50mhz Frequency counter
ISAAC AIYANYO
PostPosted: Wed Apr 16, 2003 7:29 am     Reply with quote
Hello Picstars
i need your help here.
i am trying to use the pic as a frequency counter using a 16F873 but i don't seems to have the example file
EX_FREQC.C even though its listed in the manual.
Would anyone be kind enough to post the program if you have it.
have anyone done anything like this before i need to measure the frequency of a square wave with a range of 100Hz to 10Khz
Any help rendered would be much appreciated
Isaac
___________________________
Original Post ID: 13708
Re: 50mhz Frequency counter
PostPosted: Wed Apr 16, 2003 12:17 pm     Reply with quote
:= Hello Picstars
:= i need your help here.
:= i am trying to use the pic as a frequency counter using a 16F873 but i don't seems to have the example file
:=EX_FREQC.C even though its listed in the manual.
:= Would anyone be kind enough to post the program if you have it.
:= have anyone done anything like this before i need to measure the frequency of a square wave with a range of 100Hz to 10Khz
:= Any help rendered would be much appreciated
By using Google I found it very quickly. <a href="http://www.google.com" TARGET="_blank">http://www.google.com</a>
Here are the files:
<a href="http://www.cc.puv.fi/~t0101190/projekti/source/Examples/" TARGET="_blank">http://www.cc.puv.fi/~t0101190/projekti/source/Examples/</a>
I notice that CCS doesn't have NOLVP in the #fuses statement.
They really should have it in there, because the average person
does not use LVP, and it causes a lot of problems if you
forget to set it for NOLVP.
Original Post ID: 13712
Hans Wedemeyer
PostPosted: Wed Apr 16, 2003 1:38 pm     Reply with quote
without prescaler I the pic can't count at 50 mega Hertz.
Original Post ID: 13719
isaac aiyanyo
PostPosted: Thu Apr 17, 2003 6:37 am     Reply with quote
Thank you every much for the link
its very much appreciated.
i have ran the program but i am still very confused
with the results i am getting as could understand why parts of the program were commented out?
i want to use it for the frequency range 100Hz to 10Khz
but i am getting the following results
AT 100Hz i get 11000Hz to 12000Hz
AT 1KHz i get about 13870Hz
AT 100KHz i get about 27000Hz
Could someone please tell me where i am going wrong
my program is below
Hope to hear from you soon
Isaac
#if defined(__PCM__)
#include <16F876.H>
#fuses HS,NOWDT,NOPUT,NOPROTECT,NOBROWNOUT,NOLVP
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7,RESTART_WDT,ERRORS)
#bit t1_overflow=0x0C.0
// #bit t1_overflow=0xF9E.0 (PIC18, Reminder)
void main() {
int cycles8, cycles;
int32 freq;
long freqc_high;
long freqc_low;
while (TRUE) {
cycles8=0;
cycles=0;
freqc_high=0;
t1_overflow=0;
set_timer1(0);
setup_timer_1(T1_EXTERNAL|T1_DIV_BY_1);
/* ___ wait one second ___ */
while (cycles!=0xFF) { //true=3, false=4
cycles8=0; //1 cycle
//start inner loop
while (cycles8!=0xFF) { //true=3, false=4
if (t1_overflow)//true=2,false=3 //----|
{t1_overflow=0;freqc_high++;}//6 cycles // |
else // |-- 8 cycles
{delay_cycles(5);} //----|
delay_cycles(62); //x
cycles8++; //1
///2 cycles to jump to top
//math: end inner loop
//math: total inner loop=((3+8+x+1+2)*255 + 4)*255
//math: if x=62.87781 then inner loops takes 5mil instructions
//math: if x=62 then inner loop takes 4942920, have to fill 57080 cycles
delay_cycles(216); //y
cycles++; ///1 cycle
///2 cylces to jump to top
//math: outer=(3+1+y+1+2)*255+4=57080
//math: y=(57080-4)/255)-(3+1+0+0+1+2)
//math: if y=216.827450980392156862745098039216 then outer loop cylces is 57080
//math: if y=216 then outer loop cycles is off by 211 cycles. z=211
delay_cycles(211); //z
/* ___ end waiting 1 second ___ */
setup_timer_1(T1_DISABLED); //turn of counter to prevent corruption while grabbing value
