Init struct with memset, work?
cfernandez
PostPosted: Sun Jan 02, 2005 5:24 pm     Reply with quote
Is possible and work initialize a struct con memset?
struct _ST_
   int a;
   int b;
   char x[ 10 ];
} ST;
memset( &ST, 0x00, sizeof( ST ) );
Haplo
PostPosted: Sun Jan 02, 2005 11:55 pm     Reply with quote
According to the manual, yes. The description for memset in the manual is the same as memcopy and memmove, CCS manual is full of mistakes like that. But what you want to do is in one of the examples:
MEMSET()
Syntax: memset (destination, value, n)
Parameters: destination is a pointer to memory, value is a 8 bit int,
and n is a 8 bit int.
Returns: undefined
Function: Copies n bytes from source to destination in RAM. Be
aware that array names are pointers where other variable
names and structure names are not (and therefore need a
& before them).
Memmove performs a safe copy (overlapping objects
doesn't cause a problem). Copying takes place as if the n
characters from the source are first copied into a
temporary array of n characters that doesn't overlap the
destination and source objects, and then the n characters
from the temporary array are copied to destination.
Built-In Functions
119
Availability: All devices
Requires Nothing
Examples:
memset(arrayA, 0, sizeof(arrayA));
memset(arrayB, '?', sizeof(arrayB));
memset(&structA, 0xFF, sizeof (structA));
Example Files: None
Also See: memcpy()
cfernandez
PostPosted: Mon Jan 03, 2005 7:15 am     Reply with quote
I try to fill with 0x00 a struct with the memset, but not working. Work this for somebody??
PostPosted: Mon Jan 03, 2005 12:54 pm     Reply with quote
Post a complete test program (not just a code fragment), and give your
version of the compiler.
cfernandez
PostPosted: Wed Jan 05, 2005 11:35 am     Reply with quote
PCM
This is the code
0000                07587 ....................    memset( &MSG_RX, 0x00, sizeof( MSG_RX ) );
0442 0E10           07588 MOVLW  10
0444 6E01           07589 MOVWF  01
0446 6AEA           07590 CLRF   FEA
0448 0EEF           07591 MOVLW  EF
044A 6EE9           07592 MOVWF  FE9
044C 6AEE           07593 CLRF   FEE
044E 2E01           07594 DECFSZ 01,F
0450 D7FD           07595 BRA    044C
What you do think?????
cfernandez
PostPosted: Wed Jan 05, 2005 12:45 pm     Reply with quote
PCM,
The problem is that memset support int8 for the n bytes to set, and my struct hace 272 bytes.!!!!
Is possible change this in the memset????
PostPosted: Wed Jan 05, 2005 1:01 pm     Reply with quote
Add a new 16-bit memset function.
// A version of memset that allows a 16-bit length i.s.o. the standard 8-bit length.
void memset16(int8 *Destination, int8 Value, int16 Len)
  while (Len > 0)
    *Destination++ = Value;
    Len--;
cfernandez
PostPosted: Wed Jan 05, 2005 1:29 pm     Reply with quote
ckielstra,
Your routine not work for set my struct!, you test this with struct?
Thank you very much!
cfernandez
PostPosted: Wed Jan 05, 2005 1:35 pm     Reply with quote
ckielstra,
This is the answer from CCS
This message is a reply to CCS e-mail id: 5A1131
That is a limitation now however we will allow larger constants in the next release (3.216).
CCS PIC C Compiler home: www.ccsinfo.com/picc
Software download page: www.ccsinfo.com/download.shtml
Latest Compiler news: www.ccsinfo.com/news.html
If you would like to be notified when the next compiler
version comes out go to www.ccsinfo.com/cgi-bin/email.cgi
If you will do these two things, then more testing can be done:
give your version of the compiler.
