SD CARD CCS C
Goto page Previous  1, 2, 3, 4
PostPosted: Tue Jul 22, 2025 4:56 am     Reply with quote
Reading any file is easy, you open the file, read a record, increment a counter, read the next , repeat...until end of file. Same for .bmp as it is for .txt files
However I suspect you actually want to DISPLAY an image stored as a .bmp file ?
ilker07
PostPosted: Wed Jul 23, 2025 6:02 am     Reply with quote
void bmp_draw(char *filename) {
FILE myfile;
unsigned int8 header[BMP_HEADER_SIZE];
unsigned int32 width, height, dataOffset;
unsigned int32 rowSize, padding;
unsigned int16 x, y;
unsigned int16 r, g, b;
if (fatopen(filename, "rb", &myfile) != 0) {
fprintf(SCREEN, "BMP OPEN ERROR\n");
return;
fatseek(&myfile, 0, SEEK_SET);
// BMP header
for (int i = 0; i < BMP_HEADER_SIZE; i++) {
int ch = fatgetc(&myfile);
fprintf(SCREEN,"%c ",ch);
if (ch == EOF) {
fprintf(SCREEN, "BMP HEADER READ ERROR\n");
fatclose(&myfile);
return;
header[i] = (unsigned char)ch;
fprintf(SCREEN,"\n ");
// ("BM")
if (header[0] != 'B' || header[1] != 'M') {
fprintf(SCREEN, "NOT A BMP FILE\n");
fatclose(&myfile);
return;
unsigned int32 val0,val1,val2,val3,val4,val5,val6,val7,val8,val9,val10,val11;
val0=header[18];
val1=header[19];
val1=val1<<8;
val2=header[20];
val2=val2<<16;
val3=header[21];
val3=val3<<24;
val4=header[10];
val5=header[11];
val5=val5<<8;
val6=header[12];
val6=val6<<16;
val7=header[13];
val7=val7<<24;
val8=header[22];
val9=header[23];
val9=val9<<8;
val10=header[24];
val10=val10<<16;
val11=header[25];
val11=val11<<24;
dataOffset = val4 | val5 | val6 | val7;
width = val0 | val1 | val2 | val3;
height = val8 | val9 | val10 | val11;
rowSize = (width * 3 + 3) ;
unsigned int32 temp;
temp= (~3);
rowSize=rowSize & 0xFFFFFFFCUL;
padding = rowSize - (width * 3);
fatseek(&myfile, dataOffset, SEEK_SET);
for (y = 0; y < height; y++) {
for (x = 0; x < width; x++) {
b = fatgetc(&myfile);
g = fatgetc(&myfile);
r = fatgetc(&myfile);
if (b == EOF || g == EOF || r == EOF) {
fprintf(SCREEN, "BMP PIXEL READ ERROR\n");
fatclose(&myfile);
return;
// RGB888 › RGB565
unsigned int16 color = ((r & 0xF8) << 8) |
((g & 0xFC) << 3) |
(b >> 3);
drawPixel(x, height - 1 - y, color);
// i padding bytes
for (unsigned int p = 0; p < padding; p++) {
if (fatgetc(&myfile) == EOF) {
fatclose(&myfile);
return;
fatclose(&myfile);
I can do this with this way but it is too slow .What can I do??
ilker07
PostPosted: Wed Jul 30, 2025 2:48 am     Reply with quote
in main.c
#use delay(clock=80000000,crystal=20000000)
in mmcsd_m.c
MMCSD_err mmcsd_init()
setup_timer_2(T2_DIV_BY_16, 1, 1);//for spi clock
uint8_t
i,
r1,
r3[4];
g_CRC_enabled = TRUE;
g_mmcsdBufferAddress = 0;
output_drive(MMCSD_PIN_SELECT);
#ifdef MMCSD_SPI_HW
setup_spi(SPI_MASTER | SPI_H_TO_L | SPI_CLK_T2 | SPI_XMIT_L_TO_H);
with this way,it does not work...
in main.c
#use delay(internal=16000000) it draws bmp file in 70 seconds??
PostPosted: Wed Jul 30, 2025 5:11 am     Reply with quote
Curious, downloaded the 18f67k22 datasheet...
I'm surprised you don't get an error message about the clock speed.
a 67k22 max clock is 64MHz.
you should get into the habit of adding //comments at the end of most lines of code. Makes it easier for everyone to understand what you're trying to do.
gaugeguy
PostPosted: Wed Jul 30, 2025 6:08 am     Reply with quote
Also the input of the PLL is only rated for 4MHz to 16MHz.