if (t1_overflow) //check one last time for overflow
freqc_high++;
freqc_low=get_timer1(); //get timer1 value as the least sign. 16bits of freq counter
freq=make32(freqc_high,freqc_low); //use new make32 function to join lsb and msb
printf("\%LU Hz\r\n",freq); //and print frequency
Original Post ID: 13757
Mike Broom
PostPosted: Tue Apr 22, 2003 7:56 am     Reply with quote
Below is a simple interrupt driven frequency counter which will work between approx 1Hz to 65.5kHz
Mike
#include <16F876.h>
#fuses HS, NOWDT, NOPROTECT, PUT, BROWNOUT, NOLVP
#use Delay(clock=16000000)
#use fast_io(A)
#use fast_io(B)
#use fast_io(C)
int16   Count;
int16   Frequency;
int1    OneSecondGone = 0;
void main(void) ;
#int_timer2
void t2_isr(void)
    static int8 RollOver = 0;
    Count = get_timer1();
    RollOver++;
    if (Rollover == 250)
        OneSecondGone = true;
        Rollover = 0;
        set_timer1(0);
        Frequency = Count;
    set_tris_a(0);
    set_tris_c(255);
    setup_timer_2(T2_DIV_BY_4,250,16);
    enable_interrupts(int_timer2);
    enable_interrupts(global);
    while(true)
        if (OneSecondGone)
            if (Frequency > 999)
                printf("\rFequency = \%1.4f kHz       ",(float)Frequency / 1000);
                printf("\rFequency = \%lu Hz          ",Frequency);
            OneSecondGone = false;
:= Hello Picstars
:= Isaac
Original Post ID: 13915
inmelody
PostPosted: Tue May 14, 2013 12:57 pm     Reply with quote
hi can you send me proteus schematic for this frequency counter. I try but i cant do it :( ...
Mike
#include <16F876.h>
#use fast_io(A)
#use fast_io(B)
#use fast_io(C)
int16 Count;
int16 Frequency;
void main(void) ;
#int_timer2
void t2_isr(void)
RollOver++;
Rollover = 0;
set_timer1(0);
Frequency = Count;
set_tris_a(0);
set_tris_c(255);
while(true)
if (OneSecondGone)
PostPosted: Tue May 14, 2013 1:56 pm     Reply with quote
I seriously doubt anyone here will send you a Proteus schematic.
We all KNOW Proteus is full of bug,errors and faulty DRCs and as such is a complete waste of time.
Please read PIC101 thread...
Also note that ANY floating point math takes a LOT of time on PICs, so if your signal source is not stable, you'll see 'funny' numbers.
hth
jay
PostPosted: Tue May 14, 2013 2:33 pm     Reply with quote
inmelody,
Do you realize this thread is right at 10 YEARS old? I doubt that user is still in the forum any more
PostPosted: Tue May 14, 2013 2:44 pm     Reply with quote
It's true that floating point is relative slow but here the calculation is only being done one time per second so not a real problem. Though I would recommend using the %w specifier on the integer value instead of using floats, much faster and less memory usage.
About the schematic: very easy, just connect your frequency signal to the Timer1 external input pin. I'm too lazy to read the data sheet for the pin number, you'll have to do that yourself.
PostPosted: Wed May 15, 2013 1:11 am     Reply with quote
There is though the problem that the multi-byte 'frequency' value will change during the calculation. So abnormal results would be the 'norm' (if you see what I mean....).
PostPosted: Wed May 15, 2013 1:31 pm     Reply with quote
Nope, I don't see what you mean.
Maybe I'm missing something, but I'm aware of the problems related to non-atomic actions in combination with interrupts.
As I understand it the variable 'frequency' is only updated once every second in the ISR and then immediately afterwards the float calculation happens in main. So I don't see how this being a multi-byte variable would pose a problem during the calculation? The flag OneSecondGone should cover all problems unless the calculations take more than 1 second which with the code shown is not going to happen.
