Jerry Finsen Guest
PCH - IO Problem |
Posted: Thu Mar 20, 2003 2:56 pm |
I have a series of programs that worked fine on a 16F877 that I am porting to an 18F458. My Keyboard routines that work fine on the 877 do not work on the 458. I have been able to strip the code to the minimum amount that demonstrates the problem.
I suspect I am missing something simple --- like a fuse or something. Spent two days on this --- time to look for help.
I am running 3.148 of the compiler on a Win2k machine. Target board is the Micro Engineering X1 Board.
#ifdef __PCH__
#include <18F458.h>
#fuses HS,NOWDT,WDT1,NOLVP
#else
#include <16f877.h>
#fuses HS,NOWDT,NOLVP
#use rs232(baud=9600, parity=n, xmit=PIN_C6, rcv=PIN_C7, bits=8)
#use FAST_IO(B)
void KbdInit(void);
unsigned ReadKeyboard(int1 Hold);
unsigned Key;
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_CLOCK_DIV_2);
setup_psp(PSP_DISABLED);
setup_spi(FALSE);
setup_timer_0(RTCC_INTERNAL);
setup_timer_1(T1_INTERNAL|T1_DIV_BY_8);
#ifdef __PCH__
setup_comparator(FALSE);
setup_wdt(WDT_OFF);
KbdInit();
while(1){
Key = ReadKeyboard(1);
if (Key>0)
printf("\n\r KeyPress = \%d", Key);
void KbdInit(void)
port_b_pullups(TRUE);
unsigned Mask, Col, Row, Key;
/* See if any keys are pressed */
SET_TRIS_B(0);
OUTPUT_B(0);
SET_TRIS_B(0xF0);
Key = INPUT_B();
if (Key == 0xF0)
return(0);
/* When no Key is pressed, "Key" contains:
0x00 on the 18F458 and
0xF0 on the 16F877
0xF0 is the desired response
printf("\n\n\rKey Press \%2X", Key);
//* Code Snipped
return(0);
___________________________
Original Post ID: 12894 |
Neutone
Re: PCH - IO Problem |
Posted: Thu Mar 20, 2003 4:16 pm |
:=I have a series of programs that worked fine on a 16F877 that I am porting to an 18F458. My Keyboard routines that work fine on the 877 do not work on the 458. I have been able to strip the code to the minimum amount that demonstrates the problem.
:=I suspect I am missing something simple --- like a fuse or something. Spent two days on this --- time to look for help.
:=I am running 3.148 of the compiler on a Win2k machine. Target board is the Micro Engineering X1 Board.
:=#ifdef __PCH__
:= #include <18F458.h>
:= #fuses HS,NOWDT,WDT1,NOLVP
:=#else
:= #include <16f877.h>
:= #fuses HS,NOWDT,NOLVP
:=#endif
:=#use delay(clock=20000000)
:=#use rs232(baud=9600, parity=n, xmit=PIN_C6, rcv=PIN_C7, bits=8)
:=#use FAST_IO(B)
:=void KbdInit(void);
:=unsigned ReadKeyboard(int1 Hold);
:=void main() {
:=unsigned Key;
:= setup_adc_ports(NO_ANALOGS);
:= setup_adc(ADC_CLOCK_DIV_2);
:= setup_psp(PSP_DISABLED);
:= setup_spi(FALSE);
:= setup_timer_0(RTCC_INTERNAL);
:= setup_timer_1(T1_INTERNAL|T1_DIV_BY_8);
:= setup_timer_2(T2_DISABLED,0,1);
:= #ifdef __PCH__
:= setup_timer_3(T3_DISABLED|T3_DIV_BY_1);
:= setup_comparator(FALSE);
:= setup_wdt(WDT_OFF);
:= #endif
:= KbdInit();
:= while(1){
:= Key = ReadKeyboard(1);
:= if (Key>0)
:= printf("\n\r KeyPress = \%d", Key);
:= port_b_pullups(TRUE);
:= unsigned Mask, Col, Row, Key;
:= /* See if any keys are pressed */
:= SET_TRIS_B(0);
:= OUTPUT_B(0);
:= SET_TRIS_B(0xF0);
:= Key = INPUT_B();
:= if (Key == 0xF0)
:= return(0);
:=/* When no Key is pressed, "Key" contains:
:= 0x00 on the 18F458 and
:= 0xF0 on the 16F877
:= 0xF0 is the desired response
:=printf("\n\n\rKey Press \%2X", Key);
:=//* Code Snipped
:= return(0);
It may be as simple as using a delay to allow the port to change directions before reading it. It takes a noticable time for it to switch directions.
SET_TRIS_B(0xF0);
delay_cycles(2);
Key = INPUT_B();
Original Post ID: 12900 |
Jerry Finsen Guest
Posted: Thu Mar 20, 2003 4:36 pm |
It was that simple! Thanks. Now to find where in the Data Sheet that little bit of information is found! It must be in there somewhere.
Thanks again
jerry
:=It may be as simple as using a delay to allow the port to change directions before reading it. It takes a noticable time for it to switch directions.
:=SET_TRIS_B(0xF0);
:=delay_cycles(2);
:=Key = INPUT_B();
Original Post ID: 12901 |