Do not attempt to overclock.
ilker07
PostPosted: Wed Jul 30, 2025 7:03 am     Reply with quote
when I use #use delay(internal=16MHz) ,I get same result...
setAddressWindow(startX, startY, width-1, height-1); //0, 0, 479, 319
PORTD &= ~(1 << 4);
PORTD |= (1 << 3);
for (y = 0; y < height; y++) { //320
for (x = 0; x < width; x++) { //480
unsigned int16 color = ((r & 0xF8) << 8) | ((g & 0xFC) << 3) |(b >> 3);
unsigned char high_byte = (color >> 8) & 0xFF;
unsigned char low_byte = color & 0xFF;
write_bus(high_byte);
PORTD &= ~(1 << 2);
PORTD |= (1 << 2);
write_bus(low_byte);
PORTD &= ~(1 << 2);
PORTD |= (1 << 2);
for (unsigned int16 p = 0; p < padding; p++) {fatgetc(&myfile);}
PORTD |= (1 << 4);
mmcsd_m.c
//setup_timer_2(T2_DIV_BY_4, 24, 1);//625 khz timer cikisi bunun yarisi spi icin
uint8_t
i,
r1,
r3[4];
#ifdef MMCSD_SPI_HW
setup_spi(SPI_MASTER | SPI_H_TO_L | SPI_CLK_DIV_64 | SPI_XMIT_L_TO_H);//SPI_CLK_T2 SPI_CLK_DIV_64
#else // Software SPI
output_drive(MMCSD_PIN_SCK);
output_drive(MMCSD_PIN_SDO);
output_float(MMCSD_PIN_SDI);
#endif
mmcsd_deselect();
delay_ms(250);
for(i = 0; i < 10; i++) // Send 80 cycles
MMCSD_SPI_XFER(0xFF);
/* begin initialization */
i = 0;
do
delay_ms(1);
mmcsd_select();
r1 = mmcsd_go_idle_state();
mmcsd_deselect();
i++;
if(i == 0xFF) {
if (r1 == 0)
return 1;
return r1;
} while(r1 != MMCSD_IDLE);
i = 0;
do
delay_ms(1);
mmcsd_select();
r1 = mmcsd_send_op_cond();
mmcsd_deselect();
i++;
} while((r1 & MMCSD_IDLE) && i != 0xFF);
if(i == 0xFF) {
mmcsd_select();
mmcsd_deselect();
mmcsd_select();
r1 = mmcsd_send_if_cond(r3);
mmcsd_deselect();
if(r1 != MMCSD_IDLE)
return r1;
/* figure out if we have an SD or MMC */
i = 0;
do {
mmcsd_select();
r1=mmcsd_app_cmd();
r1=mmcsd_sd_send_op_cond();
mmcsd_deselect();
i++;
} while((r1 == MMCSD_IDLE) && (i != 0xFF));
if(r1 == MMCSD_IDLE)
return r1;
/* an mmc will return an 0x04 here */
if(r1 == 0x04)
g_card_type = MMC;
else {
g_card_type = SDSC;
mmcsd_select();
r1 = mmcsd_read_ocr(r3);
mmcsd_deselect();
if(r1 != MMCSD_ILLEGAL_CMD) {
r1 = r3[3];
if(bit_test(r1, 6)) // If bit 30 of the OCR register is 1 (CCS is 1) ==> SDHC type
g_card_type = SDHC;
/* set block length to 512 bytes */
mmcsd_select();
r1 = mmcsd_set_blocklen(MMCSD_MAX_BLOCK_SIZE);
mmcsd_deselect();
if(r1 != MMCSD_GOODEC)
return r1;
/// this would be a good time to set a higher clock speed, 20MHz
#ifdef MMCSD_SPI_HW
setup_spi(SPI_MASTER | SPI_H_TO_L | SPI_XMIT_L_TO_H | SPI_CLK_DIV_4);
#else
//#use spi(MASTER, DI=MMCSD_PIN_SDI, DO=MMCSD_PIN_SDO, CLK=MMCSD_PIN_SCK, BITS=8, MODE=3,baud=10000000) //
#use SPI(MASTER, SPI1, BITS=8, MODE=3,baud=20000000,STREAM=SDCARD) //
#endif
// Turn OFF CRC check, some card return 0 (MMCSD_GOODEC) and some others return 0x04 (MMCSD_ILLEGAL_CMD)
mmcsd_select();
r1 = mmcsd_crc_on_off(FALSE);
mmcsd_deselect();
r1 = mmcsd_load_buffer();
return MMCSD_GOODEC;
ilker07
PostPosted: Wed Jul 30, 2025 7:05 am     Reply with quote
I used this way so many times by overclocking
PostPosted: Wed Jul 30, 2025 7:18 am     Reply with quote
Keep overclocking the PIC and it'll turn into a brick, you'll have to toss out.
