I3C Support from CCS?
djsb
PostPosted: Sun Jul 06, 2025 2:50 am     Reply with quote
The PIC18F16Q20 supports I3C. I wonder if anyone is using this chip and if so are they using I3C. Does CCS support I3C yet? It seems to use only 2 wires and combines I2C and SPI. I've just started reading about it in the August 2025 edition of Practical Electronics magazine (a UK electronics magazine). Any info yet? Thanks.
PostPosted: Sun Jul 06, 2025 11:01 am     Reply with quote
You are missing the key point on this. The device only implements an I3C
'target' device, _not_ a master. It can't control an I3C bus, it is a 'slave'
device on the bus.
It can only be used with another device providing the master. So you are not
going to get any utility or speed from this till you have the master device....
So, what do you intend to use as the master device??????.
It isn't going to be any use, until they launch some master PIC's for this
I'm afraid. Sad
It is also limited in the modes it can support. As a peripheral, it is designed
to allow you to implement the PIC as a peripheral on this bus, not anything
more.
djsb
PostPosted: Sun Jul 06, 2025 9:57 pm     Reply with quote
Ttelmah,
Thanks for clarifying that. Saves me making a fool of myself by getting over enthusiastic again. I'll still keep my eye on this just in case.
David.
PostPosted: Mon Jul 07, 2025 5:17 am     Reply with quote
Yes. The great thing is that when we have some PIC's implementing the
master part, these hopefully will have the improved drivers this needs,
and allow I2C at much faster rates. It is still I2C 'like', but implements
high speed drivers, error correction, and a proper protocol for dynamic
addressing. Should be a very nice way to signal once we have both ends!....
Very Happy
PostPosted: Tue Jul 08, 2025 7:32 am     Reply with quote
As a comment, CCS have implemented DMA support and interrupt support
for the I2£ receive peripheral, but I can't see any setup function for it.
PostPosted: Mon Jul 14, 2025 2:57 am     Reply with quote
It is interesting, since I thought 'wonder why CCS have concentrated on
DMA for this'.
If you go and read the MicroChip page on I3C, it says:
The I3C peripheral is designed to integrate with the DMA controller on the MCU and provides multiple interrupt triggers for the DMA. Due to the high data throughput on the I3C bus, it is strongly recommended to use DMA for data transfers.
So, it becomes obvious why CCS have done this using DMA. Very Happy
It is also worth reading:
[url]
https://ww1.microchip.com/downloads/aemDocuments/documents/MCU08/ApplicationNotes/ApplicationNotes/TB3340-Using-I3C_TargetModule-8-bit-PIC-MCU-DS90003340.pdf
[/url]
Which gives an overview of where MicroChip are on this. They make the
comment in their overview that the 8bit MCU's only support target,
suggesting that there ought to be a master somewhere on the 16bit
chips, but as yet 'no sign' of this.
The really nice thing is the actual voltage support on the bus. Really nice for
intercommunication on a multi-voltage system.
