about CHECKSUM
scanan
about CHECKSUM
PostPosted: Fri Sep 12, 2025 9:20 am     Reply with quote
after compiling my code I get a warning like that
>>> Warning 204 "C:\TX\TX.c" Line 128(1,1): Condition always FALSE CHECKSUM
I am using #ID CHECKSUM
what's that mean
compiler version 5.115
pic used PIC18F65K40
cheers
Dr Suleyman CANAN
R&D Electronic Engineer
https://suleymancanan.wordpress.com
Do whatever you do with amateur spirit -
But always feel professional.
PostPosted: Fri Sep 12, 2025 11:30 am     Reply with quote
You need to show us what you are doing.
It sounds as if you are misusing the #id statement. Possibly as if it is a
program statement, rather than a preprocessor command.
asmallri
Re: about CHECKSUM
PostPosted: Fri Sep 12, 2025 8:17 pm     Reply with quote
scanan wrote:
what's that mean
cheers
As Ttelmah said, you have not provided enough information to determine where the problem. Here is an example of the type of issue that could result in such a warrning:
bootlean mytest = FALSE;
// some other code here where mytest is assigned a value based on your program logic
// now an examle of an invalid test using = assignment operator instead of ==  test
if (mytest = FALSE){
// do something...
So what was supposed to happen was the variable mytest was being checked to see if it is equal to FALSE (zero) but what actually happened was mytest was assigned the static value of FALSE and as a result the if slatement is ALWAYS evaluated to FALSE
The compiler detects this abnormal test and hence produced the message you are seeing.
Regards, Andrew