In the meantime, many peripherals aren't rated for that speed and of course PCB design HAS to be 100% designed and made for that speed.
ilker07
PostPosted: Wed Jul 30, 2025 8:40 am     Reply with quote
right now I use interal 16 mhz
PostPosted: Wed Jul 30, 2025 1:00 pm     Reply with quote
these...
.. look wrong.
CCS C treas 'char' as an unsigned integer.
while not a real 'problem', I have to wonder AI 'created' the program ?
Lack of comments doesn't help.
Maybe post what the current problem is !
ilker07
PostPosted: Wed Jul 30, 2025 3:08 pm     Reply with quote
It draws the bmp file very well but in 80 seconds!! lookslike spi speed around 100khz
PostPosted: Wed Jul 30, 2025 4:04 pm     Reply with quote
you don't show your complete program but there are a lot of delays, including a 100ms one in what you post.
I suggest you break it down into 2 parts
1) setup / init the SDcard...
2) read the datafile.bmp but do NOT doing any 'processing'.Just read a record, loop until all read in.
time #2, see if it takes 80 seconds
SPI speed should be faster but can't tell how you're really configured it.
ilker07
PostPosted: Thu Jul 31, 2025 12:28 am     Reply with quote
main.c
#include <18F67K22.h>
#device PASS_STRINGS = IN_RAM
#FUSES NOWDT
#FUSES WDT128
#FUSES NOXINST
#FUSES NOBROWNOUT
#FUSES PROTECT
#FUSES NOMCLR
// TFT Pinleri
#define TFT_D0 PIN_F1
#define TFT_D1 PIN_E7
#define TFT_D2 PIN_F7
#define TFT_D3 PIN_F6
#define TFT_D4 PIN_F5
#define TFT_D5 PIN_F4
#define TFT_D6 PIN_F3
#define TFT_D7 PIN_F2
#define TFT_RST PIN_E0
#define TFT_CS PIN_D4
#define TFT_RS PIN_D3
#define TFT_WR PIN_D2
#define TFT_RD PIN_C0
#define BMP_HEADER_SIZE 54
//#pragma use rs232(baud=19200, xmit=PIN_G1, rcv=PIN_G2, stream=SCREEN, errors)
#define MMCSD_SPI_HW
#define MMCSD_PIN_SCK PIN_C3 //o
#define MMCSD_PIN_SDI PIN_C4 //i
#define MMCSD_PIN_SDO PIN_C5 //o
#define MMCSD_PIN_SELECT PIN_E1 //o
#include <mmcsd_m.c>
#include <fat_m.c>
#use fast_io(D)
#use fast_io(C)
#byte PORTC = 0xF82
#byte PORTD = 0xF8C
#byte PORTE = 0xF84
#byte PORTF = 0xF85
void setAddressWindow(unsigned int16 x0, unsigned int16 y0, unsigned int16 x1, unsigned int16 y1);
void write_bus(unsigned char data);
void tft_pins_init() {
set_tris_f(0x00);
set_tris_e(0x00);
set_tris_d(0x00);
output_drive(PIN_C0);
void write_bus(unsigned char data) { // 07 E0 0000 0111 1110 0000 1111 1000 0000 0000
if(data & 0x01)
PORTF |= (1 << 1);
PORTF &= ~(1 << 1);
if(data & 0x02)
PORTE |= (1 << 7);
PORTE &= ~(1 << 7);
if(data & 0x04)
PORTF |= (1 << 7);
PORTF &= ~(1 << 7);
if(data & 0x08)
PORTF |= (1 << 6);
PORTF &= ~(1 << 6);
if(data & 0x10)
PORTF |= (1 << 5);
PORTF &= ~(1 << 5);
if(data & 0x20)
PORTF |= (1 << 4);
PORTF &= ~(1 << 4);
if(data & 0x40)
PORTF |= (1 << 3);
PORTF &= ~(1 << 3);
if(data & 0x80)
PORTF |= (1 << 2);
PORTF &= ~(1 << 2);
void tft_write_command(unsigned char cmd) {
PORTD &= ~(1 << 4);
PORTD &= ~(1 << 3);
write_bus(cmd);
PORTD &= ~(1 << 2);
PORTD |= (1 << 2);
PORTD |= (1 << 4);
void tft_write_data(unsigned char data) {
PORTD &= ~(1 << 4);
PORTD |= (1 << 3);
write_bus(data);
PORTD &= ~(1 << 2);
PORTD |= (1 << 2);
PORTD |= (1 << 4);
void tft_reset() {
output_low(TFT_RST);
delay_ms(20);
output_high(TFT_RST);
delay_ms(150);
void tft_init() {
tft_reset();
tft_write_command(0x01); // Software Reset
delay_ms(120);
