101111);
set_tris_c(0b11000000);
set_tris_e(0b011);
set_tris_d(0b10000000);
while (TRUE)
if (( a=GetfromRX() ) != 0) {recmes[i++]=a;lcd_putc(a);}
if (( i>2 ) && (recmes[i-1] == '\n') ) (LOOKING FOR THE \r\n\ring\r\n)
recmes[i]=0;
i=0;
if ( strcmp(recmes,ring) == 0) TAKETHECALL();
PostPosted: Tue Aug 02, 2005 12:52 am     Reply with quote
Embarassed Embarassed Embarassed Embarassed Embarassed Embarassed Embarassed Embarassed Embarassed Embarassed Embarassed Embarassed Embarassed Embarassed Embarassed Embarassed Embarassed Embarassed Embarassed Embarassed Embarassed Embarassed Embarassed Embarassed Embarassed Embarassed Embarassed Embarassed Embarassed Embarassed Twisted Evil Twisted Evil Twisted Evil Twisted Evil Question Question Question Idea Idea Idea Arrow Arrow Arrow Wink Rolling Eyes Mad Razz Embarassed Crying or Very sad Laughing Cool Confused Shocked Very Happy Smile Sad Surprised
Humberto
PostPosted: Sat Aug 06, 2005 9:47 am     Reply with quote
This forum is only for CCS Debuggers and Programmers Devices, not for general issues.
Nobody answer you because you posted in the wrong forum.
Go to General Discussion Forum and post the full code and compiler version
http://www.ccsinfo.com/forum/viewforum.php?f=1
Humberto
