isaac aiyanyo Guest
| Help needed with frequency counter |
Posted: Fri Apr 18, 2003 4:20 am |
Hi Picstars
i still need your help here as i have being strugling all night with this program.
its the example FREQC.C which is supposed to be a 50mhz frequency counter.
i have ran the program but i am still very confused
with the results i am getting as could understand why parts of the program were commented out?
i want to use it for the frequency range 100Hz to 10Khz
but i am getting the following results
AT 100Hz i get 11000Hz to 12000Hz
AT 1KHz i get about 13870Hz
AT 100KHz i get about 27000Hz
Could someone please tell me where i am going wrong
my program is below
Hope to hear from you soon
Isaac
#if defined(__PCM__)
#include <16F876.H>
#fuses HS,NOWDT,NOPUT,NOPROTECT,NOBROWNOUT,NOLVP
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7,RESTART_WDT,ERRORS)
#bit t1_overflow=0x0C.0
// #bit t1_overflow=0xF9E.0 (PIC18, Reminder)
int cycles8, cycles;
int32 freq;
long freqc_high;
long freqc_low;
while (TRUE) {
cycles8=0;
cycles=0;
freqc_high=0;
t1_overflow=0;
set_timer1(0);
setup_timer_1(T1_EXTERNAL|T1_DIV_BY_1);
/* ___ wait one second ___ */
while (cycles!=0xFF) { //true=3, false=4
cycles8=0; //1 cycle
//start inner loop
while (cycles8!=0xFF) { //true=3, false=4
if (t1_overflow)//true=2,false=3 //----|
{t1_overflow=0;freqc_high++;}//6 cycles // |
else // |-- 8 cycles
{delay_cycles(5);} //----|
delay_cycles(62); //x
cycles8++; //1
///2 cycles to jump to top
//math: end inner loop
//math: total inner loop=((3+8+x+1+2)*255 + 4)*255
//math: if x=62.87781 then inner loops takes 5mil instructions
//math: if x=62 then inner loop takes 4942920, have to fill 57080 cycles
delay_cycles(216); //y
cycles++; ///1 cycle
///2 cylces to jump to top
//math: outer=(3+1+y+1+2)*255+4=57080
//math: y=(57080-4)/255)-(3+1+0+0+1+2)
//math: if y=216.827450980392156862745098039216 then outer loop cylces is 57080
//math: if y=216 then outer loop cycles is off by 211 cycles. z=211
delay_cycles(211); //z
/* ___ end waiting 1 second ___ */
setup_timer_1(T1_DISABLED); //turn of counter to prevent corruption while grabbing value
if (t1_overflow) //check one last time for overflow
freqc_high++;
freqc_low=get_timer1(); //get timer1 value as the least sign. 16bits of freq counter
freq=make32(freqc_high,freqc_low); //use new make32 function to join lsb and msb
printf("\%LU Hz\r\n",freq); //and print frequency
___________________________
Original Post ID: 13785 |
Mark DSylva Guest
| Re: Help needed with frequency counter |
Posted: Fri Apr 18, 2003 8:36 am |
:=Hi Picstars
:=i still need your help here as i have being strugling all night with this program.
:=its the example FREQC.C which is supposed to be a 50mhz frequency counter.
Where does it say that this is a 50Mhz freq. counter? I don't see any reference mentioning that.
:=i have ran the program but i am still very confused
:=with the results i am getting as could understand why parts of the program were commented out?
What parts are commented out? I only see some comments explaining the math, no actual code is commented out!
:=i want to use it for the frequency range 100Hz to 10Khz
:=but i am getting the following results
:=AT 100Hz i get 11000Hz to 12000Hz
:=AT 1KHz i get about 13870Hz
:=AT 100KHz i get about 27000Hz
:=Could someone please tell me where i am going wrong
:=my program is below
:=Hope to hear from you soon
:=Isaac
The code is specifying a 20Mhz clock, is that what you are using?
Original Post ID: 13787 |
isaac aiyanyo Guest
Posted: Fri Apr 18, 2003 9:12 am |
:=Where does it say that this is a 50Mhz freq. counter? I don't see any reference mentioning that.
<a href="http://www.cc.puv.fi/~t0101190/projekti/source/Examples/ex_freqc.c" TARGET="_blank">http://www.cc.puv.fi/~t0101190/projekti/source/Examples/ex_freqc.c</a>
:=What parts are commented out? I only see some comments explaining the math, no actual code is commented out!
Yes you were right there sorry for the mislead
its all to do with my C knowlegde
:=The code is specifying a 20Mhz clock, is that what you are using?
i am using a 20Mhz clock.
Please help
Isaac
Original Post ID: 13789 |
