How to fast is fast enough to prevent overrun error. |
Posted: Thu Dec 16, 2004 12:20 pm |
I want to knoe how to avoid the overrun error on a 18LF452.
I can write code on a 16F877A in the #int_RDA to get a byte from the com port, store it, check it, and set a result. No lockup. But when i try to do the same thing in the 'LF452, no matter what i try, i get overrun error.
I have tried using the code in the examples dir., and they will lockup.
I have put a simple 'buffer = getc(); inc buffer element' removing all format code, and OERR fires.
I have even used inline #ASM and use the Microchip example code, and i still get the same problem.
I suspect it could be a setting issue, and i've check all comms related regs.
I don't want to use the ERRORS, as i will lose a byte. I look at my LST file and notice 0xFAF (SPBRG) is set to 0x19. The DCE is 9600 8N1 and the PIC isset the same.
What options are there to get over this.? |
Posted: Thu Dec 16, 2004 12:23 pm |
Just to add,
this is the first time i am using a resonator rated a 4Mhz with built in caps.
Normally i use Xtal Osc.modules. |
languer
Posted: Thu Dec 16, 2004 1:38 pm |
This link may provide some help,
http://www.picbasic.co.uk/forum/showthread.php?s=&threadid=702
Quote: | On the 16F series you have an 8 level deep stack, and once it's filled up, it starts being over-written (circular type buffer) by further return addresses pushed onto the stack from top-to-bottom.
While your program may or may not work on a 16F part when doing this, it can still cause trouble depending on how many consecutive calls you have before returns start (referred to as nesting) popping addresses back off the stack.
You have return addresses being pushed onto the stack by PBP library functions + your own code. With the 16F's circular type stack buffer, you're getting by with the boo-boo because return addresses are still being pushed on the stack (simply overwritting previous contents), and all's well if you're not nesting calls too deep.
One the 18F parts you have a 31 level stack, BUT, it's not the circular type buffer like you have with the 16F. Once you get to location 31 the 32nd return address simply overwrites location 31,
and it's sit & spin at location 31 from there on. |
Posted: Thu Dec 16, 2004 1:54 pm |
1. What happens if you test the 18LF452 with a crystal, instead of the resonator ?
2. What voltage are you using for the 18LF452 ?
3. Are you using a MAX232-type chip ?
4. What's your version of the CCS compiler ?
5. What is the source of the RS-232 data stream ? What is the
spacing between the bytes ? (in microseconds or milliseconds)
6. Post your test program (complete with all #fuses statements, etc.)
Show the complete (but small) test program. |
Posted: Thu Dec 16, 2004 3:08 pm |
Hiya,
I normally use a clock module with XT set. Using it now i get the same response. So i think that's not the problem.
I also get 3.98Mhz on OSC2 pin using the resonator.
I believe the fact it is 'LF' says it can operated a lower voltages, but i am using 5v off a regulator.
Yepp, MAX232CPE from MAXIM.
MPLAB v6.30
v3.200 PCWH
Not entirely sure.
#include <18F452.h>
#device adc=8
#fuses NOWDT,HS, PROTECT, NOOSCSEN, BROWNOUT, BORV20, PUT, STVREN, NODEBUG, NOLVP, NOWRT, NOWRTD, NOWRTB, NOWRTC, NOCPD, NOCPB, NOEBTR, NOEBTRB
#use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=9,stream=GSM)
#use rs232(baud=9600,parity=N,xmit=PIN_D1,rcv=PIN_C1,bits=8,stream=COM)
#byte RCREG =0xFAE
#bit OERR =RCREG.1
#bit FERR =RCREG.2
#bit CREN =RCREG.4
char InBuff[20];
int8 t=0;
int8 i;
void SetupMCU()
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_OFF);
setup_psp(PSP_DISABLED);
setup_spi(FALSE);
setup_wdt(WDT_OFF);
setup_timer_0(RTCC_INTERNAL);
setup_timer_1(T1_DISABLED);
#int_RDA
RDA_isr()
InBuff[t]=fgetc(GSM);
if(OERR)
output_high(PIN_E1);
CREN=0;
CREN=1;
if(FERR)
output_high(PIN_E2);
t=(t+1)%sizeof(InBuff); // just inc the buffer
SetupMCU();
output_high(PIN_E0);
output_low(PIN_E0);
enable_interrupts(INT_RDA);
// clear the buffer
for(i=0; i<sizeof(InBuff); i++)
InBuff[i]=0;
do{
fputs("AT\r\n",GSM);
fputs(InBuff,COM);
40,000,000 OR 3,980,000 |
Posted: Thu Dec 16, 2004 4:41 pm |
[quote="Anonymous"]Hiya,
#include <18F452.h>
#device adc=8
IF THE xTAL IS 3.98mhZ WHY ARE YOU USING A CLOCK = 40,000,000 |
Posted: Thu Dec 16, 2004 4:52 pm |
There are several things I noticed, but first try to comment out these
lines withing the do-while loop. See if you still get the error.
