GAMCH96
| INTERFACE DHT11 PIC16F876 PLACE I HAVE PROBLEM MESUREMENT |
Posted: Wed Aug 13, 2025 9:10 am |
// Interfacing PIC16F877A with DHT11 sensor
// http://ccspicc.blogspot.com/
// electronnote@gmail.com
//LCD module connections PUERTO B
#define LCD_RS_PIN PIN_B0
#define LCD_RW_PIN PIN_B1
#define LCD_ENABLE_PIN PIN_B2
#define LCD_DATA4 PIN_B3
#define LCD_DATA5 PIN_B4
#define LCD_DATA6 PIN_B5
#define LCD_DATA7 PIN_B6
//End LCD module connections
#include <16F876.h>
#use delay(clock = 8000000)
#use rs232 (BAUD=9600, XMIT=PIN_C6, RCV=PIN_C7) // Tx a 9600 BAUDS VIA RS-232 STANDAR
#include <lcd4x20b.c>
#use fast_io(A)
// Connection pin between PIC16F877A and DHT11 (RHT01) sensor ENTRADA RA0
#BIT Data_Pin = 0x05.0 // Pin mapped to PORTA.0
#BIT Data_Pin_Direction = 0x85.0 // Pin direction mapped to TRISA.0
char message1[] = "Temp = 00.0 C";
char message2[] = "RH = 00.0 %";
short Time_out ;
unsigned int8 T_byte1, T_byte2, RH_byte1, RH_byte2, CheckSum ;
unsigned int16 Temp, RH;
void start_signal()
Data_Pin_Direction = 0; // Configure connection pin as output
Data_Pin = 0; // Connection pin output low
delay_ms(25);
Data_Pin = 1; // Connection pin output high
delay_us(30);
Data_Pin_Direction = 1; // Configure connection pin as input
short check_response()
delay_us(40);
if(!Data_Pin)
{ // Read and test if connection pin is low
delay_us(80);
if(Data_Pin)
{ // Read and test if connection pin is high
delay_us(50);
return 1;
unsigned int8 Read_Data()
unsigned int8 i, k, _data = 0; // k is used to count 1 bit reading duration
if(Time_out)
for(i = 0; i < 8; i++)
k = 0;
while(!Data_Pin)
{ // Wait until pin goes high
k++;
if (k > 100)
Time_out = 1; break;
delay_us(1);
delay_us(30);
if(!Data_Pin)
bit_clear(_data, (7 - i)); // Clear bit (7 - i)
bit_set(_data, (7 - i)); // Set bit (7 - i)
while(Data_Pin)
{ // Wait until pin goes low
k++;
if (k > 100) {Time_out = 1; break;}
delay_us(1);
return _data;
setup_adc_ports(NO_ANALOGS); // Configure AN pins as digital
lcd_init(); // Initialize LCD module
lcd_putc('\f'); // LCD clear
Time_out = 0;
Start_signal();
if(check_response())
{ // If there is response from sensor
RH_byte1 = Read_Data(); // read RH byte1
RH_byte2 = Read_Data(); // read RH byte2
T_byte1 = Read_Data(); // read T byte1
T_byte2 = Read_Data(); // read T byte2
Checksum = Read_Data(); // read checksum
if(Time_out)
{ // If reading takes long time
lcd_gotoxy(5, 1); // Go to column 5 row 1
lcd_putc("Time out!");
if(CheckSum == ((RH_Byte1 + RH_Byte2 + T_Byte1 + T_Byte2) & 0xFF)){
RH = RH_byte1;
RH = (RH << 8) | RH_byte2;
Temp = T_byte1;
Temp = (Temp << 8) | T_byte2;
if (Temp > 0X8000){
message1[6] = '-';
Temp = Temp & 0X7FFF; }
message1[6] = ' ';
message1[7] = (Temp / 10) % 10 + 48;
message1[8] = (Temp / 10) % 10 + 48;
message1[10] = Temp % 10 + 48;
message1[6] = ' ';
message2[7] = (RH / 10) % 10 + 48;
message2[8] = (RH / 10) % 10 + 48;
message2[10] = RH % 10 + 48;
message1[11] = 223;
// Degree symbol
lcd_gotoxy(1, 1); // Go to column 1 row 1
printf(lcd_putc, message1); // Display message1
lcd_gotoxy(1, 2); // Go to column 1 row 2
printf(lcd_putc, message2); // Display message2
// Envio RS232
// Envio RS232
printf("%c%c.%c,",message1[7],message1[8],message1[10]);
printf("%c%c.%c,",message2[7],message2[8],message2[10]);
printf("\n\r"); // Display message2
However, as you can see in the photograph, the result is incorrect. The intended result is to obtain the temperature and humidity values, as shown below, with a variation in the LCD text:
Temp = 22.7 C
RH = 66.3%
I'm trying to figure out what I'm doing incorrectly in the conversion operations. Is it something I can't understand, or am I using the printf(lcd_putc,)-… command incorrectly? I don't know???
Please... Any help you can give me on the correct way to write the code submitted for your consideration, I would appreciate it.
Without further ado, please accept greetings from Mexico.
Thank you for your attention.
Gustavo Adolfo Martinez Chavez. |
Posted: Thu Aug 14, 2025 2:15 am |
Of course it is.....
Look at your code:
You have exactly the same maths being performed for the 7th and
eight characters. Result the same value in each character....
You need:
/100
/10
/1 (not actually needed).
For the three characters. |
GAMCH96
Posted: Thu Aug 14, 2025 11:45 am |
Thank you, I am so grateful..  |
GAMCH96
Posted: Thu Aug 14, 2025 12:00 pm |
Thank you for you help...
And the end code.....
#include <16F876.h>
#use fast_io(A)
short Time_out ;
void start_signal()
delay_ms(25);
delay_us(30);
delay_us(40);
if(!Data_Pin)
delay_us(80);
if(Data_Pin)
delay_us(50);
return 1;
if(Time_out)
k = 0;
while(!Data_Pin)
k++;
if (k > 100)
delay_us(1);
delay_us(30);
if(!Data_Pin)
while(Data_Pin)
k++;
delay_us(1);
return _data;
Time_out = 0;
Start_signal();
if(Time_out)
RH = RH_byte1;
Temp = T_byte1;
if (Temp > 0X8000){
message1[6] = '-';
message1[6] = ' ';
Temp=Temp%100;
Temp=Temp%10;
message1[6] = ' ';
RH=RH%100;
RH=RH%10;
message1[11] = 223;
// Degree symbol
// Envio RS232
// Envio RS232
delay_ms(2000);
