No SPI clocks
JerryR
No SPI clocks
PostPosted: Tue Jul 15, 2025 9:58 am     Reply with quote
Hi Group, thanks for your help on this-
I am using PCWH v5.093 to compile code for a PIC18F86J60. I am posting a small snippet of code below. I am using the hardware SPI1 to talk to two external SPI devices
The problem is that using either of the use_spi setups, results in no clocks being issue when attempting to write to a SPI device. The Data Out looks reasonable, however, but no clock pulses.
If I comment out both spi_setup statements, I can generate clock pulses on the clock pin (PIN_C3), so there's nothing in the hardware blocking the clock pin.
This is probably something very simple, but I just can't see it. Here's the code:
#include <18F86J60.h>
#device ADC=10
#use delay(crystal=25000000)
#use spi (MASTER, DI=PIN_C4, DO= PIN_C5, CLK= PIN_C3, BITS=8, MODE=0)
//#use spi (MASTER, SPI1, BITS=8, MODE=0)
   setup_adc_ports(AN0_TO_AN1, VSS_VDD);
   setup_adc(ADC_CLOCK_INTERNAL | ADC_TAD_MUL_0);
   output_high(PIN_A3);
    output_low(PIN_A3);
    delay_us(10);
    spi_write (0x50);
    spi_write(0x00);
    spi_write(0xFF);
    delay_us(10);
PostPosted: Thu Jul 17, 2025 5:54 am     Reply with quote
Key thing. With #use SPI, you have to use spy_xfer, not spi_write.
You are mixing commands from setup_spi, with those from #use SPI.
You should also specify a clock rate. The default is as fast as possible.
If you look in the manual, under #use spi, you will have listed at the
bottom of the page, the commands that work with this.
JerryR
PostPosted: Thu Jul 17, 2025 7:45 am     Reply with quote
Hello Ttelmah:
Thank you so much for your interest!
Yes, the current version of my code uses the correct method and calls, thanks for your clairification. I see from research you have been kind to mention this to quite a few in the group.
Should have posted this yesterday, but my problem with no clocks was solved. BAD LOGIC ANALYSER PROBE! I actually did have clocks using a scope.
Sorry to have raised the question to the group. Lessons here is don't always trust your equipment.
Best regards!
JerryR
PostPosted: Sat Jul 19, 2025 11:37 am     Reply with quote
All:
I am trying to use "#USE_SPI" commands to read a MCP23S08 inputs. I can successfully set output to a MCP23S17 using SPI_XFER command, but can't seem to understand how to read inputs on a MCP23S08.
I have used the older method "SETUP_SPI" sucessfully with both MCP23S08 and MCP23S17, however can't seem to get my head around using SPI_XFER to read data. Result of attempting to read always generates clocks and transfers "0".
Any help is much appreciated
My SPI setup is:
#use spi(MASTER, SPI1, BITS=8, BAUD=100000, MODE=0)
And my code to read MCP23S08 is:
#define IODIR        0x00
#define IPOL         0x01
#define GPINTEN      0x02
#define DEFVAL       0x03
#define INTCON       0x04
#define THERM_IOCON  0x05
#define GPPU         0x06
#define INTF         0x07
#define INTCAP       0x08
#define GPIO         0x09
#define OLAT         0x0A
#define CONTROL_REG_VAL 0x40  //// these two defines are used here
#define CONTROL_REG_VAL_Read 0x41
#define GPIO_CONFIG_VAL 0x09  //// just to do very simple serial to parallel output transfer
void setup_MCP23S08(void){
int8  dummy;
output_low(THERM_CS);
delay_us(100);
dummy= spi_xfer(CONTROL_REG_VAL);      // control register setup
dummy= spi_xfer (IODIR);               // GPIO set to all inputs
dummy= spi_xfer (0xFF);                // GPIO set to all inputs
delay_us(100);
output_high(THERM_CS);
int8 ReadFrom_Thermo_Exp(void)
int8  received_Therm_data;
int8  dummy;
delay_us(10);
dummy= spi_xfer(CONTROL_REG_VAL_Read);
dummy= spi_xfer(GPIO_CONFIG_VAL);
received_Therm_data = spi_xfer(0);
delay_us(10);
return received_Therm_data;
void WriteToExpanderPort(unsigned char data){
int8  dummy;
delay_us(10);
dummy= spi_xfer(GPIO_CONFIG_VAL); // GPIO configuration
dummy= spi_xfer(data); // value to I/O
delay_us(10);
[/code]
PostPosted: Sun Jul 20, 2025 1:04 am     Reply with quote
Yes, if you look at the older posts about this, spy_write may work, in the
case where you are using the hardware pins on a non PPS chip. You were
doing this and the 'diagnosis' was just a faulty probe. Ouch.
A step forwards. Very Happy
Before looking at the code. What pull-up have you got on the A2/SO
line????.
Because of the way these chips are done with SPI/I2C, this is an open-
collector output only, and needs a pull-up resistor on this line. If it it
not pulled up, you would see only zeros, which is exactly what you
describe. So worth asking before looking at the code. They show 1KR.
Presumably you have A0/A1 pulled down?. Needs to be since you are sending 00 as the address bits.
JerryR
PostPosted: Sun Jul 20, 2025 7:58 am     Reply with quote
Ttelmah:
Your patience for my ignorance is to be commended! My fault again, everything is actually working fine. Logic analyser on wrong pin. I may be getting too old for this!Rolling Eyes
I'm driving data and CS lines with a PIC that has a complimentary output, so able to pull up and down, so I'm not using pull-ups at all (should I need them?). I'm using the SPI 'S' version of this expander
I do have a non-zero address (A0-A2), but HAEN is set to zero to ignore external address lines for now.
Again, pardon my ignorance, you are a great resource for the group. Best regards!
PostPosted: Mon Jul 21, 2025 6:47 am     Reply with quote
You should have a pull-up on the PIC's DI pin. The point is the SO line
on the peripheral does not guarantee a pull-up.
JerryR
PostPosted: Mon Jul 21, 2025 7:01 am     Reply with quote
I'll add that. Thanks again