Code: | do{
// fputs("AT\r\n",GSM);
// delay_ms(1000);
// fputs(InBuff,COM);
while(1); |
Mark
Posted: Thu Dec 16, 2004 5:37 pm |
Check to make sure the device is not echoing the data back. Since you are sending string you might be getting it back and could be the cause of the problem. I don't know if CCS disables ints in the fputs() call, but if they do, then that's the problem. |
Posted: Thu Dec 16, 2004 5:51 pm |
Hi PCM,
Ok i have done that, i've used SIOM that comes with CCS, and i get diddly squat, nothing. PIN_E0 flashes once, OK, but i don't have any error LEDs lit. The 'COM' stream is wired into the remaining half of the MAX 232, and into the PC. As i imagined it would do.
Guest, the part is a resonator with built in caps. Marked as 4Mhz, but on Osc2 it shows 3.98Mhz.
Mark, i checked the status of the device, it has that option, but it is switched off. When i connect it the the PC (no PIC or anything else), i can send data, and nothing is echoed. I though it might have been a duff MAX232 or bad wiring. but the same wiring and chip talk to the PC with no problems. |
Posted: Thu Dec 16, 2004 6:17 pm |
OK, since the Error LED didn't light up, it means that one or more
of those lines in the do-while() loop is the problem. I don't have
that version of the compiler, so I can't examine the .LST file for you.
What I would be looking for is what Mark said: Is the compiler
disabling interrupts. The primary suspect for me would be the
delay_ms(1000) statement.
Try un-commenting each of those 3 lines, one at a time. If you
start to get the error, then that line will be the problem. Then we
(or someone) can look at the .LST file and find out why. |
Posted: Thu Dec 16, 2004 8:40 pm |
PCM,
I've checked them, and i get both errors on OERR and FERR when just "fputs("AT\r\n",GSM); is the only working line. I am about to change the command with fprintf to see the response, but don't think it'l make any difference.
Where to i send the LST file, would i post it here or directly to those concerned?
Thanks |
Posted: Thu Dec 16, 2004 9:17 pm |
You don't have to post it. I looked at the .LST file for vs. 3.188.
It's as Mark said. CCS is disabling global interrupts during the fputs(). (They do the same thing during fprintf). |
Posted: Thu Dec 16, 2004 10:04 pm |
But i would have thought that would be a problem, i've used the same routine ages ago on an 16f877A
what do i do? |
Posted: Fri Dec 17, 2004 1:34 am |
I mean't "wounldn't".
Quote: |
But i would have thought that would be a problem, i've used the same routine ages ago on an 16f877A |
I've been up late. |
asmallri
Joined: 12 Aug 2004 Posts: 1646 Location: Perth, Australia
Posted: Fri Dec 17, 2004 4:01 am |
Code: | #byte RCREG =0xFAE
#bit OERR =RCREG.1
#bit FERR =RCREG.2
#bit CREN =RCREG.4 |
I suggest you go to bed. You are looking at the wrong address. You want the RCSTA register for these control bits not the RCREG
If you want to clear the buffer you should do it before you enable the serial interrupt _________________ Regards, Andrew