tft_write_command(0x11); // Sleep Out
delay_ms(120);
tft_write_command(0x3A); // Interface Pixel Format
tft_write_data(0x55); // 16-bit/pixel RGB565
tft_write_command(0x36);//rotation
tft_write_data(0xA8); //0X28
tft_write_command(0x29); // Display ON
delay_ms(20);
void setAddressWindow(unsigned int16 x0, unsigned int16 y0, unsigned int16 x1, unsigned int16 y1) {
tft_write_command(0x2A); // Column Address Set
tft_write_data(x0 >> 8);
tft_write_data(x0 & 0xFF);
tft_write_data(x1 >> 8);
tft_write_data(x1 & 0xFF);
tft_write_command(0x2B); // Row Address Set
tft_write_data(y0 >> 8);
tft_write_data(y0 & 0xFF);
tft_write_data(y1 >> 8);
tft_write_data(y1 & 0xFF);
tft_write_command(0x2C); // Memory Write
void tft_fill_color(unsigned int16 color) {
setAddressWindow(0, 0, 479, 319);
output_low(TFT_CS);output_high(TFT_RS);
unsigned int16 y,x;
for (y = 0; y < 320; y++) {
for (x = 0; x < 480; x++) {
output_low(TFT_WR);
output_high(TFT_WR);
output_low(TFT_WR);
output_high(TFT_CS);
void bmp_draw(char *filename,unsigned int16 startX,unsigned int16 startY) {
FILE myfile;
// fprintf(SCREEN, "BMP OPEN ERROR\n");
return;
// BMP header
//fprintf(SCREEN,"%c ",ch);
if (ch == EOF) {
// fprintf(SCREEN, "BMP HEADER READ ERROR\n");
fatclose(&myfile);
return;
//fprintf(SCREEN,"\n ");
// BMP type control ("BM")
// fprintf(SCREEN, "NOT A BMP FILE\n");
fatclose(&myfile);
return;
val0=header[18];
val1=header[19];
val1=val1<<8;
val2=header[20];
val2=val2<<16;
val3=header[21];
val3=val3<<24;
val4=header[10];
val5=header[11];
val5=val5<<8;
val6=header[12];
val6=val6<<16;
val7=header[13];
val7=val7<<24;
val8=header[22];
val9=header[23];
val9=val9<<8;
val10=header[24];
val10=val10<<16;
val11=header[25];
val11=val11<<24;
// fprintf(SCREEN,"width:%lu height:%lu rowSize:%lu padding:%lu ",width,height,rowSize,padding);
PORTD &= ~(1 << 4);//cs low
PORTD |= (1 << 3);
PORTD &= ~(1 << 2);
PORTD |= (1 << 2);
PORTD &= ~(1 << 2);
PORTD |= (1 << 2);
PORTD |= (1 << 4); //cs pin
fatclose(&myfile);
void main(void) {
tft_pins_init();
output_low(PIN_E3);
output_high(TFT_RD);
tft_init();
tft_fill_color(0x001F);//blue
signed int8 i=0;
i = fat_init();
if(i!=0) output_high(PIN_E3);
bmp_draw("/mainPage.bmp",0,0);
delay_ms(3000);
bmp_draw("/runGreen.bmp",0,189);
while(TRUE) {
mmcsd_m.c
//setup_timer_2(T2_DIV_BY_4, 24, 1);// timer output
uint8_t
i,
r1,
r3[4];
#ifdef MMCSD_SPI_HW
#endif
mmcsd_deselect();
delay_ms(250);
i = 0;
do
delay_ms(1);
mmcsd_select();
mmcsd_deselect();
i++;
if(i == 0xFF) {
if (r1 == 0)
return 1;
return r1;
i = 0;
do
delay_ms(1);
mmcsd_select();
mmcsd_deselect();
i++;
if(i == 0xFF) {
mmcsd_select();
mmcsd_deselect();
mmcsd_select();
mmcsd_deselect();
return r1;
i = 0;
do {
mmcsd_select();
r1=mmcsd_app_cmd();
mmcsd_deselect();
i++;
return r1;
if(r1 == 0x04)
g_card_type = MMC;
else {
g_card_type = SDSC;
mmcsd_select();
mmcsd_deselect();
r1 = r3[3];
g_card_type = SDHC;
mmcsd_select();
mmcsd_deselect();
return r1;
#ifdef MMCSD_SPI_HW
setup_spi(FALSE); //DATASHEET says for re -initializing disable spi
#else
#use SPI(MASTER, SPI1, BITS=8, MODE=3,baud=4000000,STREAM=SDCARD) //
#endif
mmcsd_select();
mmcsd_deselect();
I think spi speed dos not change here!!
ilker07
PostPosted: Thu Jul 31, 2025 4:43 am     Reply with quote
setup_spi(FALSE);
Does this method change SPI speed?
Page 4 of 4
