SkeeterHawk
Joined: 16 Oct 2010 Posts: 57 Location: Florissant, CO
| Suddenly out of ROM |
Posted: Mon Aug 04, 2025 11:37 am |
Hello programming Friends!
I had a weird issue that I can definitely work around, but I wanted to see if someone had an opinion as to what happened. I am using a PIC18F57Q84 with compiler version 5.114. I am loading an EEPROM with entries for a look-up table, so this is just a lot of monotonous code. I compiled about 7000 lines of code, and it said that I had used 52% of my available ROM. I wrote 2000 more lines, and the compiler "choked". Here is what it said
| Code: | ***Error 71 "C:\Pic....Main.c"Line 230(1,2); Out of ROM, A segment or the program is too large WriteAllValuesToEEPROM
Seg 00068-0FFFE, F1BC left, need 11EF0
Seg 10000-1FFFE, 0000 left, need 11EF0
Seg 00000-00002, 0000 left, need 11EF0 Reserved
Seg 00004-00006, 0004 left, need 11EF0
Seg 00008-00066, 0000 left, need 11EF0 Reserved
1 Errors
Build Failed. |
So, I commented out the extra lines so that it would compile, and it loaded the data into the EEPROM without a hitch.
Previously, about 2000 lines of code was taking around 10% of the ROM, so I expected it to be 62% when I got done writing, not to choke and say I was out of ROM. Is there a limit to how much ROM a single file can use or something?
Again, I can work around this regardless, but it would be good to know why I had 48% of my ROM magically vanish. Thanks for the input! _________________ Life is too short to only write code in assembly... |
Jerson
Joined: 31 Jul 2009 Posts: 132 Location: Bombay, India
Posted: Mon Aug 04, 2025 8:19 pm |
| Usually, what this means is the code / a part of it doest not fit into a memory segment. The way you can resolve this is to look into making certain parts SEPARATE (keyword) |
Posted: Tue Aug 05, 2025 7:59 am |
Yes. Jerson is spot on.
The point is you don't have one single 'lump' of program memory, it is
divided into pages. Your code doing this job it being built as one 'lump',
so when you went over 50%, it will no longer fit into the page. Previously,
at 52%, you probably had several other bits occupying perhaps just a few
percent of this, that the compiler could put into another page, so you had this in one page and then just under 50% in the second. Now this single lump
will no longer fit.
You need to split it and it can then fit.... |
Joined: 01 Jul 2010 Posts: 9598 Location: Greensville,Ontario
Posted: Tue Aug 05, 2025 9:52 am |
you may be able to break down the HUGE lookup table into 'segment fitting' chunks.
IE if it's a graphic database, consider segments for 'upper case', 'lower case' 'special symbols'. You'll need to add a simple 'test' to goto the correct table of course. |
SkeeterHawk
| Thanks for the input!! |
Posted: Tue Aug 05, 2025 12:19 pm |
Thank you all for the input on this. I suspected that something like this is the issue, but I am a little surprised that I have never run into this before. So if I was writing this in assembly, would it just stop assembling the code unless I put a new Origin statement in the middle of it somewhere? Obviously this is a function of the hardware and would carry over into assembly as well, so I am just curious.
Thanks again for all of your input!!  _________________ Life is too short to only write code in assembly... |
dyeatman
Posted: Tue Aug 05, 2025 12:40 pm |
If you go to PIC24 or DsPIC the problem goes away... _________________ Google and Forum Search are some of your best tools!!!! |
SkeeterHawk
Posted: Tue Aug 05, 2025 2:08 pm |
| dyeatman wrote: | | If you go to PIC24 or DsPIC the problem goes away... |
Good to know!! Thanks for the tip! I'd post a thumbs up...if there was one...  _________________ Life is too short to only write code in assembly... |
| Re: Thanks for the input!! |
Posted: Fri Aug 08, 2025 1:52 am |
| SkeeterHawk wrote: | Thank you all for the input on this. I suspected that something like this is the issue, but I am a little surprised that I have never run into this before. So if I was writing this in assembly, would it just stop assembling the code unless I put a new Origin statement in the middle of it somewhere? Obviously this is a function of the hardware and would carry over into assembly as well, so I am just curious.
Thanks again for all of your input!!  |
It is actually quite hard in assembler. The default options do not allow code to
be larger than a page. You have to specify that thesis supported, and then
use long jumps or calls to cross between segments. |
Posted: Sun Aug 10, 2025 2:17 pm |
this 'thread' got me wondering why it's 'hard to do'. 4 decades ago I did a fair amount of 8052 BASIC programming and recall they had some command ( XBY ??) that would access the ROM bank. 8052s went to HARVARD just like PICs.
I understand there's the 'jumping' from bank to bank issue ,but can't that be dealt with ?
OK my minds a tad fuzzy, being 40*C here, just curious that no one's made a 'driver' or 'patch' or 'function' or whatever you'd call the code . |
Posted: Sun Aug 10, 2025 11:56 pm |
Absolutely.
It is not really 'hard', but slightly 'awkward'.
Build in two separate segments, and then use the long jump between.
The awkwardness comes from the default assembly behaviour, which is
to always build in one page. You have to explicitly override this.
In this case, it is not worth worrying about. Just split the table building
code into three or four parts, and the compiler can then juggle these with
the other routines to make the optimum fit. |
