16c745JW
hillcraft
16c745JW
PostPosted: Mon Mar 17, 2003 5:12 am     Reply with quote
I inadvertently code protected this device. I have erased the device a number of times but the code protection bit still comes up as being illigal.
Is there a way to revive the chip.
___________________________
Original Post ID: 12761
Tomi
Re: 16c745JW
PostPosted: Mon Mar 17, 2003 9:28 am     Reply with quote
You can try to expose the chip for more than a day (use a fan if your UV lamp dissipates too much power).
In 1999 I did it with 4 pcs 16C74JW (well, the result was 75\% Smile : 3 out of 4 deleted successfully )
Good luck
:=I inadvertently code protected this device. I have erased the device a number of times but the code protection bit still comes up as being illigal.
:=Is there a way to revive the chip.
Original Post ID: 12768
