ciccioc74
Error#51 A numeric expression must appear here |
Posted: Tue Jul 08, 2025 2:58 am |
hi
ccs compiner v5.120 processor pic24fj256gb110
i can't use
Code: | enable_interrupts(INTR_GLOBAL); |
or
Code: | enable_interrupts(GLOBAL); |
the 24fj256gb110.h file:
Code: | // Constants used in other interrupt functions are:
#if getenv("VERSION") > 5.061
#define INTR_GLOBAL 0x0800
#define GLOBAL 0x0800 // For compatibility with PIC16/18
#define INTR_NORMAL 0x1000
#define INTR_ALTERNATE 0x2000
#define INTR_LEVEL0 0x3000
#define INTR_LEVEL1 0x3001
#define INTR_LEVEL2 0x3002
#define INTR_LEVEL3 0x3003
#define INTR_LEVEL4 0x3004
#define INTR_LEVEL5 0x3005
#define INTR_LEVEL6 0x3006
#define INTR_LEVEL7 0x3007
#else
#define INTR_GLOBAL 0x0400
#define GLOBAL 0x0400 // For compatibility with PIC16/18
#define INTR_NORMAL 0x0100
#define INTR_ALTERNATE 0x0200
#define INTR_LEVEL0 0x0500
#define INTR_LEVEL1 0x0501
#define INTR_LEVEL2 0x0502
#define INTR_LEVEL3 0x0503
#define INTR_LEVEL4 0x0504
#define INTR_LEVEL5 0x0505
#define INTR_LEVEL6 0x0506
#define INTR_LEVEL7 0x0507
i think "VERSION" is not recognized
Code: | #ZERO_RAM
#include <24FJ256GB110.h>
#device ADC=10
#device ICSP=2
#FUSES NODEBUG
#FUSES ICSP1
#FUSES NOWINDIS
#FUSES WPOSTS16
#FUSES IESO
#FUSES NOCKSFSM
#FUSES NOOSCIO
#FUSES HS
#FUSES NOIOL1WAY
#FUSES NOWPCFG
#FUSES NOWPDIS
#FUSES PR_PLL
#FUSES PLL3
#FUSES RESERVED
#FUSES DISUVREG
#use delay(clock=32000000,crystal=8000000)
#define LED3 PIN_C13
#define LED4 PIN_C14
//#priority INT_RDA2, INT_TIMER2 ,INT_RDA
int cont_1s=0;
volatile int temp;
#INT_TIMER2
void my_timer2_isr (){
if(++cont_1s>100){//0,5 seconds
cont_1s=0;
output_toggle(PIN_D15);
int cont=0;
output_a(0);
set_tris_a (0b0000000000000000);
output_b(0);
set_tris_b (0b0000001100101111);
set_pulldown(1, PIN_B0); //per il galleggiante ho bisogno di un pull down
set_pulldown(1, PIN_B1);
//set_pullup(TRUE,PIN_B0);
//set_pulldown(TRUE, PIN_B1);
output_c(0);
set_tris_c (0b0000000000001110);
output_d(0);
set_tris_d (0b0000100001001100);
output_e(0);
set_tris_e(0);
output_f(0);
set_tris_f(0xffff);
output_g(0);
set_tris_g (0b0000000100000000);
output_low(PIN_G7);
while(1){
Posted: Tue Jul 08, 2025 7:00 am |
And this has what to do with Error 51??????.
Do not use old threads to post. Launch a new thread if you have a new
problem.
However the code as posted compiles OK on 5.120 for me. I suggest you
re-install your compiler. |
ciccioc74
Posted: Tue Jul 08, 2025 9:01 am |
I'm not using an old thread. It just won't compile if I use enable_interrupts(INTR_GLOBAL); and it gives me error 51.
I'll try reinstalling the compiler.
Code: | Compiling xxx\blinkLedGb110.X\BlinkMain on 08-lug-25 at 16:58:
xxx\blinkLedGb110.X\BlinkMain.c:149:23: Error#51 A numeric expression must appear here :: Not a valid interrupt:
xxx\blinkLedGb110.X\BlinkMain.o ===> 1 Errors, 0 Warnings.:
Build Failed.:
make[2]: *** [build/default/production/BlinkMain.o] Error 31
nbproject/Makefile-default.mk:115: recipe for target 'build/default/production/BlinkMain.o' failed
make[2]: Leaving directory 'xxx/blinkLedGb110.X'
nbproject/Makefile-default.mk:91: recipe for target '.build-conf' failed
make[1]: Leaving directory 'xxx/blinkLedGb110.X'
nbproject/Makefile-impl.mk:39: recipe for target '.build-impl' failed
make[1]: *** [.build-conf] Error 2
make: *** [.build-impl] Error 2
BUILD FAILED (exit value 2, total time: 717ms) |
thank you |
Posted: Tue Jul 08, 2025 10:06 am |
You _are_ using an old thread. Threads in the forum should try to keep to
the subject heading they have. Your new question is about code failing
to compile, not Error 51. |
jeremiah
Posted: Wed Jul 09, 2025 8:15 am |
If reinstalling doesn't work, something to consider:
It looks like from the error you posted that the code provided here is not the code that is erroring. It looks like line 149 of the file is in error. My guess here is you have some code before that is wrong and the error is just propagating to that line instead. |
