Does anyone in this forum have any advice or experience creating a software bill of materials (SBOM) for projects that use the CCS device or driver libraries? Or C projects in general? It's something that's only recently required for government and healthcare products, so there's not a lot of advice on the matter. I've got a project with almost exclusively custom code, but I'm using the device header for my microcontroller from CCS, and of course, the compiler. I'm somewhat at a loss of where to start. Any suggestions would be helpful. Thanks!
Posted: Tue Dec 10, 2024 10:59 am
The key would be to document the source versions (release data, and
compiler version), for every library you use. Obviously the same for the
compiler version used.
Have a look at SPDX. This is the Microsoft tool to generate these, and
you can feed it the data from a CCS project.
