vtrx
| 12F675 INt RA |
Posted: Mon Sep 15, 2025 5:06 am |
I'm using a PIC 12F675 and would like to know if I can use #INT_RA and #int_ext each with their own routine.
It seems not, so I combined the routines using #INT_RA.
I use pins A3 and A2.
How can I know which one the event occurred on, and could I use one or the other within the interrupt routine depending on which pin changed state?
One routine is triggered by a zero crossing, and the other is to read an infrared remote control that uses Timer1.
| Code: | #include "12f675.h"
#FUSES INTRC //Internal RC Osc
#use fast_io(a)
setup_adc(ADC_OFF);
setup_vref(FALSE);
// SETUP_TIMER_1(T1_INTERNAL|T1_DIV_BY_2);
set_tris_a(0b00111110);
port_a_pullups(0b00110010);
// ext_int_edge(L_TO_H);
// enable_interrupts(INT_EXT);
clear_interrupt(INT_RA);
// enable_interrupts(INT_RA2);
enable_interrupts(INT_RA2 | INT_RA3);
// disable_interrupts(INT_TIMER1);
// disable_interrupts(INT_TIMER0);
If anyone has a better idea, please comment.
I thought about using one pic for infrared and another for zero cross. |
Posted: Mon Sep 15, 2025 7:52 am |
OK. The INT_RA on this chip is like the INT_RB on most of the similar
small chips. If enabled, the interrupt is triggered when the pin changes.
_Changes_. So this interrupt happens on both the rising and falling
edge of the selected pins. Now unlike the older chips, this chip does have
a mask bit for each pin, and it is this mask the the INT_RA1 etc., control.
There is no ability n this interrupt to know which pin triggered. However
you also cannot clear this interrupt, until a read is done from the
register. So what you have to do is read the pins and decide in your code
which one(s) have changed.
So the big question is do you want interrupts to be on both edges of
any of your signals. If the answer is 'only one', then instead of doing what
you are suggesting, enable INT_EXT instead of RA2 (this is the pin this
interrupt is on), and program it's edge. Then just enable RA3 for INT_RA,
and in the INT_RA handler, read this pin to know which edge has triggered.
You then have a separate enable for INT_EXT, and handler for this.
There are actually three ways of generating signal change interrupts on this
chip@
INT_RA (on any of the I/O pins)
INT_EXT (on RA2), and
INT_COMP (on pin RA1).
The latter can be setup to interrupt when this pin passes the voltage
from the internal DAC. This like INT_RA is on both edges of the change.
The latter two interrupts have the advantage of happening on just a
single pin.
There is an example with the compiler of port B interrupt on change. |
vtrx
Posted: Mon Sep 15, 2025 2:00 pm |
| I'm going to do some experiments here. |
