Ternary/conditional operator - trouble with strings
lindsay.wilson.88
PostPosted: Fri Oct 11, 2024 7:54 pm     Reply with quote
I'm trying to use the ?: operator to choose a string based on a variable's value and I'm having trouble getting it to return strings. As a basic example, try this:
int1 clsmode=1; // Clear screen mode, 1 or 0
char teststr[10];
teststr=clsmode ? "Escape" : "Blanks";
On the last line, I get an error "Assignment invalid: lvalue is READ ONLY".
I had originally been trying it within a printf:
printf("Current clear screen mode is %s\r\n", clsmode ? "Escape" : "Blanks");
That actually compiles without errors, but produces gibberish when run.
I can get it working with individual characters, for example:
clsmode ? 'E' : 'B'
but not with strings. Not the end of the world, I can just use an if statement, but the ternary operator is much neater.
Edit: is this something to do with it?
https://stackoverflow.com/questions/12694202/ternary-operation-with-a-string-output-in-c
Something about being able to initialise a string variable with a string literal but not an expression….
PostPosted: Sat Oct 12, 2024 12:52 am     Reply with quote
Yes.
Assuming you have PASS_STRINGS=IN_RAM, then you can do this with
strcpy, but not with an assignment as you show.
lindsay.wilson.88
PostPosted: Sat Oct 12, 2024 12:16 pm     Reply with quote
Thanks - yeah, looking around, I think I get a feeling for why it's not possible. Never was entirely happy with pointers!
I've stuck to putting separate printf() in each possible option:
printf("   4) Clear screen mode: "); (clsmode) ? printf("Escape codes") : printf("Blank lines"); printf("\r\n");
PostPosted: Sun Oct 13, 2024 6:18 am     Reply with quote
You do realise what I am saying about strcpy?:
  char teststr[10];
  strcpy(teststr, clsmode ? "Escape" : "Blanks");
Understand that C itself does not understand or handle assignment of a
string with '='. It has to be copied. The '=' form can only be used in
a declared initialisation like:
char teststr[]="something";
jeremiah
PostPosted: Sun Oct 13, 2024 10:32 am     Reply with quote
you might also be able to predefine string constants and just pass them into printf using "%s" and a tertiary operator to select which one is passed in.
lindsay.wilson.88
PostPosted: Sun Oct 13, 2024 11:01 am     Reply with quote
@Ttelmah Thanks for the suggestion - I've just had a try with using strcpy, and with #device PASS_STRINGS=IN_RAM, but unfortunately it's outputting gibberish. Strcpy works fine with just a single literal, e.g. strcpy(teststr, "Escape");, but as soon as the ternary op is used, it outputs nonsense. Is there something else I should be doing?
I hadn't actually realised that C can't do string assignment with "=" - I probably knew it at one time, but it's been years since I've done anything serious in C.
@jeremiah - Excellent idea, thanks! As it happens, there's quite a lot of other 1-bit parameters which I want to show as "On" / "Off", so this will work perfectly for them.
PostPosted: Sun Oct 13, 2024 11:23 pm     Reply with quote
That is a limitation of the "pass strings" bodge then. In normal C that
works. I hadn't tested in CCS... Sad
A pity.
Defines are the way to go then. Very Happy
lindsay.wilson.88
PostPosted: Mon Oct 14, 2024 7:49 am     Reply with quote
No problem. I had found a few examples online which should have done the trick, but they again were in normal C.
