12F1572 DAC problems
stivio
PostPosted: Sat Jan 03, 2026 6:39 am     Reply with quote
Hello all,
I am trying to get something from the DAC of the 12F1572, but nothing works.
Now, I am trying to get only DAC function but still dont work.
The output is connected to a multimeter, not loaded.
Tnak you for your help!
the code:
[code]
#include <12F1572.h>
#fuses NOWDT,NOMCLR,NOPROTECT,NOLVP,INTRC_IO
#use delay (internal=8MHz)
setup_oscillator( OSC_8MHZ );
OUTPUT_A(0b00000000);
setup_vref (VREF_ON | VREF_ADC_OFF | VREF_COMP_DAC_4V096 | TEMPERATURE_INDICATOR_DISABLED);
setup_dac(DAC_OUTPUT | DAC_FVR);
dac_write (20);
delay_ms(5);
[/code]
stivio
PostPosted: Sat Jan 03, 2026 7:20 am     Reply with quote
The original problem solved:
Even the PICKIT3 is loading the output, so after removing connection, I get voltage from the DAC.
But some intresting news...
In case, when the DAC_FVR selected in setup, the register value is (A2) 10100010.
In case of DAC_VDD the output is 10100000.
according the datasheet it should be 10101000 and 10100000.
(my curiosity... I just checked... In case of DAC_VREF 10100001 ->it should be 10100100)
The wrong 2 bits are modified in the register, so needed to change them in the header files.
